Question about Compaq Presario X1000 Notebook
How can I install the wireless network adaptor on my laptop?
  • Grease_mnky May 11, 2010
    Are you needing to know how to upgrade your adapter or are you wanting to know how to make you're current one that's already installed on your system work?
  • 358 Answers
The installation of wireless network adapter on your
PC is very easy.
I will try to explain how to go about the two parts
involved, i.e the hardware installation part and the
software installation part.
1.) Hardware
To install the hardware part, get a screwdriver,
unscrew the back of your notebook where you see a
symbol drawn that looks like a small rectangular
card. After doing this, you should see two wires that
has a form of hollow pin at the tip.It is always of two
colours, which are black and grey.
Next, get a technician or got to a compute store and
tell them you need a WiFi Card.
Make sure you specify that it is 54G or 108G card
you want.
After getting this chip, insert it into the available slot
provided for WiFi card on your system.
Then Connect the Black Wire to the Mains terminal,
and the Grey wire to the Aux terminal.
Then power on your system.
2.) Software
After you on your system, you should see "New
Hardware found", if you have the driver for the WiFi
Card, then insert it into the CDROM and select "do
not connect to the internet.
Click on next and under the CDROM/Floppy" try to
navigate to where the driver is on the CDROM.
then click on next and follow on-screen instructions
3.)Incase you have installed the adapter before, do
this:
Uninstall the WiFi Adapter totally from the System
first,
(For WIndows XP)
Right-Click on my computer Icon, Properties-->Hardware-->Device Manager,
select the WiFi Adapter under network adapters, and right click on it, then select uninstall
Next, Click on Action on that Same page, and select "scan for hardware changes",
This will bring up a prompt to install the new hardware found (Which is your Wifi Adapter).
(For WIndows Vista)
Right-Click on my computer Icon, go to
Properties-->>Device Manager, select the WiFi Adapter under network adapters, and right click on it, then select uninstall
This will also bring up a prompt to install the new hardware found (Which is your Wifi Adapter).
After this, Press your Wifi button on the system and ensure that it is On, then Scan for wireless networks.
It should connect like that.
Try this out and kindly let me know how it goes,
Hope this helps.
Thank you for using Fixya.
Goodluck
Posted on Feb 06, 2010
  • Dammy Ezekiel
    Dammy Ezekiel Feb 06, 2010
    PC is very easy.
    1.) Hardware
    you want.
    2.) Software
    this:
    first,
    (For WIndows XP)
    (For WIndows Vista)
    Hope this helps.
    Goodluck
My dell inspiron mini laptop used to work wireless. It doesn't work anymore. In re-installed the wireless driver and it still doesn't work. Model is inspiron 910
In Device manager, under the network adaptor are you able to see wireless adaptor for your device. - see if it not marked as disable( Red Mark or Yellow Mark)
Also check in network connection wheather you Wireless connection is in Enable or Disable mode,
Note: Please dont forgot to rate me.
Apr 03, 2011 | Computers & Internet
My wireless adaptor isn't working. I have an Acer travel mate5720 which has a switch on the front for blue tooth & wireless access. Bluetooth works ok but the Wireless adaptor won't i have checked in...
This model does have wireless. I had a similar problem a little while ago, I plugged the unit in to a wired connection, and on it's own, disabled the wireless adapter.
Go to start--> control panel--system-->hardware-->device manager
look under the "network adapters", there should be a wireless adapter or 802g something something, right click on this item and click "enable".
You should then be able to browse for wireless networks now.
Jan 06, 2010 | Acer TravelMate 5720-6635 Notebook
When Gateway Laptop is powered up after shutdown it is necessary to reset the network adaptor using Windows repair process before it will connect to the web. Can I replace the adaptor and if not can I buy...
You will find the driver is corrupted download the network driver and reinstall is first choice.
You may delete the driver in system properties and hardware then let windows reinstall the network driver.
Yes you may also install the USB network adaptor.
If the wireless device inside the laptop is Intel download from the Intel website.
Remove the plate from the bottom of laptop to obtain the brand and model.
Hope this helps you.
PS. system defragment should be done once a week
Oct 23, 2009 | Gateway Computers & Internet
I'm trying to set up a new wireless router but i get a messagw that says thw network adapter is not working
Open the Device Manager and check if the wireless device is listed under the "Network Adaptor".
You may also check in the "System Information" window for all the network adaptors installed and functional in the Computer.
Follow the steps given below to access the "System Information" window:
(i) Please press the Windows key on the Keyboard and then press the "R" key while holding down the Windows key to open the Run dialog box.
(ii) Then, please type "msinfo32" in the Run dialog box and click OK to open the System Information window.
(iii) In the left pane, click on the plus sign next to the Components then on the Network adaptors. This will display all the installed and functional network adaptors in the right pane. Check if wireless adaptor is listed.
If the wireless adaptor is not listed at any of the places then you may try restarting the Computer and reinstalling the wireless driver.
If the Computer still shows the message then the issue may be with the wireless adaptor.
Sep 23, 2009 | Dell Inspiron 9400 Notebook
I received a new XP laptop today! When tried to "search for available wireless networks" I could not because Intel software kept taking over from Windows XP, so I removed/uninstalled my intel wireless...
Hi , Do you have a wireless router ? Did you disable the wireless network , If yes you need to enable . You need to check if the wireless driver is installed properly for that you need to RightClick My Computer+Properties+ Hardware + Device Manager + Click On Network Adaptors . If Yes the n you need to Right Click My Network Places+ Properties and check for Wireless Status + Right Click Enable.
Dec 24, 2008 | Computers & Internet
I don't have wireless network on acer aspire4715Z
The Aspire 4715 comes with Wireless OPTIONAL. Your system obviously wasn't bought with a pre-installed wirelss card. If you want to go wireless, you will need to buy a wireless card/adaptor seperately.
Nov 29, 2008 | Acer Aspire 4720 Notebook
Restored factory settings on pc & cant re -instal belkin adaptor
The Belkin site has very specific instructions for installing this adapter in a pc with Vista. These instructions are at: http://www.belkin.com/support/article/?lid=en&pid=F5D9050&aid=6112&scid=0
I would first unistall any Belkin Software that has already been installed, shut down the system completely and then restart. After you have fully restarted the system then follow the Belkin Site instructions EXACTLY. Any variation is apt to mean an unsuccessful install. Good Luck and have patience.
Nov 14, 2008 | Belkin 802.11g Wireless Desktop Network...
No wifi
You need to get a wireless adaptor your laptop did not come with wireless built in. You can get a USB adaptor or a PCMCIA adaptor. Either will work but the pcmcia adaptor will be a little faster
Have a look here
http://www.google.com/products?hl=en&q=pcmcia+wireless+card&um=1&ie=UTF-8&sa=X&oi=product_result_group&resnum=1&ct=title
Hope that helps
Aug 25, 2008 | Compaq Presario Notebook
Wireless Network?
The modern laptop and Wii will be no problem. Windows 98 will work but it can be much trickier to set up.
Parts needed
1 x Wireless Router - You can pick up a 2WIRE Router from around £20 on eBay
3 x Wireless LAN Network Adaptors - Around £20 each.
Firstly, the Router. This bit connects to your telephone line and broadcasts your broadband signal by radio and allows several computers to use one service. When you buy a router make sure it includes installation software. You can install routers without, but it's a whole lot easier if you have it.
Next you need to be able to receive the broadband radio signal on your computers and Wii.To receive the signal you need Wireless LAN Network Adaptors on each device. Network Adaptors also have software, which allows you to install the drivers needed.
Your laptop may already have a wireless adaptor built in.
You can check this by clicking
Start\Programs\Accessories\System Tools\Communications\Network Connections
Then see if a Wireless adaptor is present. If it isn't, you can install one inside the laptop by buying a laptop wireless network card. Easier, is to buy a USB Wireless LAN Network Adaptor which just plugs in to a USB socket on the laptop.
Look for LAN Network adaptors that are suitable for the Wii and a separate one suitable for Windows 98. Most will be ok for the laptop.
Install the router first. just do what the software tells you, then install the LAN adaptor drivers on each device you want networked.
Finally, make sure you secure your router signal. That stops the guy next door using your network and offers some security from hackers. Your router will include a firewall and you can set up a key code that your adaptors will need before they can connect. Unless the guy next door has the key, he won't be able to use
your network and play your MP3s...hoorah!
Follow the instructions given in the software to set up a WPA or WEP security key.
Great fun, you'll love it if you can get it all going.
Feb 24, 2008 | Computers & Internet
Wireless not working after standby, restart of machine required.
Kaspersky Internet has a firewall built-in you have to turn it off...
Jan 01, 2008 | Intel 3945ABG (WM3945AGM1WB) 802.11a/g/b...
Compaq Presario X1000 Notebook Logo
252 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
