Question about Sharp AR-M700N Copier
Sharp AR-M700N damaging fuser rollers. I just replaced both rollers, Upper and lower, the cleaning rollers as well and when I installed on the machine it bacame so hot it rip off the skin of the lower roller and stick it to the upper roller damaging both rollers. I cheked the the temperature settings in the simulation mode and the pressure settings. Please help me what else I can do, I really needs this machine running. By the way I have replaced the rollers twice already with the same results.
  • 33 Answers
It sounds to me like you have some severe fuser thermistor and thermal fuse problems ...i would look into getting an entire fuser assembly sharp part number DUNTW7305DS** last digits depend on your location and power supply
Posted on Jul 20, 2010
The paper is crumpled in the lower part of the paper.
Maybe you have problems with the upper fuser roller, open the back door and try to see the upper fuser roller and lower pressure roller if you see any wrinkles or damage in any of the rollers that's is the problem, you can replace them just the upper fuser roller and the lower pressure roller but it will need advanced skills, the other option is change all fuser assembly but at higher price
Nov 26, 2013 | Brother HL-5250dnt Laser Printer
Sharp AR M700N toner not fusing properly
your bushing at fusser unit is worn out
Jun 03, 2013 | Sharp AR-M700N Copier
AR-M355 Latent copies.
This make is not my specialty, but if the fuser's been replaced, then it can only be a drum cleaning issue causing that problem.
Dec 28, 2009 | Sharp AR-M355N Copier
AR M700N copier jams... trouble code H5-01
h5-01 error is five consecutive jams in the fusingg section. P*C* gets you into dervice mode thenn 14 for trouble reset. then execute and restart. check the fuser pawls for dull edges and breaks. also check roller tensioning system on fuser.
Oct 13, 2009 | Sharp AR-M700N Copier
I need part numbers for Sharp AR-m620 fixing unit cleaning rolle
The part number is DUNTW7305DS88, DUNTW7305DS80,DUNTW7305DS11, DUNTW7305DS15
Not really sure which one is right - I found the part number on
Precision Roller.com they have only one part number on there web site # H3164 It cost $595.00 if your not a vender.
Dec 11, 2008 | Sharp AR-M700N Copier
SHARP AR C250 Digital Color COPIER. SERVICE CODE H4 00.
the machine is detecting a low temerature in the fuser unit. a commen cause is the thermistor digs into the fuser roller and tears the outer skin and the roller. you can check by opening the front door slide out the main unit open the door on the left hand side and you should see two orange rollers. check if the upper roller has a line around it.
Nov 17, 2008 | Sharp AR C250A Color Copier
Sharp ar-235 doble image in the copy
1.Might be a fuser problem. Check the upper fuser roller not to have toner on it.
2.The quenching lamp, if any, might be burn out.
Oct 19, 2008 | Office Equipment & Supplies
Sharp copier m550n
L4-03 is a lock of the fusing motor. It's likely you need to have the fuser rebuilt. You can try resetting the error by turning off the main power switch (located behind the front door under a little plastic cover) and back on. It's likely the error will come back. There's a cleaning screen on the lower fuser roller which gets gummed up with toner and sticks to the lower fuser roller causing it to seize and the motor not to be able to turn causing the L4-03.
Oct 06, 2008 | Sharp AR-M550N Copier
Sharp AR-M700N Copier Logo
118 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
