Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
I have a new D40 and I have had the same problem twice already on two separate occasions. I go to click to take a picture, and it does not take. Nothing happens at all. I try again and nothing happens. I try to refocus, but it does not help. I have to turn it off and on again to get it to work and click to take the picture. Thinking of if I should get the D3000 instead. Any thoughts on that and why this happens?
  • debbie326 Feb 07, 2010
    No, the battery is fine. I did some research and I am thinking that it is the autofocus b/c the d40 has 3 point autofocus. I think what is happening is that it is not focusing on something and then just won't take the picture. I am thinking of switching to the d3000 b/c it has an 11 point autofocus. I am a novice with cameras, so I really want it to be as easy as possible for the time being. Any insight as to this?
    Brigadier General:
  • 11,967 Answers
When the problem is happening, does the battery indicator show empty?
Posted on Feb 07, 2010
  • Ty Price Feb 07, 2010
    Most pros do not depend on any focusing scheme except spot focus. That way, while pressing the button half-way, they focus on the main subject and then re-compose the picture and press the rest of the way. Try it...
Nikon d40 flash won't fire
If it clicks when the flash is already open, it seems there would be a problem with the flash open sensor. The camera thinks the flash is closed, so it tries to open it again and it refuses to fire, because firing in the closed position would blow the bulb.
The D40 flash is a bit different, but if you open it (just unscrew the two little screws in front) you'll recognize the sensor clips. Open and close the flash and see if the make contact when open.
(And DON'T fire the flash when open, or at the very least don't touch anything in there when firing or you'll get zapped.
Goodluck..
May 16, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
How slove the problem
Introduction
Specifications Recommendations
The Nikon D60 is an inexpensive 10 MP DSLR that comes with an excellent 18-55mm VR lens for about $650 as of June 2008. It was a announced in January, 2008, and sold for about $750 with lens in February 2008.
The Nikon D60 is a replacement for the almost identical D40x.
Personally I prefer Nikon's least expensive D40 over the D60 or D40x. The D60, D40x and D40 are actually exactly the same cameras, differering only slightly in their internal electronics, but differing greatly in their prices.
The D60 is actually a D40 body with a few more card-clogging pixels, a VR lens and adaptive dynamic range, but a slower maximum shutter speed with flash.
The D60 is less sensitive to light then the D40 (its default ISO is only ISO 100 compared to the D40's default ISO of 200). Its less sensitive to light because the pixels have to be made smaller to cram more of them into the same-sized sensor. Smaller pixels collect fewer photons than larger pixels. Since the D60 is half as light sensitive, the D60 has to use twice as long a shutter speed or a larger aperture, which makes it more likely to make a blurry picture than the D40. OOPS!
Save your money and get the D40 instead. The D40's faster sync speed is invaluable for use with flash outdoors, and the extra light sensitivity in normal use will help make sharper pictures. These three cameras (D40, D40x, D60) otherwise, for most users, are identical. Compare them in person and you'll see. Megapixels don't matter.
(I detail the few fine points which are new in the D60 further below.)
I had my hands on a D60 back in January 2008. The D60 is an excellent camera, but for most of the people who will buy it, it's the same thing as the $300 less expensive D40. I'd suggest getting a D40 and putting the $300 towards more lenses and/or a bouncable flash.
In fact, the faster flash sync speed (the fastest shutter speed with flash) is more than twice as fast in the D40 (1/500 vs. 1/200), and along with the faster base ISO, the D40 is more likely to make sharper photos for most people, for hundreds of dollars less!
The only significant feature in the D60 over the D40x and D40 is adaptive dynamic range. The D60 does not have any of the other next-generation functionality of the D3 and D300.
The D60 is just a D40 with more pixels, but slower shutter speeds with flash outdoors and less basic light sensitivity due to the smaller pixels needed to jam more of them onto the same-sized sensor.
I make excellent 12 x 18" (30 x 50 cm) prints from my 6 MP D40; do you plan to print bigger? Really? The resolution makes no difference unless I'm printing at 20 x 30" (60 x 80 cm) or more.
Since the D60 costs $300 more than the D40, I'd much rather have a D40, 1/500 flash sync for better daylight fill-flash range, a minimum ISO of 200 and $300 left over to buy lenses and an external flash that I can bounce for better lighting. For instance, the D40, 55-200mm VR and SB-400 is a far better way to spend the same $750.
Sep 19, 2011 | Nikon D60 Digital Camera
Picture is not showing on screen until after I take the picture
The D40 works as SLRs have worked for half a century, showing the view only through the viewfinder. The LCD is for menus, setup, and reviewing pictures you've already taken. The LiveView capability that allows you to use the LCD for composing your pictures is a relatively new feature. Nikon introduced it into their cameras with the D3 and D300, released well after the D40.
Sorry if that wasn't the answer you wanted to see, but that's the way this camera works.
Feb 12, 2011 | Nikon D40 Digital Camera with G-II 18-55mm...
How to take a picture using display instead of view finder
I don't believe there is. Nikon call it Live View in other models, but its not mentioned in the D40 user manual.....
here's the full manual, if you'd like it.
http://safemanuals.com/user-guide-instructions-owner-manual/NIKON/D40-_E
Feb 28, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
I want to just download a few Pictures to my computer,can I do this? I don't want to keep dowloaded pictures I have already downloaded, just add the new ones. I use my card in my picture frame. So I keep...
Try using a separate card reader to download your pictures. That way, when you double-click on the icon that appears, you can select the pictures you want to download.
Sep 05, 2009 | Sony Alpha DSLR-A350K Digital Camera
Red line on every photo taken with Nikon D40
And your question was?
A new CCD for £128 - that is a total bargain. If you think you can buy a camera half as good as the D40 for RM750 you are deluded... although I agree that the CCD shouldn't have gone in such a short time - I would guess that Nikon UK would have repaired it on good faith - as long as the camera was obviously in otherwise good condition.
Jun 19, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
19LG30 TV issue
Call LG and schedule a service call with a local tech to properly diagnose the system. Sounds like it's a main board issue, though.
Feb 16, 2009 | LG 19LG30 19 in. LCD HDTV
Highlight feature was turned on don't no how to switch off
Just click on the top arrow on the multicontroller twice. On the first click, the histogram will show and next normal image will show up.
Dec 25, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Flash won't fire
Here's a <a href='http://photo.net/bboard/uploaded-file?bboard_upload_id=42254384'>photo of the sensor in a D70</a>. The D40 flash is a bit different, but if you open it (just unscrew the two little screws in front) you'll recognize the sensor clips. Open and close the flash and see if the make contact when open.
Apr 02, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
