Question about GE Microwave Ovens
GE microwave tocuhpad doesn't respond to any keys
I have GE microwave (JVM 1540 DN1WW). Its tocuhpad doesn't respond to any keys now. Power is there in the microwave. Does it mean the keypad needs replacement? Thanks!
  • 572 Answers
Yes replace the keypad
Posted on Feb 06, 2010
Ge microwave oven key pad short circuited JVM 1540
see the next steps. God bless you
a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Oct 03, 2012 | GE JVM1850 1000 Watts Microwave Oven
GE Microwave JVM-1190WY Is always on with the door closed. Need to open door to shut down,. Is the power relay stuck on?? Do I need a new power relay?/ Joe Ziomek 305-664-1221
Please check your e-mail. I answered this directly.
Jun 20, 2011 | GE JVM1190SS Microwave Oven
Need manual
Hi
Thanks for using FixYa. Please see the link to download the manual for GE Space Maker JVM 1640SJ Microwave Oven---
GE JVM 1640SJ Microwave Oven Manual
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My jvm 1540 will not heat. any advice?
Hi
Thanks for using FixYa. Microwave not heating properly is caused by a power relay going bad, cold solder joint on the board and/or magnetron (this is only if it makes a loud hum/buzz sound). Also the door hooks and the door-release button should be checked. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
May 31, 2010 | GE Spacemaker JVM1540 Microwave Oven
GE 1540 handle...bottom fastener is broken. How
remove w putty knife the inter face. you can see the screws at this point ,. just remove screws and reinstall handle . pop interface back in **** . you can get a brake down of how this fits on sears web sight . **** / hope this helps ( it;'s not a hard job /time 1/2 hr / mm .
Dec 22, 2009 | GE Spacemaker JVM1540 Microwave Oven
Ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Jul 17, 2009 | GE JVM1430 Microwave Oven
Microwave Oven has no power.
yeah open the microwave, and you will see a fuse usually located on the top area. the is also a fuse around the back of the panel area.
Jul 02, 2009 | Microwave Ovens
GE microwave lights and fan do not work
If one of the surface light bulbs burnt out it may have shorted out the control board. Take the control board out and look for a burnt spot on the board. It may be able to be repaired with a drop of solder or solder in a jumper wire. Or you can purchase a new board, which may cost more than you want to put into the microwave.
Jun 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable stopped rotating.
this microwave has a turntable motor that can be accessed from under the micro.. usually a $15-30part.. put your modle number on partsdirect.com and you can see how it comes apart
Feb 28, 2009 | GE JVM1651 Microwave Oven
Ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Jan 22, 2008 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
380 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
