Question about Dryers
Runs but will not heat up to dry the cloths. it takes 8 to 10 hours to dry them. what to do? it only gets just a little warm!
  • Dryers Master
  • 8,220 Answers
It could be the heating element, a safety limit, a loose blower wheel/clogged with fluff, a control problem, or an electrical problem. A heating coil is used to warm the clothes as they get tossed gently inside the drum. A blower mounted on the motor pulls air through the heating element into the drum and out the exhaust. Give the dryer and the vent a good Hoovering. The element gets old and brittle with use and eventually needs replacement. That is what you check first. On gas dryers vibration and age will cause the ignitor to crumble and fail. If it turns out the element is fine then one of the safety's might be blown. These safety's are set to a certain temperature
for the dryer to operate safely. The drum temp control for cotton is 160f. A limit on the heater housing is 250f. If it fails another smaller limit is mounted nearby that blows at 300f. If that temp exceeds 350f a duct fuse mounted on the blower housing opens and kills most dryers. On gas dryers the duct fuse will kill the gas assembly but the dryer will still run. If all of those safety's are good the timer could be the problem. The timer has a terminal on it that runs down to the heating element. If you suspect it is bad you can check it with a meter. That leg of the timer should have continuity with other terminals on the timer at different spots on the timer. Turning the timer and checking for continuity will give a clue. If you cannot get continuity with any other terminal on the timer at any position on the dial then you have a burned contact in the timer. If that turns out to be good, you would need to inspect the electrical outlet for proper power to the machine. On American models the motor runs on 120 volts but the heating element must have 240 volts. If you have more questions just post a comment. Good luck on repairing your machine. I have some repair photos: HERE
Posted on Feb 06, 2010
Wrinkles clothes terribly. Solutions.
Check your settings on your dryer. See if it's on a longer duration of time to dry. Dryers have different wording depending upon the make and model. If you're trying to dry smaller loads the heat settings s
does not have to be set for very long. Heavier, loads with thicker clothing will need to dry a little longer. When you take the clothes out of the washing machine, do you shake the clothes before putting them in the dryer? And do you use dryer sheets? Believe it or not, they're not only used to help make your clothe's smell fresh but they also help elevate static and a few wrinkles.
Mar 23, 2015 | Washing Machines
Only gets warm and takes hours to dry
Could be a defective heating element.
Mar 02, 2015 | Dryers
Have a whirlpool cabrio gas dryer. It takes several hours to dry one load of clothes. The clothes seem to stay damp towels may take all day... what could be the problem
Have you opened the door while its running to see if its warm inside (heater working) If its getting warm and still not drying the clothes properly you likley have a air circulation concern. With the unit running check the exhaust vent outside from dryer it should have a good flow of warm air, if not you have a restriction sowher between the unit and outside. Heat alone will take forever to dry clothing,you need good air circulation to remove the moisture from the clothes otherwise all you will end up with is warm moist clothing.This generaly happens over a long period of time and then all of a sudden you realize the dryer is not working like it use to..Hope this helps you with your concern.....
Aug 09, 2010 | Whirlpool Dryers
Whirlpool Electric Dryer LER 7648PQO (hardly used) is not drying clothing. Clothes are being heated as they are warm when you open the door and feel them but after hours the clothing is still wet. I have...
Still sounds like you have a restriction in the duct work going outside. check again with unit running for good airflow at outside vent. What you describe is what happens when you dont have good air circulation you end up with warm moist clothes,you need more than heat to dry clothes you need the air circulation to take away the moisture.....
Aug 07, 2010 | Whirlpool Dryers
There is a lack of heat. It gets a little warm
Please ensure that the venting from the dryer to the outside of the house is clean and free of lint.
Ensure the venting behind the dryer is not kinked.
Long time to dry issues are usually caused by restricted venting to the outside.
Since you have heat this may solve the problem.
Jan 13, 2010 | LG DLE2516 Electric Dryer
Kenmore Gas Dryer Model # 97281800 - will not turn on. The dryer will not turn on, does this machine have a Fuse?
kenmore 97281800 drum turns good ,all vents are clear,only blows
very little.take the cover off blower compartment blows a lot.only warms the cloths. runs very well just does not dry. WHY does the blower not blow very much when its all together? is that the reason the heat cycles mostly off? three hours to dry a well wrung out load
KEN
Dec 23, 2009 | Kenmore Dryers
Take too long time to get cloth dried
how much are you putting in ? Is it a 220 volt dryer? May have a dead line (electris) to heating coils, or thermaostat is not functioning and letting the dryer coils get to operating temperature. Your heat setting control may be faulty. I wouls look at heat control first.
Jul 02, 2009 | Frigidaire GLER341A Electric Dryer
Maytag dryer barely gets warm
Is your vent stopped up? Or your lint screen? Usually an element will be all out, not just a little.
Apr 13, 2009 | Dryers
Dryer Run too long
MAKE SURE YOUR LINT TRAPS AND DUCTS ARE NOT PLUGED.EASY REPAIR.YOU CAN DO IT.
Jan 16, 2009 | Maytag PYE2300AY Electric Dryer
Dryer heats up but isn't drying properly
yes it does something is blocking your vent either its all coiled up behind the drier or something i need to ask a few questions go out side and look at where your drier vent has a hood make sure nothing is blocking it from opening it has a little round door on it ive seen some that have little plastic screens on them that gets clogged the screen is there to keep critters from building nests in the vent line then get a flash light and look over the back to see if the vents folded over mashed etc to find out if its a vent problem take your vent loose dry a load and see if it goes back to normal if all that's ok get back to me and we will clean the drier i need to know if your lint screen is on top or in door and your model #
Jan 02, 2008 | Dryers
Dryers Logo
21 people viewed this question
Top Dryers Experts
