Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Control panel not responding to any commands. Refrig seems to be running at full cold. Temp according to thermometer 34 degrees. Indicated 38 degrees on panel.
  • Maytag Master
  • 8,220 Answers
That's gotta be a bad thermister. The ice box is cooling ok obviously so that means the controls are not in control! Some of these new fangled machines have as many as 6 thermisters. You need a repair manual bad to help you ID the whereabouts of these thermisters and how to check their OHM's values to determine which one is faulty. You can get a repair manual by going HERE
Posted on Feb 06, 2010
Have replaced the main control board, and all the control panel lights now work, compressor comes on, fan inside comes on, but fan at bottom of refrig does not. Checked all connections and all is good....
Set you refrigerator controls at their middle settings. Put a thermometer in both sections. Check after several hrs. Freezer temp should read near 0 and fresh food temp between 38 and 42 degrees. Those are normal operating temps on most refrigerators.
Mar 06, 2015 | Refrigerators
Food is starting to spoil more quickly than it should. The refrig temp on the door is set at 34 degrees which is the lowest it will go. The temp. on the refrig thermometer says it is 60 degrees. What...
You can get a small digital thermometer at your local hardware store for a pittance. ... For most refrigerators, this temperature coincides with the lowestsetting or one of the ... If your refrigerator is really full with items, lower the temperature a bit. ... they're not going to go bad because they were at 41degrees for a few hours.
Sep 12, 2013 | Samsung RF267AE (25.8 cu. ft.) Bottom...
I have a freezer top refrigerator in a rental unit of mine. It is only a few months old. My tenant said the freezer is working fine, but the fridge is not cold. He has tried putting the cold switch in...
Have him put a thermometer in a cup of water overnight and set the upper freezer
knob to the middle position and the temp control to midpoint. The refrigerator temp should
be between 34 and 38 degrees. You can get a thermometer at walmart or an appliance
parts store. If you continue to have the problem then change out the defrost termination
thermostat (this was a common failure in many of my frigidaire units). It is located in
behind the freezer back panel, it is clipped to a tube and has two wires coming to it.
Remember to unplug unit before servicing. The part is under 20 dollars usually.
The model number is located in the fresh food compartment on the left side. Hope this helps
Apr 25, 2011 | Frigidaire Refrigerators
Fridge too cold
all food in refrig freezing?
Jul 09, 2010 | Viking 42 in Built In Professional...
Frigidaire refrigerator with a broken freezer
He is correct. The temp in the refrig controls how often and for how long the refrig runs. Lets say the temp in your garage is 34 degrees, and you have your refrig set to 36 degrees: The refrig will never run, the fresh foods section will cool to 34, and the freezer will warm to 34. Even if the temp is 45 in the garage and you set the fresh foods to be 33, the refrig will not need to run long enough and often enough to keep the freezer temp cold enough. You will most likely need to have the ambient room temp at least 55 degrees to get satisfactory refrigerator performance. Insulating the refrig will not help. (by the way, outdoor beverage vending machines use an internal heater in cold weather to prevent liquid beverages inside from freezing,..... so using that info, you could put a low wattage heater in your refrig to make your refrig run enough to make the freezer section work. The %&#* with that, just move it into the house!)
Feb 06, 2010 | Frigidaire FRT17B3A Top Freezer...
What temp should the fridge and freezer each be?
According to FDA safetey specs bacteria can grow at 40 to 140 F degrees .Refrigeration must be below this number but above 32F to keep from freezing. I maintain commercial refrigeration and they run at 34 to 38 F degrees. I have deep freeze set at -10F which keeps ice cream very solid but can go up to +2 F which renders softer ice cream...
Jun 25, 2009 | Kenmore 64802 Top Freezer Refrigerator
642s Temp Setting Does Not Work
Possibly, but check your condensor before calling for service.
May 28, 2009 | Sub-Zero 642
Thermostat problem
is the refrigerator section is freezing up
Apr 04, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Never shuts off.Too cold
Try defrosting.
if you can move everything out unplug ,turn it off w/ doors open 6 to 12 hrs this will free up any clogged tubes. Set it at a low setting and keep an eye on it, If this doesn't work your thermostat may be going out.let me know.Good luck.
Len West
Feb 16, 2009 | KitchenAid KSRS25IL Side by Side...
Cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
cabinet.
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
hours.
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
dial.
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Jan 31, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
42 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
