Question about Whirlpool LER5636P Electric Dryer
Whirlpool dryer I have a used whirlpool dryer my outlet is 3-prong and the dryer is 4-prong. Do I need to switch the 3 wire to 4 wires?
No go to a home store like lowe's home depot or others ad buy a switch kit
Posted on Feb 22, 2008
Switch the 3 prong cord to a 4 prong on my whirlpool duet sport, 9 cycle
Hi mybabycamero
Go to the following webpage and you can see how to convert your 3 wire to a 4 wire dryer.
Please take time to rate me
Bud
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Oct 17, 2012 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
I need to put my 4 prong cord onto my whirlpool duet dryer
Hi mybabycamero
Go to the following webpage and you will see how to change your 3 wire into a 4 wire dryer.
Bud
I am trying to change my miller welder 4 prong plug to qa 3 prong to match my dryer outlet ? which wire goes where ?
On 4 wire outlets the neutral and ground wire were seperate on 3 wire the ground and neutral are combined so hook up the 2 hots (black&red) as before on the 2 outside terminals and combine the green and white together onto the center terminal
Nov 12, 2011 | Whirlpool LER5636P Electric Dryer
Just moved, the dryer has a 4 prong plug and house has 3. Should it replace plug to dryer to 3 prong or house plug?
Buy a 3 wire cord and install it on the dryer. Hang onto the 4 wire one in case you move again.
Aug 28, 2011 | Whirlpool LER4634J Electric Dryer
I have a four prong clothes dryer plug that needs to go in a three prong outlet - 220v. Any ideas?
It's either you convert the 3-prong outlet to 4-prong or the 4-prong cord to 3-prong. But the latter is easier and more feasible. Unplug the dryer then disconnect the 4-prong cord from the dryer. Note that it has red, black, white, and green/yellow wires but sometimes the red and black wires are both replaced by same color wire, usually gray. The red and black wires are lines L1 and L2 reversibly, meaning they can switch places, while the white and green/yellow wires are the neutral line and ground, respectively.
Get yourself a 3-prong cord and note that it has red , black, and white wires but sometimes, like the 4-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect these 3 wires in the same manner they are connected as 4-prong cord to the terminal block. The wire strapped to the dryer cabinet and connected to the green/yellow wire of the 4-prong cord wire is now left hanging. The last step is to connect this hanging strap wire to the same terminal on the terminal block (center) where the white wire (neutral) is connected and it's done.
It can be observed that converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3. On the other hand, converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4. The link below might enlighten you further on this matter.
Electric Dryer Prong Conversion
Aug 20, 2011 | Maytag Dryers
I have a dryer with 4-pronged plug and just moved to a home with a 3-pronged outlet. Can I buy a 3-pronged cord to use with my dryer?
Yes, you can convert your 4 wire to three wire.
Go to the following website for the way to hook it up, it is easy.
This is a free answer, Please rate me
Oct 16, 2010 | Whirlpool Dryers
Moved and the new place has a 4 prong outlet. i need the wiring diagram to switch from 3 prong to 4 prong power cord
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Sep 03, 2010 | Dryers
Front loader whirlpool dryer (04') 3-prong cord; 4-prong outlet..
You'll need to get a new 4 prong cable. Connect wires as color coded now and connect the green to the frame.
Jul 16, 2009 | Whirlpool GEW9250P Electric Dryer
Kenmore series electric dryer need to replace 3 prong w/4 prong
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If you still have questions, please let me know. I hope this helps you.
Feb 15, 2009 | Kenmore 62802 Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
106 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
