Question about PfaFF Creative 7570
Pfaff Creative 1371
Haven't used my machine for several years. When I set it up today to use it, the presser foot seems to be stuck--it will not go down. The presser bar lever works up and down, but the foot does not move.
  • 1 more comment
  • Anonymous Feb 29, 2008
    creative 7510 the presser foot will not go up or down although the lever moves.
  • Maralee Mar 06, 2008
    Thanks -- I tried the oil, but still will not budge. The wheel just does not turn.
  • Maralee Mar 12, 2008
    Thank you for your efforts. I finally broke down and took it to the sewing machine shop -- they said it was totally seized up and had to send it to their repair center.
    Scholar:
  • 35 Answers
I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional repair guide written by an expert. Besides PfaFF sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learn the repair skills!
Good luck.
Posted on Sep 08, 2010
I have a Pfaff creative 1371, all the lights on the switches are on ,and it wont do anything .have tried pressing the corrector switch,turning off ect but nothing does this mean its toast .Tina
NO! It may not be toast! Have you tried pressing the needle down button? This recently happened with my Pfaff 1467, and it turned out to be a short in the foot control. Check the power cord to your foot control, giggle it, and if you have a meter, check to see if the correct amount of voltage is running through it. Then, gently unscrew it and take it apart to make sure there are no loose or frayed wires. We did this twice, over the last few years, before we just gave up and bought a new foot pedal.
May 01, 2018 | PfaFF Sewing Machines
Can I use modern presser feet with my Pfaff 130?
It all depends on your particular model machine.
Found on the internet, Low Shank vs High Shank:
"When presser foot is down, measure the distance from the bottom of foot to screw-hole that holds the foot onto the presser bar. Singer slant is for slant needle machine only. A high shank machine measures approximately 1 1/4" from the screw to the bottom of the foot."
http://www.sewingpartsonline.com/sewing-machine-presser-feet.aspx
http://www.sewingpartsonline.com/pfaff-sewing-machine-presser-feet.aspx
Pfaff Presser Feet
You may be able to use snap-on feet if you can first buy the shank adapter for your machine. You can buy a whole kit of 10 or more different snap-on feet that you would be able to use with the adapter shank.
Buying brand-name accessories could get very expensive. Some believe the generics or snap-on are inferior, but that is a matter for the owner to determine after deciding how much the accessories will be used. Personally, the snap-on feet I've used serve their purpose. If I am using a foot very frequently, I will consider buying the brand-name because the quality is usually better.
You'll need to determine what shank your machine has and whether these feet will work on your machine. Frequently, you can find accessories on eBay.
Here's an example of an adapter for low shank:
Generic Snap On Low Shank
http://www.thecolorfulworldofsewing.com/Pfaff-Presser-Feet/
11 Piece Snap On Presser Foot Set
15 Piece Presser Foot Set with Walking Foot
32 piece: http://www.thecolorfulworldofsewing.com/32-Piece-Presser-Foot-Set-with-Bonus-Needle-Threader.html
In case you need it, here is a manual for your machine:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0CCIQFjABahUKEwiL_5_30pDIAhXRBpIKHSP2Bas&url=http%3A%2F%2Fwww.voiles-alternatives.com%2Fdocuments%2Fvoilerie%2Fmachine%2FManuel_pfaff_130.pdf&usg=AFQjCNGAJ_-_R3MN_5aa1L1yRJ38-FrUVQ&bvm=bv.103627116,d.aWw&cad=rja
Sep 23, 2015 | PfaFF Sewing Machines
Presser foot
If your footer have been in storage for so long, there must be some rust accumulating in the footer, you should have a technician take a look at it.
Dec 10, 2013 | PfaFF Creative 7570
My presser foot "handle" is stuck on my Pfaff Creative 7550, I can't move it to use my machine. I don't see anything wrong, any suggestions?
Yikes! I bet that since it has sat for so long that you have some corrosion not allowing the foot bar to be moved.
Dec 15, 2012 | PfaFF Creative 7570
Presser foot does not lower.
I had the same problem ! I had to take it to be repaired, they had to take it apart & grease the whole thing, I hadn't used the machine in a couple of years & the original "grease" became too hard for the foot to come down.
Jul 06, 2012 | Euro-Pro 9105 Computerized Sewing Machine
Pfaff 1371 hand wheel is frozen and presser foot won't lift up or down
the machine needs to be checked to see what's wrong with it
Jun 11, 2012 | PfaFF Sewing Machines
I have a 9960 singer machine and am trying to use the buttonhole presser foot for the first time and I can not get it to sew T
the buttonhole foot snaps on to the presser bar, there's a little lever at the back of the presser bar that releases the foot, then put the buttonhole foot down on the needle plate & use the presser foot lifter (number 11) to lower the presser bar down onto the buttonhole foot & you'll hear a click sound when it snaps on & make sure to use the buttonhole lever(number 31) because the machine won't sew a buttonhole unless that lever is pulled down.
Apr 26, 2012 | Singer Sewing Machines
The foot doesn't go down enough to reach the feed dogs
The presser bar may be stuck and may need some WD40 on the top so it seeps down the needle bar, or the presser foot dial or adjuster is set to 0, or the presser bar spring has broken, or the block and screw on the presser bar where the lever is has come loose.
Sep 02, 2011 | PfaFF Sewing Machines
Cannot get presser foot into sewing position
if the presser foot is stuck in the up position you need to get some WD40 and spray the shaft.
Nov 24, 2010 | PfaFF Creative 7570
Sewing Machines Logo
1,008 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
