Question about Refrigerators
What does ER FF mean on the ditigal display? Model LFX21960ST Refrigerator w. Ice and Water dispenser
  • 1,531 Answers
This means that the evaporater an has quit working.need to find out why
Posted on Feb 06, 2010
What er ff mean at Error message on display of Kenmore Elite Bottom Freezer Refrigerator
Hi.
Error ff (er ff) means defective fan detected. Before calling support or before replacing the fan try performing a complete defrost by leaving power disconnected for one day (remove food from inside the unit first). That will fix the problem if the fan was temporarily malfunctioning because of ice formation. If that does not work the fan must be tested before replacement.
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 09, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Cheats sf
We don't understand what you exactly mean. If it means a eror code, please find below the error codes and its solutions.
Er FS - Freezer Sensor Error
Er rS - Refrigerator Sensor Error
Er ds - Defrost Sensor Error
Er dH - Defrost Heater Error
Er CF - Cooling Motor Error
Er CO - Communications Error Er-Ff- Freezer fan fault. Write again if you're not satisfied with this answer.Thanks.
Feb 24, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Our refrigerator constanly has ER FF in the ice & water display area. What does that code mean.
This error code ER FF indicates a problem with the evaporator fan motor but it can also be with the main control board. When the power cord is disconnected for 30 seconds and then reconnected, it resets the board. But resetting the board does not solve the problem always. The Defrost Control Board being defective will also show this error. The best solution would be to look for your complete model number and contact me HERE and I will send you your models Service Manual and parts to look for, I will continue to publish manuals HERE, Thanks, Sea Breeze
Feb 20, 2011 | LG Refrigerators
I have an LG SXS side by side refrigerator that will not dispense water. The display shows FR & FF. If the supply is switched off and then back on again the display resets for a period of time. Over...
Er FF - Freezer Fan Error - This can be caused byfrost accumulationon or around the freezer fan. Unplug the unit for 3-4 hoursto allowthis to melt off. If error code persists, call Customer Service.
Jan 20, 2011 | LG LSC26905TT Side by Side Refrigerator
I have a Kenmore Elite Refrigerator, Model No. 795.77573600. The ice and water dispenser give the error message Er 1F. In searching online it appears that this problem is related to the ice compartment...
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 25, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
DITIGAL ERROR DISPLAYING MESSAGE?
check your service manual and see what it say about err dh
Mar 30, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Error code Er IF is on the display and noone from sears can tell me what it is, does anyone know?
ER IF means error icing fan, the problem is with a little board that is behind the water dispenser. Change this board and you will be in business.
sgt 48
Jun 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Error Code ER FF
FF is your freezer fan. You may need to defrost the unit.
Feb 28, 2017 | LG French Door Cabinet Depth Refrigerator...
Display screen says "Er ff"
LG's bottom mounts have had problems with air leaks in freezer making a iceball right under the evaperator fan actually coming close enough to the fan blades to slow them down or stop them all together also causeing the FFerror meaning the control board is not detecting the normal RPM's you should to keep it cool enough. Suggestion take the back panel off and remove any ice carefully if this be the problem. Make sure all doors are closeing tightly and gaskets make a air tight close.
Jan 20, 2008 | LG LFX25960ST Stainless Steel French Door...
Refrigerators Logo
123 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
