Question about Fellowes 220 Powershred Strip-Cut Shredder
It has power but the teeth won't roll - Fellowes 220 Powershred Strip-Cut Shredder
  • 41 Answers
It may be a gear or jammed up or may be birdnesting
Posted on May 11, 2010
94 Chevy Blazer S10 driver side front power window not working. The window motor works with the switch but the gears don't seem to meshing.
OK remove the motor out , and take the motor cover out and you will found 3 thing broken in said , replace it . let me know .
Nov 16, 2011 | 1994 Chevrolet S-10
Windows won't roll down, and it won't auto lock,
There are fuses for both windows and door locks, If fuses are good may be electrical problems
Sep 23, 2011 | 2001 Mercury Sable
My left rear window won't roll down. When I go to roll it dow (via the little button thing) I can hear it clicking inside the door. Is there a way to take the frame off the inside of the door to get to...
there is a gear on the motor that goes bad it is plastic the teeth get stripped take the door panel off (screws and push tabs) when you get the screws out take a putty knife on the bottom edge and start popping the panel out then take it off, get to the motor drill the rivets out and replace put back together
May 09, 2011 | 1998 Buick LeSabre
I bought my son an old fashioned hot dog roller for Christmas. It worked great the first time and the second time he went to use it, the rollers wouldn't roll. I've read several reviews on this product...
The 5 rollers are operated by 9 small gears that a run by the center gear which is turned by the motor on your machine. The gears in between the rollers help drive the next roller as you move outward from the center. The gears are made of what looks like pot metal, (cheap junk). The teeth break on the gears easily and either stick or won't operate the next roller. You can take the unite apart using a thin screw driver an pry the 6 flange on the drive side and straigten the flange with needle nose plyers. It then prys apart. If any teeth are broken, you can only buy a whole new grill part from Nostalgia Electrics. Cost is 20.00. They won't just sell the junk gears
Jan 06, 2011 | Nostalgia Electrics Hot Dog Grill Roller...
I have power windows in my 1987 Chrysler Fifth Avenue and I was just driving around town, rolled down my front driver's side window and now it won't roll back up. The rest of my windows roll up and down...
this happened to all four of my windows. the inside the door panel there is a gear for the window mechanism, this gear is only made of plastic so due to old age it gets brittle and then the teeth on the gear fall off. its not a big deal though just go to a auto window place...they fixed all four of mine
Oct 28, 2010 | 1987 Chrysler Fifth Avenue
Driver side window will not roll up or down on my 1992 Corolla. have you ever had this problem and how did you fix it?
you should open the door panel and check if the rolling motor is trying to roll at all, if it is then the teeth for rolling up is weak else then check the fuse for the motor
Jul 17, 2010 | 1992 Toyota Corolla
Driver Power Window Won't Go Up
The window regulator has gear teeth on it that connects to a metal track attached to the window glass. The teeth are most likely stripped and the grinding noise is the motor trying to mate to the broken teeth. You need to replace the window regulator and I wouldn't hesitate to replace the motor at the same time. It's a costly fix but worth it to only have to be inside the door once and the motor will have to be removed at the same time the regulator is replaced. If you can reach the glass and pull up on it at the same time you can probably get it to roll up as a temporary fix.
Aug 09, 2009 | 1999 Buick Century
Cannot load new paper roll into the calculator so it catches
Replacing the paper roll involves feeding the evenly cut, uniform end of the roll through the fine slot located under the paper arm at the back of the calculator. (Even if the paper is only slightly wrinkled or cut unevenly, it will not feed through the teeth in the loading area.)
When getting ready to feed the paper into the calculator, envision your printout feeding out of the machine away from you and back toward the paper roll. Don't insert it upside down.
To get the paper feeding through once you have partially fed it into the teeth, gently tap the paper feed button. Once or twice should do it. (The button is located on the far top left of the control panel, indicated by an arrow jagged saw mark icon).
Then, slide the paper roll onto the feeder arm and you're in business.
Apr 09, 2009 | Sharp EL-1801C Calculator
My HP Deskjet 400 won`t properly print a straight vertical line
check the print head belt.......belt that moves the cartridge from left to rite
check to see if all the teething grooves on the belt is intact...and that its all there..if this belt slips a teeth it wont print in a straight line....
Nov 09, 2008 | HP Office Equipment & Supplies
Window problems
How many windows will not roll up? Do they roll up from the individual door switches or are they totally dead? Did you have the driver's door panel off, and if so, did you remember to plug the master window switch back in?
The fuses for the power windows are in the underhood fuse box. Each window has it's own fuse. I would start by checking those.
Jun 02, 2008 | 1991 Honda Accord
Fellowes 220 Powershred Strip-Cut Shredder  Logo
127 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
