Question about Husqvarna Viking 1
Threading the emerald 183 - Husqvarna Viking 1
  • 371 Answers
SOURCE: my husquavarna Emerald 183 ights up when turned on
sounds like an overload of some sort. Suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
If you bought the machine new the warranty may still be in effect.
Posted on Feb 14, 2010
  • 371 Answers
SOURCE: the bobbin thread is bird nesting on my viking
Make sure the bobbin is extended out of the bobbin case via the tension spring mechanism in the bobbin case. This provides tension for the bobbin unit. Check to make sure the upper thread has not "jumped out" of the take-up lever so that when the needle first touches the fabric the thread is still taunt and when the needle enters the fabric a small loop is formed right above the fabric and the eye of the needle. If these tips do not help suggest that you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
  • 371 Answers
SOURCE: the bobbin is bird nesting on my viking emerald
Check that it is threaded correctly (both top and bottom) making sure that the upper thread is in the takeup lever and the bobbin is guided through the tension spring in the bobbin case. Watch the needle as you slowly turn the handwheel counter clockwise (toward you) and the needle point touches the fabric (make sure presser foot is down). Is the thread still relatively taunt? If it is loose, the upper thread tension unit does not have enough tension. Check the areas where the thread goes and make sure you remove any loose threads or fluff which could be inhibiting the tension discs from closing over the thread. If the tension unit still is not tightening enough, the tension unit may need to be replaced or the circuit board replaced. If everything is ok in the upper thread area, now look at the bobbin area. With no fabric, watch as the needle enters the bobbin area. Does it go down and the upper thread catch the bobbin thread and pulls it to the surface? Check for anything preventing the bobbin thread from being pulled up to the surface through the needle plate. If you have still not been able to resolve the problem suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
SOURCE: husqvarna viking emerald 183 - horizontal bobbin
I know the answer is a little late now...
I bought the machine a month ago and find that the bobbin picture is a bit misleading... i find putting the bobbin in the case, pushing the thread down over the hook thing (like in the picture) but then cutting the thread really short and putting the plastic cover on seems to work!
it is actually vary easy once you get the hang of it!
Posted on Feb 16, 2010
SOURCE: where can i purchase a foot pedal for my husqvarna
Check your local sewing machine repair store. Sometimes when a machine can't be repaired, they ask to keep the parts and sell them as used.
Posted on Mar 07, 2010
Self threading
first make sure your needle is fully seated in the needle bar.
Jul 18, 2012 | Husqvarna Viking 1
Husqvarna model 183 foot control no power
anytime the machine does not respond like it's suppose to then it needs to be checked, the foot pedal could have gone bad, or the the sewing machine plug where the foot pedal goes may have gone out
Mar 27, 2012 | Husqvarna Viking 1
Thread easily pulls out of fabric. Viking emerald 183 machine
You don't have the machine threaded correctly, make sure the thread is seated in the top tension, between the disc
Aug 13, 2010 | Sewing Machines
I have an Emerald 183 sewing machine.The bobbin thread is too loose. I can pull the top thread out no problem. I tried rewinding the bobbin thread, changing the needle and I do use the right settings for...
Clean any tangles from the bobbin area.
Always thread a sewing machine with the presser foot up so the thread can properly seat into the tension control.
Hand walk a few stitches to see if the thread still feeds too fast from the spool.
When thread pools (falls off the spool) a thread net will help - you can get these at a sewing machine dealer. I use to find them at fabric stores, but have not seen any lately with sewing/serging notions.
Mar 19, 2010 | Husqvarna Sewing Machines
Stippling for Viking emerald sewing machine
The switch in the back will lower the feed dogs.
If you need a manual - I found a PDF download by googling: viking emerald 183 manual
Feb 23, 2010 | Husqvarna Viking 1
My husquavarna Emerald 183 ights up when turned on but will not ''go''. I followed everything the manual said to do ie remove bobbin, plates, clean out any lint or threads etc then put it back together -...
Feb 13, 2010 | Husqvarna Viking 1
The bobbin thread is bird nesting on my viking emerald 183. i've only had one sewing class so far. how do I insert the bobbin correctly?
Jan 30, 2010 | Husqvarna Viking 1
Husqvarna viking emerald 183 - horizontal bobbin difficult to thread properly; any tips or how to?
Dec 28, 2009 | Husqvarna Viking 1
The bobbin is bird nesting on my viking emerald
Good luck.
Nov 15, 2009 | Husqvarna Viking 1
Sewing Machines Logo
57 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
