Question about True Pizza Prep - TPP-67
My true TPP-57 is not blowing cold air. compressor runs for a minute or so and shuts off.
4 Suggested Answers
  • 1144 Answers
SOURCE: GE Refrigerator external fan - air flow?
This really depends on the manufacturer and their preference on design. First, the fins at the compressor are part of the condensing coil. Most all makers have air pulled into the condenser coil and blown across the compressor. You should be moving room temerature air across the condenser and the air from that is usually then moved across the compressor.
Hope this helps clear it up .
Posted on May 09, 2009
bobicehouse
  • 1524 Answers
SOURCE: My True refrigerator turns on,
Change compressor starting components
Posted on May 25, 2011
  • 488 Answers
Change Start Relay For Compressor, if it will not help, most likely you will need compressor itself
Posted on Jun 10, 2015
What can i get wiring diagram for TPP-67 pizza table?
TRUE TPP-67 SPECIFICATIONS Pdf Download. - ManualsLib
www.manualslib.com > ... > True Manuals > Kitchen Appliance > TPP-67
True TPP-67 Food Prep Tables: Specifications. TPP-67 ... TPP-67. Solid Door Refrigerator. TPP-67. True's pizza prep tables are ... Heavy duty PVC coated wire.
Aug 06, 2014 | True TPP-67 Commercial Refrigerator
Why is my air conditioner not blowing cold air
Good Afternoon Friend,
I understand that your Frigidaire air conditioner, model# FAC107P1A, comes on with the compressor running, but the air is not cold. First, check to see that the temperature sensing element, located behind air filter, is not touching a cold coil. If it is, straighten the element away from the coil. Secondly, try resetting to a lower temperature. Lastly, the compressor may have shut-off by changing modes. Wait approximately 3 minutes and listen for compressor to restart when set in the COOL mode. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 10, 2014 | Frigidaire FAC107P1A Wall/Window Air...
Air Conditioner
Someone will need to find out if the compressor clutch is failing, or if it is loosing power due to a pressure switch or other problem.
A faulty relay or switch could get hot and switch off power to the compressor.
Aug 03, 2012 | 2006 Nissan Altima
Ac blows cold then hot air
Is the compressor running when it blows hot air ?
Jul 31, 2012 | GMC Sierra 1500 Cars & Trucks
Danby DB98-26786A window air conditioner will start up and blow cold air..frost forms on the tubes..after a few minutes the frost disappears and the compressor shuts off .. the fan still blows; but no...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 23, 2011 | Danby Heating & Cooling
I have an RV with a duo therm rooftop air conditioner... when i turn the air on.. the compressor will run for a few minutes.. it blows cold air and then the compressor shuts down. Low freon??
Quite possibly low on refrigerant. Sounds like a pressure switch is shutting the comp. down after it pumps down for a few minutes. Someone will have to check the refrigerant with guages if you don't have any of your own. There should be ports to connect a set of guages near the compressor under the cover.
Apr 13, 2011 | Dometic Rooftop RV Air Conditioner
Compressor will not stay on.
very good possibility that it is low on freon. If indoor unit is blowing ambient air, not cooling is happening. If this is the case and you are sure the compressor is running and then shutting off, the compressor could be overheating and the internal overload is taking out the compressor. If outdoor fan runs and compressor runs, probably cause. If capacitor is bad, unit would most likely not run that long. While unit is running, feel the large line at the condensing unit. If it is cold, and stays cold, could be something else going on. If stays warm, most likely low on freon.
Apr 19, 2010 | Intertherm P3RA-030K Air Conditioner
Have duo therm
Hi, You are getting low on refrigerant. The A/C cranks up, vaporizes all of the refrigerant available to it and the compressor shuts down. The fan continues to run.
Best regards, --W/D--
Aug 04, 2009 | Dometic Rooftop RV Air Conditioner
1998 Volvo V70 A/C Intermittent
I had exactly the same problem. When your engine is cold and off check the gap on your ac compressor with a feeler gauge, it should be between 0.3 and 0.5mm. If it is larger you need to re-shim which invloves undoing a nut on the end off the compressor and removing the clutch plate, then removing the appropriate shims (look like washers) then replace. The reason it blows warm after 10 minutes or so is because the ac compressor gets hot and the clutch gap gets too large for the electro-magnetic clutch to engage. Some people would say that you need a new compressor but all you need to do is a re-shim.
Mar 01, 2009 | 1999 Volvo V70
True Pizza Prep - TPP-67 Logo
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
christian nielsen
Are you a True Refrigerator Expert? Answer questions, earn points and help others
