Question about Orion VR213 VHS VCR
What does ATR on vcr mean? - Orion VR213 VHS VCR
  • Orion Master
  • 5,391 Answers
I think it stands for AUTO TRACKING.
Posted on Feb 09, 2010
2 Suggested Answers
Grubhead
  • 5391 Answers
SOURCE: what does ATR mean?
I would guess it stands for Auto Tracking, since it appears only in play mode.
Posted on Feb 02, 2010
Why does atr appear on vcr sreen
Borrowed from Toshiba's site: Unfortunately this unit was meant to record from DVD to VCR and not VCR to DVD. The DVD section of this unit is a Player only and does not record. I was not able to find an "atr" function on the unit. If you meant OTR that stand for "One Touch Recording."
Jun 12, 2014 | Toshiba SD-V290 DVD Player/VCR
How do I disassemble the bolt on a mossberg 100 ATR
Apparently the three previous folks have no idea that a Mossbergt 100 ATR is a RIFLE not a shotgun. Regretfully it is a press fit at the rear (multiple splines, pressure fitted into multiple recesses). What that means in English is that it's a factory fix. Sorry!
Apr 11, 2012 | Mossberg Optics
Error codes 000070-001 and 00020-081 for iRC3180i
E020 Drum/Developer-related error
XX=01:Y XX=02:M XX=03:C XX=04:K XX=00:Any color
XX10 In INIT control of the initial setting,
SGNL is less than 62. Clean the ATR sensor window, Check on attachment of the developing unit, Check on a break
in the ATR sensor, Replace the ATR sensor
XX11 In INIT control of the initial setting,
REF is less than 62. Check on a break in the ATR sensor, Replace the ATR sensor
XX12 In INIT control of the initial setting,
SGNL is 960 or more. Check on a break in the ATR sensor, Check on operation of the shutter, Replace the ATR sensor
XX13 In INIT control of the initial setting,
REF is 960 or more. Check on a break in the ATR sensor, Replace the ATR sensor
XX50 When density data is computed using
SGNL value and REF value in ATR
control, REF becomes 0 due to backup
data corruption.
in the ATR sensor, Replace the ATR sensor,
Replace the DC controller PCB
XX51 When density data is computed using
control, the sensitivity coefficient
becomes 0 due to backup data
corruption.
XX81 P-SENS-P is less than 255 when a base
(drum face) of patch detection is read
out.
Clean the patch image reading sensor window
XX90 A computation result of patch reading in
patch detection is less than 16. Check on attachment of the developing unit, Replace the patch image reading sensor, Replace
the developing unit
XX91 A computation result of patch reading in
patch detection is 1008 or more. Check on toner leak from toner buffer in the developing unit, Replace the patch image reading
sensor
XX92 A computation result of patch reading in
patch detection is less than 42 for Y/M/
C and less than 73 for Bk 3 times in
succession.
the developing unit
X93 A computation result of patch reading in
patch detection is 522 or more for Y/M/
C and 543 or more for Bk 3 times in
succession.
sensor
XXA0 In ATR control, SGNL is less than 62. Clean the ATR sensor window, Check on
XXA1 In ATR control, REF is less than 62. Check on a break in the ATR sensor, Replace the
ATR sensor
XXA2 In ATR control, SGNL is 960 or more. Check on a break in the ATR sensor, Check on
XXA3 In ATR control, REF is 960 or more. Check on a break in the ATR sensor, Replace the
ATR sensor
XXA8 In ATR control, the detected T/D ratio is
upper than its upper limit (13%) 10
times in succession.
developing unit, Replace the ATR sensor
XXA9 In ATR control, the detected T/D ratio is
lower than its lower limit (3%) 3 times
in succession.
and,
E070 ITB HP detection error
0001 HP of the ITB fails to be detected even
after the specific period of time.
Abnormality of the HP sensor,
Deviation of the belt from its position to
either edge, or soiling of the seal
Clean the HP detection seal, Clean/Replace the HP
sensor
...so, I pressume that something is broken, because you are getting these two error codes... call service, or write on emma.servis@gmail.com for service manual.
Hope that helps!
Aug 10, 2010 | Canon Office Equipment & Supplies
Canon3100 with code e000020-01a9 and -02a9 and -03a9, turned off. checked drum, fuser seems ok help
data corruption.
corruption.
out.
the developing unit
sensor
succession.
the developing unit
XX93 A computation result of patch reading in
succession.
sensor
ATR sensor
ATR sensor
in succession.
BUT FIRST: Check the ATR SENSOR, left from the developing rotor you have an "rail" with atr sensor - vacume it!!!!! Vacum all dev units, and copier
Apr 20, 2010 | Canon imageRUNNER C3200 Copier
What does ATR mean?
Feb 02, 2010 | Orion VR213 VHS VCR
E020 sub code 0481
ATR Error (E020-XXXX) Display due to Dirt on ATR Sensor Window
Cause
The waste toner may adhere on the ATR sensor window or the sensor shutter. As a result of that, it may be faultily detected as ATR sensor fault and trigger the ATR sensor error (E020-XXXX).
The detail codes (xxxx) are as follow: XXA0, XXA2, XXA8, XXA9, XXC0, XX10, XX11, XXDA.
Filed Measure
Clean the ATR sensor window and the ATR sensor shutter with the following procedure. 1) Remove the ATR sensor from the main body. 2) Press the plunger [1] of the ATR sensor lever solenoid in the direction of the arrow. 3) Clean the ATR sensor window [2] and the ATR sensor shutter [3] with lint-free paper [4].
Pls rate thanks!!!!!!!!! dont forget testimonial mate.
Oct 17, 2009 | Canon CLC 1150 Color Copier
My tape won't play, I just get an
ATR keeps showing on the TV screen when I am trying to play a tape.
Jun 17, 2009 | Toshiba SD-V290 DVD Player/VCR
Orion D1050
need remote contro'
Feb 07, 2008 | Orion VR213 VHS VCR
My VCR is playing too fast
try recording on a blank tape and setting the tape speed to SP (standard play). you should also see options for (LP-long play) and SLP (super long play). I think your machine is stuck on SLP option. if no-go, look for a manual on the web.
May 27, 2007 | Daewoo DV-T8DN VHS VCR
Orion VR213 VHS VCR Logo
1,292 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
