Question about Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5100 all-in-one printer, says check color ink cartridges, ive replaced the ink cartridges with the same number cartridge. why does it still says to check the color ink?
  • 103 Answers
Call Kodak tech support > They will send you a replacement ink cartridge > If that does not work > The printer needs to be replaced
Posted on Feb 08, 2010
Kodak 5350 Color Ink Error Problem Solved
Yes the cartridges of all newer printers have chip that indicates the cart ink level, when the cart is empty the chip self destructs.
May 04, 2017 | Kodak EASYSHARE 5100 All-In-One Printer
My Kodak printer ESP3 is not printing. It keeps flashing over the 3 color tear drops (red,green,purple). Ive powered it on and off several of times as well as checking the cords.
This 3 color drop flashed when the color ink cartridge needs to be replaced.
Try to use a new color ink cartridge > If no go, call Kodak they will replace the color ink > If no go > Call Kodak and this time they will replace the printer
Jan 21, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
How can i refill a kodak color ink
No need of refilling it , call Kodak and tell them u have bought a new pack of ink cartridges and its not detected. Will ask you for serial numbers. Provide the one written on your old ink cartridges.
You'll get inkk cartridges free of charge.
Dec 10, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Check color ink always blinks and does not allow to do any job.
Make sure that you installed the correct ink. It is not enough for it to fit, the numbers on the cartridge have to match those on the cartridges you replaced. You may also have problems with off brand ink that claims to work. Use Kodak ink. Also, many of the Kodak have the ink jet nozzle on the printer, not the cartridge.You can try cleaning in and around the cartridge casing, especially on the copper areas, with an alcohol swab. Then run the cleaning utility on the printer 2 or 3 times.
Nov 09, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5100 Needs Both Cartridges To Print?
Unfortunately, you cannot used the printer if one of the ink cartridge is empty., compare to the other printers you can print a black text or gray scale if the color is empty or one of the cartridge is empty.
All kodak printers work the same both cartridges should have ink on ink before you can use It.
Nov 04, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Red light on "check color cartridge" blinks constantly.
i have a printer hp all in one p380 the all lights are blinking
Jul 06, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Ink level will not reset when cartridge is replaced
If you take the cartridge to walgreens, etc... they can clear the chip. There is none for home use
give them a call !
May 10, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Check Black Ink blinking...???
Remove the ink cartridges
Remove the printhead
Close the access door w/o anything in the printer
wait for a few minutes
Install the printhead only
install the color ink cartridge
install the black ink cartridge
if the error still there ( Repeat the cycle 5x)
or go to www.kodak.com/go/itg
Mar 24, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Prnter kodak easyshare 5100
just to check, is what specific lights is blinking is it the check color or just check black inks??
-to make sure w/ this one is it blinking too fast or slow and what is the color?? check if the on and off is also blinking
-check black ink and check color cartridges blinking fast means no printhead installed
-check black ink and check color cartridges blinking slow, no cartridges installed
-check black ink and check color cartridges blinking w/ on and off ready to calibrate
(in ready to calibrate if doing nothing, just press cancel and
-press photo and cancel on printer, if not doing anything
-remove printhead( the one that holds the cartridges) turn printer on and off, put printhead back to printer w/ cartridges, and check the lights that is blinking
-press photo and cancel again
-if not doing anything, contact manufacturer
-goodluck
Mar 13, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
New ink cartridge for Kodak Easy Share 5300 will not work
The version of firmware you originally had on the printer when you changed the ink cartridge was bad. There is a known issue that when you put in a new ink cartridge when the printer is in the error state "COLOR INK EMPTY. REPLACE COLOR INK CARTRIDGE" the unit writes that value to the new ink cartridge so you will continue to have that error.
So to fix your problem Open the access door and Remove the ink cartridges. Then download and install the new Firmware. Heres the link.
Kodak AiO 5300 Firmware
Then sadly you have to go get another new ink tank and install it.
If you can get through to kodak you should request reimbursement of some sort like a free set of ink tanks.
I hope this helps
Mar 09, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
154 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
