Question about Kenmore 63942 Dryer
The dryer turns on but the drum doesn't spin - Kenmore 63942 Dryer
  • 572 Answers
Belt is broken
Posted on Feb 06, 2010
  • 24 Answers
SOURCE: dryer doesn;t spin
Sounds like the belt has broken. The terrible noise was probably the belt slipping until it gained traction.
Posted on May 19, 2009
dmftrucker
  • 1922 Answers
SOURCE: dryer drum will not spin. motor hums when button
either the belt is broken that turns the motor or thr idler tension pulley is bad, if it were a motor problem the breaker most likely will trip
Posted on Nov 01, 2009
  • 161 Answers
SOURCE: When Turned on, drum will not spin?
if the motor is running,your belt is the problem.if all you hear is a slight humming noise,you may have a bad motor,or something caught in blower. if the drum turns easily by hand,its probably the belt
Posted on Mar 06, 2010
oldTech2332
  • 2341 Answers
SOURCE: When i tried to turn
Those symptons (humming/buzzing ¬ starting) are 99 out of a 100 times a sign of a motor that has locked up.
Gene
Posted on Aug 07, 2011
Testimonial: "nice"
ftw1952
  • 10319 Answers
SOURCE: Drum doesn't turn..Motor sounds fine
replace the belt and idler pulley as a set sold at any Sears store
Posted on Aug 14, 2011
Dryer drum doesn't spin
If the motor runs and the drum doesn't turn then most likely the belt is broken.
Oct 23, 2012 | GE DBVH512EFWW Dryer
Westinghouse Electric Dryer, Drum doesn't turn on start up, if your spin drum and close door it will start,
Either something is binding the blower wheel up or the motor is bad. The best thing is to take the front of the machine off to access the blower wheel to verify ifanything is indeed binding it.IF not read the next section.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
Jun 22, 2012 | Westinghouse Laundry Dryer Motor...
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
My dryer will turn on, when I push the start button the sensing indicator lights up, but the drum doesn't turn and no air flows. I had a tech come out and tell me it was the main control board. We...
Most dryers have a belt that goes around the drum attached to a spring pulley and the motor pulley, if the belt breaks. the drum will not spin. and most dryers also have a safety switch in between the door and the dryer, if this switch is bad,will not let the drum turn. most dryers have a vented slot in the rear of the machine at the bottom, if you remove this vent you should be able to see how the motor moves the drum. good luck!
Aug 19, 2011 | Whirlpool Dryers
Ive just installed a new door kit onto my fisher and paykel de45f56a dryer. It has never had a door as it was cracked when purchased so the dryer has never been started. I have now fitted the door however...
yes, double check the switch first. it sounds like the motor is not even moving, since the dryer was never used before sometimes there is a "tab" or locking mechanism to keep the tumbler form moving during shipping.
Mar 27, 2017 | Dryers
The dryer is plugged in and the circuts seem to work however the dryer is making a humming noise but it will not turn on fully.
what do you mean it won't fully turn on?do you mean the motor won't run because usually when it humms you either have a bad motor or something is jammed and stopped the motor from spinning.try this,open the door,with one hand hold the door switch in and with the other hand spin the drum,have someone else push the start button while you do this,if it starts the motor is bad,if you can't spin the drum something could be stuck in the blower wheel or the belt broke and could of jammed up the motor but it sounds like you have a bad motor.let me know what you find and next time send the brand name and model number.
May 04, 2011 | Dryers
Dryer doesn;t spin
May 17, 2009 | Dryers
Kenmore 63942 Dryer Logo
85 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
