Question about Garden
I hav a Dayton 150,000btu kerosene space heater, model 3E219B. it seems to be running rich and putting out alot more smoke than normal. what can i adjust to make it work right?
  • reedmanx1 Feb 07, 2010
    thanxs, it did the trick
  • 11,896 Answers
The spark plugs are always on when the heater is on. On the back of the heater, you should see a bolt with a hole drilled in it. This bolt has a spring with a ball under it that acts as a "main jet" in that the more in you screw it, the less the amount of fuel that is fed in. (All the screw does is adjusts the amount of air going to the atomizer nozzle-more air=more fuel/Less air = less fuel.) On my old heater I kept a 7/16" wrench to "fine tune" it because as it and the air in the shop warmed, it would run too rich (no more than 1/2 turn)
Posted on Feb 07, 2010
  • Nate Stansfield
    Nate Stansfield Feb 07, 2010
    Not a problem! Thank YOU for using Fixya!
How to ajust dayton 155000 btu torpedo heater when running smell like kerosen
You say: When running it smells like Kerosene--
That is what you are burning in it, right?
Is it smoking--- like there is a poor combustion mixture?
-- like maybe not enough air pressure?
There is a pressure adjustment for both-- Please check the manual for adjusting the pressures for your particular model.
Jan 18, 2011 | Dayton E50 Heater
Is the front of the fuel powered heater supposed to glow red?
Hi, and the answer is yes. All fuel powered type heaters will glow red, or bright orange. Example, a space heater that runs on #2 fuel oil, natural gas, gas, kerosene, ect. will glow this way, so do not be alarmed. This is normal.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Jan 04, 2011 | Dayton Heating & Cooling
Getting alot of smoke when running
The manuafacturer has a technical support website that offers technical service manuals. You can go to www.desatech.com . I hope this helps!
Jan 11, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
I have a dayton model 3e218d heater and would like to know if i can use no. 1 deisel fuel oil
if the owners manual says kerosene, or the name plate says kerosene, no you cannot. diesel fuel is slightly more viscus and burns cooler, this will cause smoke/ odor issues.
Jan 10, 2010 | Heating & Cooling
Have older 3e198 kerosene portable heater,will not run but a feww minutes. if i take the top shieldoff it runs great
Set the pump pressure to specs. If unsure hoe to do this instructions are at reddyparts.com 's website.
If the heater still has the same symptoms- then change the nozzle. Desa (the mfgr of your Dayton heater) recommends ANNUAL replacement of the nozzle. The nozzle should create a fuel FOG but it becomes a fuel SPRAY after a period of running, due to wear.
May 04, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Kerosene Portable Forced Air heater comes on, runs awhile
Here is a link to your owner's manual... http://12.153.20.74/manuals/123919-01A.PDF. Look on page 8 and 10. It could be several things. It could only be a dirty fuel filter or the pump pressure may just need adjustment. If you need a part you can contact Master Parts at 800-466-1446 or you can find them on-line at www.masterparts.net. I hope this helps!
May 04, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Dayton kerosene heater 3E219B will not turn on
I have a Dayton Model # 3e219b 150,000 BTU potable heater and it runs fine with the top cover off.But if I put the cover on it will go out is less than a minute and trip the reset.
Jan 31, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
150,000btu Dayton htr (torpedo) lights, runs10 min fine, then shuts off
check for proper pump pressure. Restricted fuel flow. Proper venting of fuel cap.
Feb 19, 2008 | Dayton E52 Utility Heater
Dayton mod#3e219b gas heater
who told you air pump is supposed to be 5 psi? at the desatech site in their PDF troubleshooting guide air supposed to be 3.0-3.5 psi.
Dec 26, 2007 | Dayton G73 Utility Heater
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
