Question about Sharp AR-M550U Copier
Sharp AR-M550U get error code:F2-31
What is problem with this code? please give me advice also i'm looking for services manual.Machine runs fine on start up, after warm up less than 120second the code F2-31 come out and can't do any thing
  • denbac195857 Feb 06, 2010
    What is wrong with this code?
  • 95 Answers
F2-31 is related to the image process control for the drum. The drum sirface is read by the image density sensor - if it has a problem doing so then it will give this code. Possible causes could be a bad/old/worn drum or the drum is not being cleaned properly by the drum blade. To run the processor control adjustment do the following : press the "P" key then "*" key then "C" key then "*" key again. this will bring you into service mode. (warning : please do not make any other adjustments in this mode as you can do some serious damage to your copier). then type 44 and press start key then 2 and start key again. Once it is finished running restart the copier. If this fails you need to look at the drum and possibly change it.
Posted on Feb 08, 2010
Testimonial: "very helpfull.Thanks"
Can't rid off firm ware update creen
Posted on Jan 23, 2011
ER-M550U GET ERROR CODE E7-60
Posted on Mar 05, 2010
I lost my key operator password for my sharp ar-m550u, how do i recover?
Touch # * C * on the panel
touch 22, then the start button
touch 7, then the start button.
it will display the code on the screen for you
Copier Collin Houston TX Copier and Imaging Expert
Jul 13, 2014 | Sharp AR-M550U Copier
CALL FOR SERVICE.CODE:U7-00
According to the error code manual, it means "U7 00 PC/Modem communication trouble" - You can download the entire list of all codes at the link below. It includes your machine specifically. Hope this helps. http://olsonbros.com/sharp/support/pdf_trbl/trbl-arm550n_m550u_m620n_m620u_m700n_m700u.pdf
May 27, 2014 | Sharp AR-M550U Copier
Sharp MX-M550U cartridge error code: F2-05
f2-05 means that the cartridge is either not in correctly or is a "noncompatible cartridge" aka a knockoff.try a different cartridge and then reset the machine by pressing #,*,C,*, 1,4,start,1,start
Dec 16, 2010 | Sharp AR-M350U Copier
controller connection trouble if you are technical then power down the unit and unplug it ....remove rear cover and reseat all connectors....if you are not technical then call for local service rep....are you in the midwestern usa?
Mar 05, 2010 | Sharp AR-M550U Copier
H5 flashing on the display, anyone tell me what the error is please? It's a Sharp AR-161 copier
H5 doesn't show up on the service code manual. However, all error codes beginning with 'H' are related to the fuser, this is the heating portion of the machine. Be careful if it still prints despite the error code, you may damage the unit. It should be looked at by a service rep.
Jan 12, 2010 | Sharp AR-161 Laser Printer
With a Sharp AR-M550U copier getting a CE-03 error when trying to email an image. Any suggestions on what the problem might be.
It means the copier is having ttrouble accessing the network resources to send the email. If you are still able to print to the copier without any problem then the issue will be with your email setting on the copier. Check to make sure you have the correct SMTP server info and the DNS and Domain info. Your email connection may also need authentication. If any of this info is incorrect it will give you this error. Was it working before ? Has your service provider or you changed your email information?
Dec 02, 2009 | Sharp AR-M550U Copier
AR-5132 Error code E7 13
CCD calibration error. Make sure the optics are clean in the machine in the scanner and free of dust.
Nov 03, 2008 | Sharp AR-5316 Advanced Digital Imager...
SHARP STAPLES
For the AR-M335U/455U-they are AR-SC2,5000 staples                            AR-M550U/700U,N-they are AR_SC11 staples                     They are a box of three. Hope this helps
Oct 17, 2007 | Office Equipment & Supplies
Sharp AR-M550U Copier Logo
2,041 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
