Question about Electrolux Kitchen Ranges
Why did the Frigidaire stove EOC blow up and fry the traces and make big black marks by the big black switch on the circuit board.
I'm trying to figure this out too, the exact same thing just happened to mine today, 16Apr10...I'll repost here if i find a solution.
Posted on Apr 17, 2010
Frigidaire oven temperature unreliable.
Is this an electric oven? Sound like a bad breaker to me if it is.
Dec 22, 2016 | Frigidaire Ovens
Power surge made my Frigidaire stove show a F9 code
F9 is a door lock error. Sometimes when the power surges the door locks then unlocks. It is possible your door lock could actually be broken, however many times when the EOC fails, it will show an F9 when it should show F1. I would guess that your EOC (main computer board) is fried. Try unplugging it for 24 hours then press the door lock button once you plug it back in. If there is no error code when you plug it in but the error code comes back when you lock the door, you probably have a problem with the lock.
Jun 25, 2014 | Frigidaire PLEF398AC Electric Kitchen...
Our frigidaire stove or the oven is locked and it just keeps making this beep noise and the oven wont unlock so we really need help unlocking the oven and stoping the been noise thanks
The "F1" error code indicates a failure of the Electronic Oven Control or EOC circuit board. You may find the oven gets too hot, fails to respond to input or acts irregularly when the EOC is malfunctioning or broken. While this code usually indicates a need for repairs.
Read more: How to Troubleshoot a Frigidaire Oven F1 Code ' eHow.com http://www.ehow.com/how_10004808_troubleshoot-frigidaire-oven-f1-code.html#ixzz2EhW21T4n
Dec 11, 2012 | Ovens
Frigidaire Oven Error F1, what caused it?
Hello - From my research part number: 318184400 (clock) seems that it has not yet been updated and still the same part number for the MSRP: $163.04. Part can be purchase directly from the manufacturer or a part distributor in your area (part could possibly be different with them). Typically error code F10 could indicate a variety of issues. The range could possibly have a runaway temp (higher than normal temps), shorted keypad, faulty EOC (Electronic Oven Control) or, display wire harness missing/not connected. Usually, this code means to replace the EOC. You may be able to reset the range by disconnecting the power to the unit for up ten minutes. Usually this will clear most false error codes. You can disconnect power by either unplugging the unit or flipping the circuit breaker off and back on. If resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
Oct 24, 2012 | Frigidaire Ovens
My stainless frigidaire professional series electric stove oven door is locked...i did not self clean it, but it is locked somehow...if i hold either the lock button, or the clear/off button for 15 seconds...
F1 is an EOC (electronic oven control) failure. The control is expensive. But before you go and buy this board, you need to find a diagram to see of this model oven lock is controlled by the EOC or by a micro switch. If you have a lock button on the board the you have to replace the EOC.
Mar 24, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire Stove beeping F1,How do repair this?
The f1 code means that the EOC (Electronic Oven Control) failed. You need to replace the EOC board.
Good Luck And Please rate
Sep 10, 2009 | Frigidaire FES367 Electric Kitchen Range
F6 ERROR CODE ON MY FRIGIDAIRE STOVE.
dagadier
We may be able to repair your EOC, what are the symptoms?
- www.fixyourboard.com
Jul 25, 2009 | Frigidaire PLEF398AC Electric Kitchen...
Power went out. Back on now, monitor won't show on range. Can't set clock, so my stove won't work now. Any suggestions?
HI, you will need to replace the EOC/clock. the power surge has fried the chip set. Replace the control board.
Jun 22, 2009 | Frigidaire FEB27S5A Electric Single Oven
Instructions for frigidaire oven
Thanks for the question. remove the back panel. first cut the power to the stove .remove the clips that hold the board, install new one. install the wiring on the new one. thanks the appliance doc.
Sep 27, 2008 | Frigidaire FEF366 Electric Kitchen Range
Kitchen Ranges Logo
293 people viewed this question
Top Electrolux Kitchen Ranges Experts
Mike Henne
Level 1 Expert
Dominic
Dominic
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
