check your lid switch ,or debriss in drain pump ,pump can not run will not spin untill machine waterlevel switch comes below a certain level of water pressure
The draining problem could be something stuck in the pump. A easy fix just take it apart and get whatever is in it out of there. The agitator sits atop an agitator drive block. The spline on these tends to strip out. Yank off the agitator (it just snaps on) and replace the drive block.
If the machine fills, won't agitate, wont drain or spin, then you need to replace the lid switch.
if machines fills, wont agitate, will drain but not spin, then you need to replace the motor coupling
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain
hose connected to the pump (pump is usually located at the bottom
and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the
water pump such as a frozen pulley or a broken impeller. If that's
the case replace the water pump. Note: if you have a belt driven
washer, check the belt(s) for cracks, as this would be a perfect
time to replace the belt(s) if needed.
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
The whirlpool calypso was a lemon!!! if i were you i would buy another machine. They have many problems! Pumps go out very frequently and they are over 80 dollars. Save and buy a new machine... Sorry for the bad news.
Okay...I'm a little confused on your symptoms. You initially said it fills, but doesn't agitate or spin, but drains. Then, you finished with the washer filling, no agitate or spin, but now doesn't drain. Which one is it? The symptoms you describe are usually associated with the following: 1. Fills, may or may not agitate, won't spin or drain - lid switch. 2. Fills, may or may not agitate, won't spin, but still drains - motor coupling. 3. Fills, may or may not agitate, won't spin or spins slow - gear case. 4. Fills, agitates, spins, but does not drain – water pump. NOTE: These are the more common failure items with these symptoms. Double check the lid switch by opening and closing the lid. You should hear a clicking noise to indicate the switch is working. The switch is located under the top panel along the wash tub rim on the right-hand side. If not, check to make sure the lid strike (small plastic piece on the lid itself) is in place. This activates the lid switch when the lid is closed. Also, check the mounting screws along the rim (there are two of them) to see if they are tight. If the motor coupling were bad, the washer would still drain, but there would be a rattling sound as the washer tries to spin or agitate. If you need replacement parts, go to searspartsdirect.com and type in your model number in the "Search by Model Number" window. The lid switch can be found under the "Top and Cabinet" heading as item number 11 (part #3949238).Instructions on how to replace are located at the following link: http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top If you wish to replace the motor coupling, the part can be found under the “Brake/Clutch/Gearcase/Motor/Pump” heading as item number 13 (part #285753A).If you need instructions on how to replace, just follow this link: http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top Now, there’s a couple of ways to drain the washer. If it’s a simple lid switch problem, you don’t need to drain the washer to replace the switch.With a broken switch repaired, the washer will run and drain by itself.However, if you wish to drain the tub you can use a shop vac to pull a vacuum on the drain hose.This may take a few times depending on the size of the shop vac.These wash tubs typically have about a 35 gallon capacity.If you do not own a shop vac, you can by-pass the lid switch by jumpering the two BLACK wires at the lid switch connector that is connected to the console.CAUTION: Make sure you UNPLUG the washer before jumpering, then plug back in. I hope this information is helpful to you.If I’m wrong about the symptoms, please post back and update me on what the washer is or is not doing, so I can assist you further.
If the machine fills and agitates but does not drain, something is probably wrong with the drain hose or the pump. The fact that the washer fills and agitates tells you that the motor works and the belt is okay (though some units have a separate belt for the pump and direct-drive washing machines don't have belts).
1) Be sure the drain hose isn't kinked.
2) Check the tab on the lid that strikes the lid switch; if it is broken, the washer may stop during the drain cycle. Press and release the lid switch: if it doesn't click each time you do this, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person.
3) The water pump may be broken or clogged with a small article of clothing or the controls may be broken; call an appliance repairperson.
courtesy "nagev"
