Question about GE Washing Machines
Oil is leaking down the shaft below the gearbox How hard is it to change the seal.
  • 572 Answers
If its a top loader then u need to change ur transmision
Posted on Feb 06, 2010
My gearbox is loosing oil through bottom of engine
would be nice if you mentioned the transmission type
for both manual and automatic , the box has to come out
for manuals the reason seals leak are
worn seal or groove on shaft
input shaft bearing failure
for automatics it is torque converter shaft and pump seals failed
check for correct oil levels first as over filling causes seals to leak
Jun 14, 2018 | Cars & Trucks
Verso gearbox leaking oil
There is a seal in the gearbox and this has been damaged so oil is leaking past it out of the gearbox. You will have to carefully replace this seal, to do this you need to take the gearbox out of the car, put it on a bench and carefully remove the old seal and press in a new one.
Dec 20, 2013 | 2006 Toyota Corolla
Hard to change gears in my v6 hyundia
First thing to check is oil-level in the gearbox. If far below the filler hole - refill and look for oil leaks around seals and in clutch housing.
If oil level is ok - it might need changing or when serviced recently, it might have been filled with the wrong oil.
Somewhere on the side of the gearbox there's a bolt with a seal ring. Usually this is the filler hole. Oil level check is simple, stick a finger in downwards. Should feel the oil level.
Gear boxes need the right oil viscosity and are quite sensitive - meaning changing gears gets difficult specially when cold.
Jun 29, 2011 | 2003 Hyundai Tucson
My ford focus is leaking oil think it might be gearbox oil,
Is the oil you see reasonably clean or is it black. The gearbox oil would be cleaner than the engine oil. Gearbox leaks would most likely come from one of the following:-
  1. Drive shafts
  2. Gear change lever inputs,
  3. Speedo cable
  4. Reverse light switch
  5. Drain plug
  6. Input shaft seal (inside the bell housing).
Pig a piece of paper under the car when you park it at night to give you an idea where the drip is located and inspect the area above that position
Jan 24, 2011 | Ford Focus Cars & Trucks
I have a leak coming from inside the bell housing of my transaxle leaking onto my clutch making it slip new clutch replaced less than a week ago and rear main seal replaced oil smells like gear oil (rotten...
There is an oil seal on the gearbox/transaxle input shaft. If this has failed it will leak oil on to the clutch.It might be able to be replaced by just removing the gearbox again to access the seal. Most likely though is, the gearbox will need to be opened up to replace it.
Oct 12, 2010 | 1998 Suzuki Swift
The transmission is leaking in front and middle of the engine. What is the problem and how can I fix it
could be your gearbox seals.Check if the front one is gearbox oil or engine oil.If it is engine oil then could be your rocker cover seals..oil from the top travelling down,sump gaskits or crank shaft seals.The direction of travels pushes oil towards the rear and sometimes we think that the leak is on the rear somewhere whereas it could be in the front.
Sep 18, 2010 | 1987 GMC Jimmy
What do i do if my transmission fluid leaked ?
fine out were the leak is???? if its leaking out a drive shaft there are oil seals on them that can be changed from the out side if its coming out the frount gearbox oil seal it will be running out the bell housing,,, big job to fix,,,thats a gearbox out job?
Aug 21, 2010 | 2005 Ford Expedition
Oil leak from driveshaft n/s
not sure if you can interchange the manual & aut shafts, but you should check to see if there is excessive play where the shaft enters the gear box if so the diff bearings my be worn, if there is no play or noises from gear box when driving, remove the shaft again an try the seal on the shaft to check it's a proper fit, before fitting seals it is a good idea to leave them soaking in oil for a few hours prior to fitting
hope this helps
Regards
Jim
May 29, 2010 | Hyundai Motor S Cars & Trucks
Water leak/mixing with oil
change the seal behind the water pump impeller
the shifter shaft seal will stop leaking
if it continues to mix water and oil you will have to change the head gasket
Mar 10, 2009 | 2002 Yamaha YZ 426 F
Washing Machines Logo
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
