Question about Whirlpool Duet GHW9150P Front Load Washer
Hello I have a whirlpool duet sport ht and it only a year old and it show code f-21 what does that mean and can it be fix
  • 8,197 Answers
EXPLANATION AND RECOMMENDED PROCEDURE
F21 LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:After 4 minutes the “Sd” error will be displayed, then
4 minutes later the “F/21” error code will be displayed. Press
PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Posted on Feb 06, 2010
Whirlpool Duet Sport F21, F01, SD
Drain pump may be clogged or need to be replaced may run but not pump blade stripped in pump
Apr 28, 2017 | Whirlpool Duet 3.8 cu. ft. Front Load...
How do i fix a F02 error for a whirlpool duet ht
Take the service panel off and look for the tech sheet behind it. It give explanation of error and remedy.
Aug 29, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Error code F--21 and it is locked
Hello, welcome to fixya.
Based on your post I understand you have a "F21" error problem with a Whirlpool washer, the error means an excessive drain time or excessive suds was detected as you may or may not already know. This is also the reason it won't unlock.
If you follow the link to my solution to this error designed specifically for "do-it-yourselfers" you should be fixed up in no time. (It's much quicker for me than pasting or retyping the complete solution several hundred times, that's how common this is)
http://www.fixya.com/support/r9090359-whirlpool_frontload_f2_f21_sd_suds
Thank you for visiting fixya for your washer inquiry. Please take a moment to rate my assistance both here and on my tip link and leave a brief testimony.
Regards,
Macmarkus :)
Jul 21, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
What is error code f 21 on a whirlpool duet sport wfw8300 3.8 cubic washer?
This means that the drain pump is clogged. Tip the machine back and remove the three screws on the bottom panel. The pump has a filter inside. Pull the filter out and clean it, it will fix the issue for sure!
Apr 13, 2011 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Duet Sport washing machine with a leaking door.
You need to check if the door is not loose on the washer, make sure you tighten all the screws on the door
Jan 07, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
My whirlpool duet sport washer often finishes it's cycle with the symbol Sd or 5d, I'm not sure which one. Any idea what that means?
Slow drain. Check your drain hose for kinks and make sure it's not partially plugged. If it is going into a pipe make sure it isn't pushed too far into it.
Sep 10, 2009 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool Duet Sport ~ E28 Error Code
serial communication error between central control and motor control.
Check connections at ccu (top front right corner) and mcu (bottom by motor), check belt drive for wear.
Did motor run ? Any other codes in diagnostic? (any one modifier button 4 sec on 4 secs off 5 times.) F codes are failures and C codes are portions of test cycle(automaticly run)
Apr 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
48 people viewed this question
Dan Webster
Dan Webster
Sal De
