Question about Kenmore Refrigerators
My ice maker only makes 1/2 of the cubes and the water only dribbles out of my door
  • 4,070 Answers
There is a mesh screen filter in the water line where the water supply connects to the water inlet valve on the back. It may be stopping up with sediment. Cut the water off under the sink and take the line off the valve to inspect and clean the screen.
OR take the line off on the other side of the valve to see how the water flow is when you try the water dispenser. Left side usually goes to the dispenser.
Posted on Feb 06, 2010
  • 572 Answers
Change your water filter
4 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: Water is not geting to the ice cube maker, it is
Look inside the water tube to the icemaker. It may be frozen. If so, thaw it out.
If not frozen, replace the water valve.
Posted on Mar 19, 2009
  • 142 Answers
SOURCE: water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Posted on Jun 02, 2009
Sea Breeze
  • 4655 Answers
SOURCE: freezer won't make ice cubes, but does provide cold water.
The water and ice maker are two seperate water control valves built onto the same. Your water control valve for the ice maker may be defective and require that you change the set. Fill ice maker with tap water and allow the water to freeze. If the ice maker dumps the ice into ice bin and then does not refill then this points to the water control valve. If the ice maker does nothing after water freezes then the problem is the ice maker. Send me a model number and I will look up the part numbers for you, Thanks, Sea Breeze
Posted on Jul 08, 2012
Water collecting in the water compartment
what is question as well as make ,model of unit
Nov 13, 2016 | Refrigerators
Why is ice maker making small cubes?
Low water pressure can make small cubes.
Feb 14, 2016 | Refrigerators
Freezer won't make ice cubes, but does provide cold water.
Jul 08, 2012 | Frigidaire Refrigerators
Low water pressure in ice maker and water dispenser I changed the filter but water just dribbles out of water dispenser and ice maker makes hollow cubes
Make sure the water line to the back of the fridgeis not kinked.Ifit is replace it. Hope this helps,If so give us a 4 thumbs up. THANKS
Mar 02, 2011 | Maytag MSD2758G Side by Side Refrigerator
Not making ice cubes
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jun 08, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Water works on door but ice maker isn't making ice occasionally hear noise like trying to dump ice cubes but no ice
the water valve located on the back of the refrigerator that the water line is connected to could be bad. if no water is coming to the ice maker then it shouldn't have any ice or water in the ice mold. if it is empty you can try pouring enough water in the mold to make ice cubes. wait an hour or so and see if the ice maker dumps the ice. if it does you probably have a bad water valve.
if your ice maker has ice in it but had been making small cubes you should check to make sure you don't have a jam. small cubes could be from low water pressure or a blockage. if your refrigerator has a water filter it may be time to replace it if the water dispenser water pressure is also low.
May 28, 2010 | Hotpoint HSM25GFRSA
Maytag msd2356ae ice maker will only give me hollow ice any ideas.
Hollow ice cubes are most often cause by insufficient water supply. Icemakers fill for about 7.5 seconds, resulting in about 4.75 oz. (140 cc) of water into the ice cube mold. If there s not enough water pressure available at the fridge, cubes may end up hollow and/or the fill could continue to dribble, eventually causing the fill tube to freeze closed.
pls rate my suggestion.........
Jul 25, 2009 | Maytag MSD2454G Side by Side Refrigerator
Water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Jun 02, 2009 | Frigidaire FRS26R4A Side by Side...
Ice Maker frost and freeze where ice drops into refrigerator door
You need a service guy to look at it. It could be water leaking or a simple case that the flap isnt sealing and the ice melts and then freezes the flap open
May 14, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
NOT MAKEING ICE CUBES
well 9 1/2 times out of ten it is the ice maker i recommend you shop for a new ice maker... whirlpoolpartssurplus.com can get you a real good discount and free shipping...call them
Apr 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
51 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
