Question about Whirlpool Duet GHW9150P Front Load Washer
Screeching sound from dryer - Whirlpool Duet GHW9150P Front Load Washer
  • 572 Answers
Rollers might be out
Posted on Feb 06, 2010
My Bravos dryer makes screeching sounds during use, what could it be?
how handy are you,its a pull apart job not a hard job to do,but if your not let me know I can give a lot of help,or look here
https://youtu.be/CIyXnH8y3Zw?t=37
Sep 25, 2017 | Dryers
I have a stacked Frigidaire FEZ831CA washer/dryer combo and when running the dryer it makes a very high pitched (AND LOUD) screeching sound. Any ideas as to what might be the problem? Thanks, Sean
screeching sound
Sean, Bad felt gasket body to drum, if belt drive on dryer, it could be worn and slipping, making a screech, or if not the belt, the drum may have a worn bearing on its hub allowing it to run crooked and rub where it should not.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Disassembling reassembling stacked clothes dryer
Frigidaire Stacked Laundry with Noisy Dryer
How to Replace an Electric Laundry Center Dryer Drive Belt Kenmore...
Mar 29, 2016 | Frigidaire Washing Machines
Dryer screeches than stops cycle. Now doesnt work
I would bug them until they fixed it. You got sold a bill of goods. In other words avpiececof junk. Your bearings are burned up. You should ask for your money back if that is in the clause. Hold on to your paperwork and get copies made. I hope you didn't pay but 50-75 dollars.
Feb 28, 2013 | Frigidaire Dryers
Screeching sound coming from Maytag dryer. Blower wheel, motor?
Probably bad motor if dryer is shutting down after few minutes of operation
Aug 27, 2017 | Maytag PYG2300A Gas Dryer
Hi my Frifidaire dryer model number feq1442es is making a metal screeching noise somtimes when it is running
With frigidaire, more than likely the rear bearing is going out on if it the screeching sound is happening. the part number for that is 131825900 and will run you about $3.00. Go to apdepot to order the part if needed.
Oct 31, 2010 | Frigidaire FEQ1442ES Electric Dryer
Obnoxious screeching sound when the drum turns. Short consistent screech on revolution, which turns into one long non-stop screech. Stops after 45 seconds or so, then starts all over again with longer...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Sep 05, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Dryer screeching and grinding when running
Hi !
The drive belt has become old and hard.
Just change the drive belt and all will be well.
Please don't try to lubricate the belt as may be suggested by many as cheap quick fix.
Regards
Berry.
Feb 01, 2010 | Whirlpool Dryers
Screeching noise until dryer heats up. After the dryer has run for about 5 minutes, the screeching stops.
Sounds like you have a dryer drum belt that's getting bad. Once the belt gets warm enough, it becomes more soft and pliable, lessening the noise. Needs to be replaced. Hope this helped!
Nov 08, 2009 | Dryers
Screeching Kenmore front loading dryer
There is a hub and bearing that needs to be replaced you will need to have this serviced by a qualified tech. The whole front of the dryer has to come off and the basket needs to be removed.
Jan 05, 2009 | Kenmore 94872 Front Load Stacked Washer /...
Whirlpool Duet GHW9150P Front Load Washer Logo
124 people viewed this question
Dan Webster
Dan Webster
Sal De
