Question about RCA Audio Players & Recorders
Fix for RTD206/RTD207 which says ''open''
Fix for RTD206/RTD207 which won't play and displays ''Open'' when disk inserted.
Mine did the same thing. When I put the disk in it said loading for a few seconds then said ''open''. I fixed mine and its playing great now. I went through the trouble of taking the whole drive out (something I don't suggest anyone else do because it turned out to be totally unnecessary) to test the two motors and clean the lens. As it turned out, both motors spun when put under the appropriate current and the lens wasn't the problem. Hmmm...I thought to myself. Here's when I accidentally figured out what was wrong. I PUSHED THE LASER ALL THE WAY UP THE TRACK UNTIL IT WAS AS CLOSE TO THE MOTOR WHICH SPINS THE DISK. I didn't do this on purpose, I was just in there messing with stuff one last time before giving up, but this time when I put a disk in it worked. Just to make certain this was really the problem I tried moving the laser back and it quit working again. Apparently, unlike a lot of other drives the laser doesn't return automatically to the starting position when the system starts. Bad programming on the drive's board in my opinion.
1. Unplug the system (seriously) if anything metal (like a screwdriver) falls and touches junk on the main-board it could toast the whole system.
2. Open the top of the case up. There are six small screws on the back and 2 big ones on the sides which need to be removed.
3. Locate the drive and remove the 3 screws on the metal plate over the drive. Let this dangle over the back (don't set it on the main-board). It's connected with a cord to power the little LCDbut you don't have to unplug this.
4. Push the laser all the way to the center of the drive near the spindle motor (the one that spins the disk).
5. Put the plate back in place. Its got the top spindle which holds the disk in place. You can't test it without this.
6. Plug in the drive being careful not to let anything touch the main-board and test that ******.
7. Assuming everything's good re-assemble using steps above.
Good Luck! I hope this helps. I guess next time we should all be a bit more discerning when buying a home theatre for $89 bucks at target.
  • 125 Answers
SOURCE: LSQ9549LWO WHIRLPOOL WASHING MACHINE TOP LOAD NO SPIN @ RINSE CYCLE
You could have a bad lid switch or the hinge may need to be bent to make better contact with the switch. If your washer has a oval cut out on the right side and an actuator on the rt side of the lid... the next time it acts up don't open the lid and turn the tub, simply push down on the rt side of the lid, if it starts to work replace the lid switch. If there is no hole or actuator on the rt side, then the lid switch is on the back left corner, when you open and close the lid you should hear a click. If you don't hear a click or if you hear it when the lid is almost closed you need to adjust the hinge. There are 2 screws on the back of the endcaps on the control panel remove them and flip up the control panel, use a screwdirver to pop out the spring clamps on the rt and lt sides of the top panel. approx 3-4 inches from the sides. just insert the tip into the front most part of the clamp and pry back. unclip the lid switch, and pull the cabinet forward. You should be able to bend the hinge a little so it makes better contact with the lid switch. hope this helps.
Posted on Aug 22, 2008
SOURCE: cd's skip
all the rca's have been released without quality control... you will have to open and adjust the potentiometers (the adjustible resistors on the main board) to re-calibrate the laser timings. However the way that the boards are mounted inside the boombox's chassis you will need to take apart everything to be able to reach the main board (inside vertical right side board with large heatsink and fan) without causing a short (as to be able to properly adjust these you need to have a cd playing and the whole thing needs to be upright.
I would recommend throwing it all way, not worth the time if you don't have the patience.
Posted on Oct 15, 2008
SOURCE: I replaced the laser on my wii, now the disk won't spin
did u remember to desauder the antistatic point on it n make shure u grease up track that lense moves on n make shure its lined up perfictlyhope that helped
Posted on Apr 25, 2009
  • 51 Answers
SOURCE: games wont play. Problems with Disk player
If you don't have the tools to open your 360 go to best buy or an office supply store and get a can of compressed air and blow the dust out of the dvd drive. If that doesn't work then the lens needs to be cleaned with a q-tip and alcohol. This has worked for me on numerous occasions.
Posted on Jun 01, 2009
  • 107 Answers
SOURCE: Hitachi DS18DL drill quits under load
sounds like your battery is either shorted out or out of charge
Posted on Jun 22, 2009
The open disk will not open the disk drawer
Try to force drawer open it could be jammed, if not it is possibly a bin job
Jan 27, 2016 | RCA RTD207 System
DVD ' s tray won't open when pres OPEN, DVD is inside
There are little gears to open the tray with a little rubber belt that drives it you should be able to open door and pull on tray to get disk out if not unplug it take top off push tray out Cheapper to replace player than to fix but little flap should pull down grab tray and pull
Feb 21, 2013 | RCA DRC247N DVD Player
Rca rtd206/207 disk will not spin, goes from loading to open everytime.
It is called the pladder motor, causes no B+ to the motor "5volts" the pladder motor is defective, or the laser pickup is not in sync with the pladder motor.
May 05, 2012 | RCA Televison & Video
My CD player keeps displaying no disk and wont play the cleaner disc, is something dirty or broken?
Hello
If it does not play the cleaner disc, just inspect whether the disc inserted in spins inside it. You can check this by open the upper cover of the player, and inserting a disc into it. If inserted disc spins inside, and the player won't read it, the fault is with its laser pickup unit, and it should be replaced with same type and number.
If the disc dos not spins, the fault is with the sled motor [the motor that spins the inserted disc], has damaged, and should be replaced. OK.
Dec 25, 2011 | Sharp Audio Players & Recorders
RCA RS 1285 5 disk audio system won t show or play
When you turn on the unit the cd draw seams to open. I hear it making a noise like if it is trying to get ready to play. When you shut the draw it won't play, change tracts, or the disc thing to put in more disc wont work. Someone please help me
May 01, 2009 | RCA Audio Players & Recorders
Dvd burner won' eject dvd
On the front of the burner there is a pin hole. Take a paperclip and unfold it so it's a point. Stick it in the hole and it should open the tray. This should FixYa!
Jan 27, 2009 | Lite On LDW-401S DVD+RW Burner
RCA RTD206 HOME THEATRE
This is an indication that the optics are either dirty or failing. Carefully open up the unit and clean the lens using a cotton swab and alcohol. That should resolve the problem. If not, try playing a music CD. If the CD plays but a DVD does not, the optics are failing and need to be replaced.
Dan
May 22, 2008 | Audio Players & Recorders
Rtd207
There may be something blocking the path of the dvd drawer. Take a peek inside. You might also try very gently shaking the machine. Do you have kids who might have shoved something in there?
Mar 18, 2008 | RCA RTD207 System
RCA home theature RDT206
You can attempt to open the unit and see if there is a disk stuck in the unit. Typically there will be 2 screws on each side and a couple on the rear holding the top on the unit. MAKE SURE YOU UNPLUG IT BEFORE YOU BEGIN!!!
Jun 09, 2007 | RCA RTD207 System
90 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
