Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Sub Zero 650 Refer with a Service light flashing- with what I believe is 40 EC refer temp is steady at 37 but freezer temp is rising
  • sean_toomey Feb 06, 2010
    Thank you- sub zero when I called told me to shut the breaker off for 15 minutes and see if that clears the code- I still have a call in for service for Monday- any further thoughts from you??? thanks,
    Sean
    Sergeant:
  • 198 Answers
Posted on Dec 02, 2012
    Sergeant:
    Champion:
  • 263 Answers
40-ec means your freezer is running too much and can not get cold. You should call for service asap.
Sub-zero refrigerator repair in orange county, ca
appliance repair orange county, ca
Posted on Feb 06, 2010
Freezer not functioning properly
I believe you need the Sub-Zero Service Manual to answer your questions. Your model is listed in the manual which explains how to cause the forced defrost electronically. I believe it is done through the keyboard as defrost on your refrigerator in electronic and not done with a typical defrost timer that you will turn. I may be able to answer a few of your questions, Thanks John Tripp Appliance 911
Feb 20, 2014 | Sub-Zero Refrigerators
"service" flashing also what seems to be an error
Service flashing- 1. Ice maker not working 2, Rise in temperature 3. Condenser needs cleaning
To Clean Condenser 1. Remove Grille 2. Brush with a soft brush 3. Vacuum being careful not to bend fins.
Jul 07, 2011 | Sub-Zero 650/SRH Stainless Steel
My Sub-Zero is flashing error code 36. What is this?
Diarmait --
Technical Service Manual for the SubZero 600 series can be downloaded at:
[https://docstore.fedex.com/subzero]
Username=subzero
Password=subzero
Write back if you still need help.
-- SWT
Aug 23, 2010 | Sub-Zero 650 / O Bottom Freezer...
Frost accumulating on back of fridge - service light blinking
YOUR EVAPORATOR IN THE FRESH FOOD SECTION IS LEAKING FREON. THIS IS COMMON WITH EVAPORATORS IN THIS AREA. 12 PART WARRANY OR 6 YEAR FULL ON THIS. SUB ZERO HAS SUPERIOR CUSTOMEER SERVICE AND MAY COVER FULLY IF OUT OF THE 6TH YEAR. 1-800-222-7820 CALL THEM AND ASK.
Apr 23, 2010 | Sub-Zero 650 / O Bottom Freezer...
Service light is blinking & code 06 EC flashes on Sub Zero 650
Turned the breaker off to the fridge for 15 minutes and turned it back on.
Jan 01, 2010 | Sub-Zero 650 / O Bottom Freezer...
Sub zero 650-display
If you cleaned out the condensor unit, your problem is probably a bad evaporator. Schedule a service call. If the condensor was really dirty then you may have just compacted the dust into the condensor in which case a shot of CO2 would be a good idea.
Oct 03, 2008 | Sub-Zero 650 / O Bottom Freezer...
Subzero model 650 refrigerator
If the light keeps coming back on and temps are rising in the refer section, then you most likely have an evaporator leak. Check to see if you see either a moist spot or ice on the back wall on the left side of the back wall of the refer. If you do, it's definetly a leak. Call a authorized Servicer.
Jun 08, 2008 | Sub-Zero 650 / O Bottom Freezer...
Subzero 690 flashing EC and service
Rhino, this is yet another simple fix. You need to call subzero and let them know that your ref section is not cooling properly. 9 out of 10 times it will be a problem with the evaporator coil needing replacement. Sub is aware of this issue and usually picks up the tab for this repair.
Mar 26, 2008 | Sub-Zero 632 / S
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
935 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
