I need wiring diagrams to connect the timer in a Hoover Premier 510 washer
  • atobin13 Feb 06, 2010
    I need a washing machine expert , not a refrigeration expert.
  • jody cole Feb 27, 2012
    i wondering if you found out how to connect the timer
    Top Expert:
  • Washing Mach... Master
  • 80,637 Answers
Hoover premeir washer diagrams
Posted on Feb 07, 2010
  • 4,070 Answers
Your model number is needed for more information.
It's usually stamped on a small tag in a visible location on your appliance.
Refrigerator-
Behind the lower toe kick-plate, Behind the lower crisper drawer, On the face frame of the refrigerator body, Inside the refrigerator of freezer on the left or right side wall.
OVEN look on the back side of the door at the bottom or edge. On the vent trim behind the center of the door.
Washer-Dryer- behind or on top of the control panel. Behind the door. On the lower front or side of the cabinet.
Dishwasher- Inside the doorjamb on the top, left or right. On the door edge top left or right. Portable models on the back.
Microwave- on the face frame behind the door or on the back.
Posted on Feb 06, 2010
  • Charles T Nevin
    Charles T Nevin Feb 07, 2010
    I am also a washing machine expert on Fixya. But regardless of that anyone will need to know what kind of machine you have(model number) to look up parts and diagrams.
Hoover 210 A6952 washing machine... one loose wire at timer.
If you email Hoover with your product details & the timer details as above they can have an engineer contact you via email or phone, or most have an online live chat service which has engineers who can answer your problem in minutes.. Truly hope this helps & your problems are soon resolved..
ps you could google the part number & find images on the item that will show you the wires in situ, this may solve the issue for you as well...
Feb 21, 2018 | Hoover Washing Machines
How to wire timer on hoover dryer ?
there should be a wiring diagram in the back right hand of dryer,
Oct 21, 2010 | Hoover Dryers
Washer spins out but will not fill or agitate
You most likely have a bad timer. If machine is filling properly, then the switch is bad.
Servicing the Timer
Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by hand.
Step 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.
Sep 03, 2009 | Kenmore 24032\24036 Top Load Washer
User manual needed for Hoover washer/dryer
Hi.
In you browser box type in Hoover user manual.
Then scroll down to Hoover after sales service instruction manuals.. Click on this, and then on Laundry.then on Waher -dryers, follow instructions
You will find your model listed there,.
Please leave good feedback.
Thanks
Nov 29, 2008 | Hoover Washing Machines
Whirlpool duet washer f-27 code error
hi Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Nov 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer kenmore elite he 4 t
HI Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Oct 16, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore ultra fabric care heavy duty washer 80 series
Sep 13, 2008 | Washing Machines
I need to know how to replace the timer-mall on my Amana washing machine model #ALW780QAC
hi here steps Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Sep 12, 2008 | Amana Washing Machines
Hoover 700LB top loading washing machine
there should be a wiring diagram on board in an envelope or taped somewhere you can get one from sears too
Dec 09, 2006 | Hoover HTC243 Top Load Washer
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
