Question about Altec Lansing XT1 Computer Speakers
No sound from Altec Lansing XT1 speakers
No sound from speakers even though they appear to be correctly installed and are visible in My Computer as working correctly. Worked before I unplugged them earlier today.
  • Bill Brown May 11, 2010
    There are generally three different ports to plug them into, is there a chance you plugged them into the wrong port? It is generally the green outlined port.
Cannot turn off power on speakers?
Posted on Mar 17, 2010
The same thing is happening to me...did you ever figure out how to fix it?
Posted on Feb 16, 2010
My altec lansing bx1020 is not working after i upgraded my pc to windows 7.
The problem is not with your speakers.
When you upgrade to a new Operating System, sometimes your hardware is not recognized correctly by the new OS.
In your computer, the sound card is not installed correctly. Search for Windows 7 sound drivers for your sound card and install.
If you think the problem is with your speakers, you can check by connecting them to another computer or an audio device.
Sep 11, 2011 | Altec Lansing BX1020 Computer Speakers
NO LIGHT - no sound altec lansinG XT1
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers if this fails to fix the problem
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Jun 15, 2011 | Altec Lansing XT1 Computer Speakers
I have a pair of XT1s, I plug em all up and there is sound for a split second then nothing.. does that each time i turn the power on.. any clue whats up?
I have the same problem. Mine works fine if only the one speaker is plugged in, but as soon as I plug in the second one, it cuts out.
Jan 18, 2011 | Altec Lansing XT1 Computer Speakers
Just bought expressionist Ultra, when I plug it into my MacBook Pro no sound comes out.
Click on the Apple icon and look at the sound options in the system preferences. If the Mac does not detect your speakers, you may need to install drivers for them. Try doing that at the Altec Lansing site. Also try the tech support at Altec Lansing and at Apple.
Oct 06, 2010 | Altec Lansing XT1 Computer Speakers
My altec lansing mx5021 speakers problem
The problem I have found is the contact glue between the back panel and circuit board inside the sub woofer. The glue becomes conductive after some time (2 years..!!) and needs to be scraped away from across tracks, you can tell the problem areas as the glue is pale yellow but goes brown and conductive over time. Good luck.
Regards
aj
Feb 18, 2010 | Altec Lansing MX5021 Computer Speakers
I have an XT2 computer speaker set. The program seems to be gone. I have the speakers plugged in and there is no sound. When I check the control panel there is no Altec lansing device listed. Do I need to...
Hi there bud, if it is related too your Drivers ,Then simply reinstall your Sound card drivers or Motherboard Drivers , It will work perfect then...You dont need to install Drivers for your Speakers ....Try using one of those Driver update programs too update it for you..
Hope you come right bud
Happy new year
Jan 06, 2010 | Altec Lansing XT1 Computer Speakers
Computer not seeing Altec Lansing BX1020 speakers
go to start>settings control panel> click on system then click on device manager. Make sure that everything is working properly then in control panel click sound. if that is all working. Make sure you have the speakers connected in the right spot. You may also want to try the speakers on another computer to isolate exactly what the problem is.
Thank you,
lee
Nov 10, 2009 | Altec Lansing BX1020 Computer Speakers
No sound after i buy new PC ( speaker altec lansing atp3) should i install altec driver ?
check the port to which u have connected ur speakers. And also install proper driver
Aug 20, 2009 | Altec Lansing ATP 3W Computer Speakers
Power up but no sound, I have correctly assign sound in computer
in system preferences go to sound and see if the speakers are selected?  sometimes a restart can reset system to standard.
May 30, 2009 | Altec Lansing XT1 Computer Speakers
Altec Lansing XT1 Computer Speakers Logo
612 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
