Question about Magic Chef MCWC30MCG Compact Wine Cooler
I am getting an E3 Error message on my temp
I am getting an E3 Error message on the temp reading on my Magic Chef wine cooler
  • Anonymous Mar 30, 2014
    an E3 code came up on an led read out on front of door
Do this...
The e3/e4 problem is the "connectors" for the fans to the middle separator shelf are put in the pathway of condensation. This causes them to get wet and rust. PLEASE NOTE: If you decide to attempt this fix, you take full responsibility for your fridge and the outcome. If you don’t think you can do this…DON’T! Call a licensed electrician. Here is how I resolved my e3 issue: 1) Unplug the fridge
2) Remove all wine and the metal shelves
3) Remove the 2 screws from the middle separator shelf, one on each side on top
4) Remove the 4 screws from the backboard, one in each corner
5) Slide out the middle shelf slowly, on the right hand side towards the front of the shelf there will be 4 connectors you must disconnect before removing the shelf (they are tucked into the shelf). With one hand on the backboard and one on the shelf, slowly take them out together
6) Once you have the backboard and shelf out, you'll see there is a black and white connector, each having a red and black wire on each side
7) These are the fan connectors that are causing the issue. Mine were brown/green and damp (not good for electricity)
8) Using wire cutters, cut as close as possible to the "black" connector on each side to remove it. You will have 4 wires left, 2 from the backboard and two from the shelf (both having a red and black)
9) Take some of the sheath (cover) off of each wire
10) Take the red wire from the backboard and the red wire from the shelf and twist the metal portion together
11) Cover w/ electrical tape!!! Or you will have the same e3/e4 issue
12) Repeat step 10 and 11 for the black wires
13) Move onto the "white" connector and repeat steps 8 - 12
14) Put the backboard and shelf back in the fridge. Be careful not to pull the backboard and shelf apart or your connection may come apart
15) As you slide the shelf in, make sure the wires you disconnected in step 5 are in the "channel" on the side of the shelf or the shelf won't slide properly.
16) Reattached the 4 connectors and then re-attach the backboard and the shelf with the screws
17) Plug the fridge back in
18) Put the metal shelves and wine back in
Posted on Feb 08, 2010
    Problem Solver:
  • 5 Answers
If this does not work for you parts can be ordered at:
http://www.mcappliance.com/partordermain.aspx
Posted on May 17, 2010
Magic chef wine cooler not gettng cold
at sears .com the schematic lists a "protector" part 265RFBYY
is this the overload?
also somewhere else I saw the temp stat was a problem, how would I rule this out? (Its expensive)
thanks
Jun 23, 2014 | Magic Chef MCWC45A Wine Cooler
Magic Chef Wine Cooler Model #MCWC50DBT will not hold correct temperature. Temps fluctuate between about 45 to often 70 degrees F. Also, often get an "EEF" error message.
Mr. Lindquist: We are experiencing essentially the same problem. Have tried replacing the temperature control board without change. Would be interested to know if you get a solution.
Aug 10, 2013 | Haier BC112G Wine Cooler
HH error code? on magic chef mcbc580dbt
I, too, have just seen (late June 2013) the "HH" code on my Magic Chef wine cooler (and it is running too cold and I can't reset the temperature). Have you found a solution since your posting of about 1 year ago?
Jun 27, 2012 | Magic Chef MCWC30MCG Compact Wine Cooler
Received apparent error message "E3" for upper
E3 is a fan error. This is usually caused by poor connection to the fan. Remove all connectors and reinstall assuring tight connection. This should remedy it unless the fan is bad, which is very rare!
Jan 12, 2011 | Magic Chef MCWC44DZ Wine Cooler
E3 error code on my Magic Chef Wine Cooler - what does this mean? Not sure of the model # but its only 1.5yrs old...Thanks!
could be a broken fan, compressor gone, thermostat. neither one you can fix. you need a refrigeration mechanic or a new fridge
Nov 11, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Wine refrigerator is not worjung
IN YOUR USER MANUAL THERE WILL BE A TROUBLE SHOOTING SECTION. CHECK IT OUT AND IF POSSIBLE GET A TECHNICIAN.
Sep 07, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
How do you set the temp. On the magic chef 45 bottle cooler
www.mcappliance.com
You can find user manuals for all appliances. Press set for 2 seconds till it beeps then usethe arrows.
Aug 03, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Temperature setting doen not work
rsteiner10,
Welcome to Fixya.
You said, you have the Magic chef wine cooler and it is not cooling. I unplugged it when the temp was reading 78 degrees!!! It was cooler to unplug it!! Does anyone know where you can get this repaired?
here in our fixya site there are serviceres from all round the country.
click on Browse the Repair Directory an you may find a serviser in your area.
Thanks
let me know you found some one!
Huuum
Please remember to leave me a rating before you leave me!
Oct 03, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
I have a magic chef wine cooler (Model MCWC50DBT) and the labels keep falling off of the bottles. The temperature is set to red and we don't seem to have any other problems.
All the wine chiller set 2 temp red and white, red wine temp only for 18- 20 oC , your using white wine don't set red wine temp , set only for white temp mode,white and red wine set temp are different temp
May 27, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Magic Chef MCWC30MCG Compact Wine Cooler Logo
568 people viewed this question
Top Magic Chef Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Magic Chef Furniture Expert? Answer questions, earn points and help others
