Question about Dell Computers & Internet
I tried to add RAM and now laptop will not power up. Did taking the back off the computer cause it to die?
  • 102 Answers
No but if you installed the RAM without wearing a wrist strap or other anti-static protection then you could have damaged the RAM.
Otherwise check the laptop manufactureres website to make sure that the RAM you purchased is compatible with your PC.
Posted on Feb 06, 2010
Acer Extensa E210 totally death
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Aug 15, 2012 | Acer Computers & Internet
I need to be able to type on my laptop keyboard it just stopped working .
Remove main battery and power on, if no change! remove one stick of ram, try again, remove second stick and put the first one back, any change? power supply should checked, if okay! the DC jack in the laptop breaks free causing no power. A professional will be needed to take computer apart down to the motherboard level to make the determination.
Mar 08, 2012 | Toshiba Computers & Internet
Toshiba a210: Powers up on both battery and power source. When powered on the caps lock blinks green most of the time but not always. Display does not come on at all, no blinking, flickering, or...
Just out of curiosity, you haven't got a usb device plugged in as you are booting the laptop have you?
If not, try this:
Remove battery, unplug power, hold power button for 60 seconds, turn on computer with power plug only, then shutdown, add battery and restart
If that fails to work, check that the charger indicator light is not flickering, this indicates that the power is not completing the circuit (damaged power capacitors/ fault on motherboard.
Are you using a genuine Toshiba charger, these laptops are prone to breaking down if an aftermarket one is used, a non-genuine one can damage the motherboard as well.
How many blinks does the caps lock make? Flashing caps lock is usually a sign that the Ram may be failing. You can try replacing the Ram modules to see if it boots, also, a dying hard drive will prevent booting, remove and see if that allows the laptop to power up
After that, I'd suspect the motherboard is damaged and will need replacing
Jun 15, 2011 | Computers & Internet
My computer is starting up but it wont go any furthur, im wondering would anyone knoow what the problem maybe???
Possibilities:
* flaky AC power supply
* dying battery
* flaky motherboard, causing "intermittent" problems
* bad RAM, causing "intermittent" problems
* bad spots on the disk-drive, causing "intermittent" problems when reading/writing
* a messed-up installation of Microsoft Windows
Take the original "System Restore" set of CD-ROMs, and boot from them.
If it loads into the "system recovery environment", and asks you whether you really want
to reinstall Windows, STOP. If your computer gets this far, then several components:
* power supply
* battery
* RAM
* motherboard
* CD/DVD drive
probably are OK. This leaves the disk-drive as the "suspect",
and it leaves your possibly-messed-up installation of Windows as the other "suspect".
Feb 24, 2011 | Dell Inspiron 1525 Notebook
I just put a new 9 cell battery, two new 2GB ram cards & a new, blank hard drive in our Dell Inspiron 1525. But the screen does not seem to work when I turn it on, or after I put in an installation...
Remove the battery, and connect the AC power. Then, try to start it.
Disconnect the AC power, and remove the "new" disk-drive.
Then, connect the AC power, and try to start it.
Disconnect the AC power. Remove the "new" RAM, and put the "old" RAM back in.
If it does start, add the "new" disk-drive, and try again.
If it does start, add the "new" RAM, and try again.
Jan 15, 2011 | Dell Inspiron 1525 Notebook
Laptop died suddenly and is not charging
Take the battery out and discharge the capacitors by holding down the power button for 15 seconds. plug in the charger without the battery in to see if you get a charge light. If you do, replace battery and plug in charger and power on laptop. If this does not work, you may have to pull the cmos battery for 15 minutes and try it again.
Oct 03, 2009 | Computers & Internet
Power light is on, no POST
With power cord connected no add on ram just the basic system ram the laptop should post if it's not she's dead could be mother board CPU not ram the system will beep code you if ram. I sorry to say that it sounds like your laptop died. try taking out the add on ram use your power cord that will tell you right there. was it working before you replaced the ram?
Mar 20, 2009 | Toshiba Satellite M115-S3094 Notebook
Pc died suddenly. dies during reboots.
I would try to blow out the pc with canned air. Please take a look at this video for help on how to perform this.
Mar 17, 2009 | Compaq Computers & Internet
I have a presario f500 and it will not turn on
Try this:
Unplug everything (and I do mean *everything*) from the laptop and remove the battery.
Then with no power of any kind for the laptop, hold down the power button 15 seconds.
Attach A/C power and try to turn it on.
If that does not work, remove power and take out the CD/DVD drive and if you feel
comfortable with it, take out the RAM and hard drive.
Connect power and try to turn on. See if you get beeps or a power light on the laptop. If
you get beeps, put the RAM back in and try power again. If that gives you a display, add
back the hard drive.
Let me know what happens.
Honest1abe
Jan 12, 2009 | Computers & Internet
Computers & Internet Logo
Alun Cox
