Question about LaCie 500GB USB 2.0 7200 RPM 8MB 500 GB Hard Drive
Macbook is not reading this hard drive, after editing in final cu
Hello... i am using this hard drive for editing video and audio (final cut pro, GarageBand) with Macbook ...
Recently after a certain editing time on final cut, it started to freeze + sounds of buzzing, like electricity or something. I had to force quite it all, all the time... it was happening at a specific point in the editing time line. After few times of trying to change the project in final cut, it got to a point where the macbook was having hard time reading the drive itself, immediately after connecting it to the computer it started that buzzing sound, and it only read the volume but not what's in it.
I've tried verifying disk and repairing disk... but nada.
Then i've tried the drive with an old Ibook G4, and the ibook read the hard drive, no problem... and no buzzing noise.
So at this point i guess that my macbook is having a certain problem with the content of the hard drive, something in the communication between them, in the usb maybe, in the preferences...
I don't know :-)
Any suggestions?
Thanks allot!
2 Suggested Answers
KOakaKO
  • 135 Answers
SOURCE: External Firewire drive won't mount any more
This model appears to have a high failure rate in consumer reviews, so it may have physical damage on the disk. Only a re-format of the drive will isolate bad sectors that won't hold data. Try re-mounting your drive after a fresh re-boot of your computer. If the drive came with the manufacture's software to allow it to communicate with your computer, then try removing this software from your system and re-installing it again. This will repair a corrupt driver or I/O program. Try using the drive with a new or different firewire cable. Other users have reported this drive working again after replacing the cable. If you use Mac OS 10.2, you might not be able to initialize or partition the hard drive. This may require you to partition and format the drive on a different computer. From your brief description, it sounds as though you may need to re-format the drive before it will work again.
Posted on Aug 02, 2007
G-Tech G-Drive Q 1TB. Four months old, only several hundred gigs of data on it. Used primarily for video editing with Final Cut Pro. PLugged in, attached to MacBook Pro today. Without warning, drive made...
The platters on your drive collided, the only way to recover is a professional company. Google Hard Drive recovery, you will get several companies, be prepared to pay $300-500.
Mar 25, 2009 | Computers & Internet
Tip
Best Mac MXF File Converter-Import/Edit Canon MXF Files to ProRes 422 MOV to FCP...
MXF file format comes from like Panasonic HVX200/HPX300, Canon XF300/XF305, Sony EX camera, etc. It is not compatible with many programs just like Apple Final Cut Pro. So Convert MXF file to FCP MOV Video is a necessary step to do if you want watch your video from your camcorder which export mxf file.
And we know that Apple ProRes 422 , Apple ProRes 4444,introduced in Final Cut Studio, was advertised to one of the codecs to result in less compression and higher data rate/higher quality files for HD editing in Final Cut Pro.
Below is the step-by-step guide for you to quickly Convert/Edit MXF to Apple ProRes 422 (*.mov) Final Cut Pro on Final Cut Studio,Final Cut Pro 7 on Mac.
Step 1. Add MXF videos to Aunsoft MXF Video Converter for Mac.
Connect your MXF Camcorder to iMac with USB 2.0 cable or use card reader to transfer the .mxf files to Apple hard drive disk. Run Aunsoft Video Converter for Mac as the best Mac MXF to FCP Apple ProRes Converter . and click the "Add" button to load .mxf videos.
Step 2. Choose Apple ProRes codec for Final Cut Pro.
Click the "Format" option, choose the Final Cut Pro > Apple ProRes 422 (*.mov) and navigate to the Final Cut Pro group, you will notice that there are profiles with Apple ProRes 422, Apple ProRes 422(HQ), Apple ProRes 422(LT), Apple ProRes 422(Proxy), Apple ProRes 4444. Here we choose Apple ProRes 422(HQ) (*.mov) as output format. (The Apple ProRes 422 (Proxy) codec is intended for offline editing and contains 30 percent of the data rate of Apple ProRes 422, and I recommend you to select Apple ProRes 422(HQ), Apple ProRes 422(LT) MOV for outputting.)
Step 3. Merge Canon MXF files. (Optional)
Tick the checkbox for "Merge into one file", and the Mac MXF Video Converter will join and combine the video clips into a single file as output.
Step 4. Convert MXF to Apple ProRes MOV for Final Cut.
Click the convert button under the preview window, the Mac MXF Video converter starts converting MXF videos to Apple ProRes MOV, and joining the MXF files for editing in Final Cut Studio.
After Converting and Merging the MXF files, just import the output Apple PreRes 422 .mov files to Final Cut Pro 7 or Final Cut Pro 6 for editing and the video .Optimize your workflow and save time with the Apple ProRes compression for Final Cut Pro. You can also import the output videos to Final Cut Express (FCE) 4 for editing in full HD.
on Jul 13, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
Convert and Merge Panasonic TM700/HS700 MTS to ProRes MOV for FCP 7 on Mac
More Article about ProRes Converter: <br /><a href="http://www.aunsoft.com/mac-avchd-videos-to-prores-422-converter-m2ts-to-prores-422-quicktime/">Convert M2TS to ProRes</a> <br /><a href="http://www.aunsoft.com/transcode_convert_avchd_mts_m2ts_to_fcp_fcp7_apple_prores_422_on_mac/">Convert AVCHD MTS to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_transfer_panasonic_hs60_mts_to_apple_prores_422_mov_for_editing_on_final_cut_pro/">Transcode Panasonic 1080p AVCHD to ProRes</a> <br /><a href="http://www.aunsoft.com/no_loss_of_quality_mts_to_prores_conversion-edit_panasonic_tm900_mts_on_fc_studio/">No Loss of Quality Panasonic MTS to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_nikon_d5100_h264_to_prores_for_editing_on_fcp/">Convert Nikon H.264 MOV to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_canon_eos_t2i_canon_7d_mov_to_prores_mov_for_final_cut_pro_on_mac/">Convert Canon EOS MOV to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_deinterlace_sony_hxr-nx5e_avchd_to_prores_mov_for_fcp_on_mac/">Deinterlace Sony AVCHD MTS to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_bloggie_touch_full_hd_mp4_to_prores_for_final_cut_with_mac_sony_bloggie_touch_converter/">Convert Sony Bloggie Touch Full HD MP4 to ProRes</a> <br /><a href="http://www.aunsoft.com/apple_prores_422_converter_convert_and_playback_apple_prores_codec_movies/">Convert and Playback Apple ProRes Codec Movies</a> <br /><br /><b>Panasonic HDC-TM700</b> is the new model introduced in early 2010 with 32GB built-in Flash Memory. To maximize the beauty of Full-HD 1920 x 1080, 60 progressive recording*, Panasonic worked to develop the ideal camera system. <br /><b>Panasonic HDC-HS700</b>,New 1080/50p recording (Full-HD, 1920 x 1080, 50 progressive recording) conveys about twice the information of 1080i (interlace) recording to produce the ultimate beauty in image quality, exceeding even conventional Full-HD images. It minimizes afterimages and flickering caused by subject motion and renders crisp, detailed images. 64GB SDXC card can record approximately 27 hours 30 minutes of 1920 x 1080i High Definition video in HE mode, and approximately 5 hours 20 minutes of 1920 x 1080p full High Definition video in 1080/50p mode. <br />Final Cut Pro is supposed to support AVCHD Lite import, but it does not work very well.If you encounter any problem using GH2 AVCHD Lite on Mac, or want to edit TM700/HS700 1080p MTS in FCP/FCP 7, it is recommended that you convert TM700 Full HD to common MOV for FCP/FCP 7.So you may face the rendering problem when editing in Final Cut Pro. To avoid waiting for rendering in Final Cut when editing, it is recommended want to <b><a href="http://www.aunsoft.com/video-converter-mac/">Transcode AVCHD to ProRes 422 for Final Cut Pro</a></b> native format. <br /><br />Apple ProRes,Apple ProRes 422,Apple ProRes 4444,introduced in Final Cut Studio, was advertised to one of the codecs to result in less compression and higher data rate/higher quality files for HD editing in Final Cut Pro. <br /><br />Here is the step-by-step guide for you to <b><a href="http://prores-converter.com/2011/06/convert-and-merge-tm700hs700-mts-to-prores-mov-for-fcp-7-on-mac/">Convert and Merge TM700/HS700 AVCHD MTS to PreRes 422 MOV</a></b> for Editing in FCP/FCP7 without rendering on iMac or MacBook Pro with Mac OS X like Snow Leopard. <br /><br />Step 1. Load Panasonic TM700/HS700 videos to Aunsoft Video Converter for Mac. <br />Run Aunsoft Video Converter for Mac as the best <b>TM700 AVCHD Video to ProRes Converter on Mac</b>, click the "Add" button and you can browse the TM700/HS700 1080p videos for conversion. <br /><br />Step 2. Choose Apple ProRes for Final Cut Pro. <br />Click the "Format" option, and navigate the mouse cursor to <b>Final Cut Pro &gt; Apple ProRes 422 (*.mov)</b> as output format. The video to ProRes 422 converter will transcode Panasonic DMC-GH2 1080 AVCHD Lite to Final Cut Pro native format. <br /><br />Step3. <b>Merge Panasonic 700 1080p AVCHD files. (Optional)</b> <br />Tick the checkbox for "Merge into one file", and the Panasonic TM700/HS700 1920&times;1080 AVCHD converter will join and combine the video clips into a single file as output. <br /><br />Step 4. <b><a href="http://canon-videoconverter.com/2011/06/convert-and-merge-tm700hs700-mts-to-prores-mov-for-fcp-7-on-mac/">Convert Panasonic TM700/HS700 videos to Apple ProRes for FCP</a></b>. <br />Click the convert button under the preview window, the conversion from <b>Panasonic Camcorder AVCHD to FCP Native Format ProRes 422</b> will start immediately. <br /><br />After converting and merging the Panasonic TM700/HS700 AVCHD files, just import the output Apple PreRes 422 .mov files to Final Cut Pro 7 or Final Cut Pro 6 for editing and the video is in HD 1920&times;1080.Optimize your workflow and save time with the Apple ProRes compression for Final Cut Pro. You can also import the output videos to Final Cut Express (FCE) 4 for editing in full HD.
on Jun 16, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
Convert TM900 1080/60p and 1080/50p AVCHD MTS footage to ProRes 422 for Editing...
Edit TM900 1080p 28Mbps AVCHD MTS to ProRes 422 in FCP
The HDC-TM900 High Definition Camcorder is a HD offering from Panasonic.While you record 2D videos in 1080/60p (1080/50p for PAL model) at 28Mbps with Panasonic HDC-TM900 .If you would like to put the AVCHD videos from TM900 to Final Cut Studio for editing, a third party software shall be needed to handle the 1080/60p and 1080/50p footage to ProRes 422 for FCP 6/7. Aunsoft Video Converter for Mac is the recommended Panasonic TM900 AVCHD to ProRes converter for high quality video editing on Mac with less compressed Apple ProRes format.
Here is the step-by-step guide for you to Convert,import and edit Panasonic HDC-TM900 MTS to Apple PreRes 422 MOV to Final Cut Pro/FCP7 without rendering on iMac/MacBook Pro with Mac OS X like Snow Leopard.
Step 1. Load Panasonic HDC-TM900 videos to Aunsoft Video Converter for Mac.
Run Aunsoft Video Converter for Mac as the best MTS video to ProRes converter on Mac, click the "Add" button and you can browse the TM900 28Mbps videos for conversion.
Click the "Format" option, and navigate the mouse cursor to Final Cut Pro > Apple ProRes 422 (*.mov) as output format. The video to ProRes 422 converter will transcode Panasonic HDC-TM900 1080p AVCHD to Final Cut Pro native format.
Step 3. Choose 1080p size with 60 or 50fps.
Click the "Settings" button and choose 1920*1080 from the video size drop-down box to keep the original HD resolution. Click the drop-down box for frame rate, and choose 60fps or 50fps as output video frame rate. The frame rate option depends on your source videos in NTSC or PAL model. Click the OK button to save the changes and the Mac AVCHD video converter will convert 1080p AVCHD videos to 1080p ProRes 422 Mac FCP compatible native format.
Step 4. Convert 28Mbps MTS to Apple ProRes for FCP.
Click the convert button under the preview window, the conversion from Panasonic TM900 AVCHD to ProRes 422 MOV Final Cut Pro Native Format will start immediately.
After converting and merging the Panasonic HDC-TM900 AVCHD files, just import the output Apple PreRes 422 .mov files to Final Cut Pro 7 or Final Cut Pro 6 for editing and the video is in HD 1920×1080.Optimize your workflow and save time with the Apple ProRes compression for Final Cut Pro.
on Jun 06, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
How to import Kodak video to Final Cut Pro and edit Kodak video with Final Cut...
How to import Kodak video to Final Cut Pro and edit Kodak video with Final Cut Pro?
Final Cut Pro is a professional and all in one video editing, compositing and special effects package for the Macintosh. The software logs and captures video onto a hard drive (internal or external), where it can be edited and processed.
If you are a Kodak video fan and you want to give professional editing to your Kodak videos, Final Cut Pro is the best choice for you. However, Final Cut Pro can edit any QuickTime compatible file format including DV, HDV, MOV, MPEG-4. That is to say, in order to edit your Kodak video with Final Cut Pro, you have to convert Kodak videos to the supported formats by Final Cut Pro with Kodak video to Final Cut Pro Converter for Mac.
Tips:
Kodak records the video files with mov files (i.e. Quicktime files) does not mean they are perfect for editing in FCP. The fact is, all of the small video cams, including the Kodak Zi8 Cams, records highly compressed codecs that are known as delivery codecs, not editing codecs. You need one third-party software to convert HD mov files to some formats like DV, HDV , MPEG-4 that FCP is happy to edit.
Kodak video to Final Cut Pro Converter for Mac is one simple-to-use solution with the minimum amount of buttons and a small menu for converting Kodak video (Kodak Zx1, Kodak zi6, Kodak Zi8 and Kodak PLAYSPORT) to DV, HDV, MPEG-4, etc., for importing Kodak videos to Final Cut Pro. Besides, it is also an easy-to-use editing tool that assist you for making personalized video. You can trim the video to a certain length to convert, adjust video aspect ration by using crop function, add special effect like Gray, Emboss, Old film into video to make it more artistic, join several files or set the video output parameters. All this can be done with a few mouse clicks.
Part one: How to import Kodak video to Final Cut Pro and edit Kodak video with Final Cut Pro?
Step 1:Free download and install Mac Kodak video to Final Cut Pro Converter
Download Kodak Video to Final Cut Pro Converter For Mac and double click the downloaded . dmg files to install. A user-friendly interface will pop up.
Step 2:Load Kodak video files
First: Connect Kodak camcorder to computer and transfer mov files to iMac, Mac book.
Second: Hit the File button on the top left panel or click "Add Video" button to select Kodak MOV files to this converter.
Step 3:Select the output format and destination
Click the downward arrow beside Settings to choose the proper Final Cut Pro format from the drop-down list. And then click Browse button to specify the output location.
Tips: Select DV, HDV or MOV format for FCP in the pull-up list next to Profile field. And then click Browse button to specify the output location.
Step 4:Start the conversion
After all the necessary setting has been done, hit the "Start" button to start converting. Click the Open button to select the converted DV, HDV files to Final Cut Pro for further editing upon completion.
Part Two: Import Kodak videos to Final Cut Pro and edit Kodak video in Final Cut Pro.
Step 1:Import Kodak videos to Final Cut Pro
Launch Final Cut Pro and click "Import"-"Files" and then select the converted Kodak files. Find the file in the resources list for the project and drag the file into the Timeline, and then save the project.
Step 2:Edit Kodak video in Final Cut Pro
Apple's Final Cut Pro Software is an all in one video editing, compositing, and special effects package for the Macintosh. The following steps will show you how to use the Timeline:
One: Edit video and audio timing
There are three tracks on the Timeline, one for video and the other two for audio. And you can cut the video and audio tracks all at once in the same place.
Choose the razor blade tool in your menu, and click the times that you want to split it. You can also set input and output times on the Viewer window. Final Cut Pro also allows you to layer video tracks on top of each other.
Two: Add transitions
For Kodak videos, you might want to use simple and non-distracting transitions. Then you can just select Fade Out or Cross-Fade transitions.
Three: Export video
Once you are finished with editing your video, click on File and point to Export, then you will see a list of options of how you can export the edited file. For example, if you want to publish your video to the web, you can click on "Export using QuickTime Conversion". When you see the naming dialog box, input the name you prefer and at the bottom, select "MPEG-4" at the bottom, and then select "Broadband-High" under the format setting. And now click on Save.
on Sep 17, 2010 | Computers & Internet
Tip
Import flip video to Final Cut Pro and edit flip video Final Cut Pro Final Cut...
Final Cut Pro is a professional video editing application for Mac users and it is widely used even by many Hollywood people on professional movie post-production. If you are a flip video fan and you want to give professional editing to your flip videos, Final Cut Pro is a great choice. However, Final Cut Pro does not allow raw flip videos to be imported to Final Cut Pro and you will need to convert flip video to Final Cut Pro supported formats. Thus, to edit flip video in Final Cut Pro, you can follow the three parts below:
Part One: Convert flip to Final Cut Pro video
Download Doremisoft Mac Flip Converter and refer to the following steps to import flip video to Final Cut Pro.
Step 1: Add flip videos
Click the "Add File" button to add the flip videos you want to edit in Final Cut Pro to Mac Flip Converter.
Step 2: Select a Final Cut Pro supported output format
Click the Profile drop-up list and select
Step3: Convert flip video to Final Cut Pro
Click the "Start" button on the lower right of the interface to start converting flip video to Final Cut Pro.
Part Two: Import converted videos to Final Cut Pro
Step 1: Launch Final Cut Pro and you can see the layout of the Final Cut Pro Interface. From under the File command at the top of the interface, select "Import" and "Files". Thenselect one converted file from the Choose a File window and press the "Choose" button to choose this file.
Step 2: Find the file in the resources list for the project.
Step 3: Drag the file into the Timeline and then save the project.
Part Three: Edit flip video in Final Cut Pro
Final Cut Pro is a very professional tool with many functions. The following steps will show you how to use the Timeline:
Step1: Edit video and audio timing
Step2: Add transitions
For flip videos, you might want to use simple and non-distracting transitions. Then you can just select Fade Out or Cross-Fade transitions.
Step3: Export video
As mentioned above, Final Cut Pro is a very good tool for professionals. If you want to know better about using Final Cut Pro, you can go to certain Final Cut Pro forums. The most popular one is Los Angeles Final Cut Pro User Groupn and you can find a lot of useful info there.
You might also want to buy a book and study how to use Final Cut Pro, such as Apple Pro Training Series: Final Cut Pro 7 and learn how to professional edit your videos with Final Cut Pro.
If you just want to do some basic editing such as cropping, length trimming and video effect adjustments, you can just use Doremisoft Mac Flip Converter to get the job done by following How to edit flip video with Doremisoft Ma Flip Converter.
on Aug 13, 2010 | Computers & Internet
Tip
Put and Play Canon HF S21 HD 1920x1080 AVCHD MTS on iPad Canon Vixia HF S21 is...
Canon Vixia HF S21 is the new AVCHD camera in 2010 for capturing Hi Def 1920x1080. The 64GB internal flash drive enables long time video recording for more than 8 hours with Full HD 1920x1080 recording at FXP profile. It enables double slots for SD memory cards.
The video captured with Canon HF S21 is stored in AVCHD .mts file format with MPEG-4, AVC/H.264 as video codec, and Dolby Digital 2 channel (AC-3) as audio codec. If you get the with optional Canon SM-V1 5.1-Channel Surround Microphone, you can get Dolby Digital 5.1-channel for the audio.
To transfer Canon Vixia HFS21 AVCHD to computer hard drive:
You can use the bundled Pixela ImageMixer 3SE Video Editing Software, and it is easy to transfer Vixia HF S21 AVCHD movies onto computer hard drive with this software. If you are using Mac computer, you can also use iMovie to download videos to Apple hard drive. Just connect the camcorder to iMac/MacBook Pro with Mac OS X like Snow Leopard, and HF S21 could be recognized by iMovie for loading videos.
To put and play Canon HF S21 AVCHD videos on iPad:
Even though iMovie mentioned above could recognize Caonon HF S21 for loading videos, there are also problems for importing Canon HF S21 .mts to Final Cut Pro (FCP) or Final Cut Express (FCE), even iMovie. Aunsoft MTS/M2TS Converter for Mac is the recommended Mac Canon HF S21 MTS to iPad converter for you to easily edit Canon HF S21 videos and transfer edited video to iPad.
Below are the simple steps for transcoding Canon HF S21 to iPad.
Step 1. Load Canon HF S21 video to Aunsoft MTS/M2TS Converter for Mac.
After transferring Canon HF S21 AVCHD videos to Apple hard drive, run Aunsoft MTS/M2TS Converter for Mac as Canon MTS converter and click the "Add" button to load .mts videos.
Step 2. Edit Canon HF S21 MTS videos.
Select the video clip and click the "Edit" button to trim and crop videos, to flip video, adjust brightness and contrast.
Step 3. Choose iPad HD output format.
Click the "Format" option and choose iPad > iPad HD Video(*.mp4), and the Mac Canon MTS to iPad converter will convert AVCHD Hi Def 16x9 to 720p MP4 videos for iPad.
Step 4. Convert Canon HF S21 MTS to iPad.
Click the convert button under the preview window, and the conversion from Canon HF S21 MTS to MP4 for iPad starts immediately.
After the conversion, connect iPad to iMac/MacBook Pro and sync the editing videos to iPad. It is that easy to transferr edited video to iPad. Give it a try and enjoy AVCHD videos on iPad.
on Jul 29, 2010 | Cell Phones
Tip
Import MOD to FCP ? How to import MOD to Final Cut Pro to edit your MOD files
Final Cut Pro is a very sophisticated video editing program made by Apple and provides professional editing of any QuickTime compatible video format including DV, HDV, P2 MXF (DVCProHD), XDCAM, QuickTime MOV, QuickTime MP4 etc. It has become the choice for multimedia journalists using Apple computers and many Hollywood film makers.
However, Final Cut Pro does not support MOD files, which poses a problem if you are using JVC, Panasonic or Canon camcorders that take MOD videos. So if you want to edit MOD in Final Cut Pro, you will need to convert MOD to Final Cut Pro supported formats.
Doremisoft Mac MOD converter provides the perfect solution to letting you import MOD to FCP by converting MOD to Final Cut Pro supported formats.
The four steps below will guide you to import MOD to Final Cut Pro:
Step 1: Add MOD files
Click the "Add File" button to add the MOD files you want to import to Final Cut Pro from your Mac hard disc. Then double click a file or select a file and click on "Open" to add it.
Step 2: Select the output format
Click the small arrow at the end of the Profile field, and you will see the Profile drop-up list. Move your mouse cursor to "HD Video" and click on the "HD MOV" profile. This option will let you convert MOD to FCP MOV. Then you can tick the "Apply to all" option that will convert all added MOD files into selected Final Cut Pro supported format. You can also convert MOD to FCP MP4 if it is what you prefer.
Step 3: Start to convert MOD to Final Cut Pro
Find the round Start button on the lower right part of the main interface to start the conversion. On the conversion window you can see the elapsed time and the remaining time. Now you can decide how to kill the time before the conversion is finished. Then just don’t forget to come back for the converted files you want to import to FCP.
Tip: You can also use Doremisoft Mac MOD Converter to do easy editing such as cropping, trimming, and video effects to your MOD files, click here to see how.
Step 4: Import converted MOV to Final Cut Pro
Launch Final Cut Pro and you can see the layout of the Final Cut Pro Interface. From under the File command at the top of the interface, select "Import" and "Files". Then select one converted file from the Choose a File window and press the "Choose" button to choose this file. Then find the file in the resources list for the project and drag the file into the Timeline and then save the project.
Now you have successfully imported MOD to Final Cut Pro and just start editing!
on Jul 21, 2010 | Cell Phones
Tip
Transfer/Edit Sony HDR-TG3 1080i AVCHD Videos on Windows/Mac Sony Handycam...
Sony Handycam HDR-TG3E is a super small camera with full HD recording on Memory Stick in 2008. It includes 4GB and 10x optical zoom for capturing 1920x1080 and 1440x1080 videos. However, this camera does not include progressive recording mode, which indicates that the HD videos are 1080i. Even though it is compact camera, the audio is recorded in Dolby Digital 5.1ch. You can also take 2.3Mp stills while you are recording video footage.
Sony HDR-TG3E features:
- 1920x1080i HD video recording
- 4 megapixel still photo recording
- Dual Rec simultaneous 2.3 megapixel still photo during video recording
- Handy face detection
- Carl Zeiss Vario-Tessar lens
- ClearVid CMOS Sensor and Exmor derived technology
Videos from Sony HDR-TG3E:
Movie Format:
- High Definition: AVCHD (1920 x 1080, 1440 x 1080) in .mts filename extension
- Standard Definition: MPEG2 in .mpg filename extension
Movie Quality:
- HD: FH (1920x1080i, 16Mbps) / HQ (9Mbps) / SP (7Mbps) / LP (5Mbps)
- SD: HQ (9Mbps) / SP (6Mbps) / LP (3Mbps)
Transfer & Edit Sony HDR-TG3 AVCHD videos:
For Windows users:
Install the Picture Motion Browser (PMB) from the bundled CD in box, and connect Sony HDR TG3 to PC via USB cable. Use Sony PMB to download HD .mts videos from camcorder to PC.
For Mac users:
You can capture and transfer Sony HDR-TG3 1080i videos to iMac/MacBook Pro via iMovie after connecting camera to computer with USB cable. However, you may face problem when trying to log and transfer AVCHD videos from Sony Handycam HDR-TG3E to Final Cut Express (FCE) 4 or Final Cut Pro (FCP) 5. After transferring HD .mts videos from camera to computer hard drive, just run Aunsoft MTS/M2TS Converter for Mac as the Mac Sony HDR-TG3 MTS converter to deinterlace .mts videos and convert .mts to .mov for FCE and FCP, if you want to edit HD videos.
Alternative way to transfer HDR TG3 videos for Mac and PC:
Just connect HDR TG3 pocket camera to computer via the USB cable, and the HDR TG3 will display as a hard drive on computer. Navigate to the HDR TG3 hard drive to access the memory stick.
Tips: Sony Handycam HDR-TG3E is the model for Europe, and Sony Handycam HDR-TG1 is the model for US.
on Jul 14, 2010 | Cell Phones
LaCie 500GB USB 2.0 7200 RPM 8MB 500 GB Hard Drive Logo
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
