Question about Panasonic CT-32HX42 32" TV
Tv won't stay on
My tv comes on, the power light comes on, but it won't stay on, it goes off by itself a few seconds later. Is there a solution to this? Same problem. The TV clicks, the light comes on, the normal power-up buzzing sound... then another click and the light goes out. Black screen the whole time. I have tried unplugging and waiting for 5 to 10 minutes, but the reuslt is always the same. Bought the set in 2002. Until now, it has been wonderful.
    Genius:
  • 3,422 Answers
Hi Yocam,
solid state devices usualy fail at turn on or turn off time so it is possible for a part to fail at this time and the set worked fine earlier in the day
one thing you could try doing is unplug the tv for 30 mins or so then plug back up and restart it up and see if it works.
If it does not then you could take the back off and check the fuse and see if its blown if so you may want to change it and see what happens.
some times a fuse does just fail
but usually there is a reason for the failure.
Another thing is that it must be going into the protection mode to avoid any further damage to the internal circuits.This is possible if you had a power outage.Replacing the fuse can solve this sometimes if i is not a major problem.
Finally i would recommend you to get it repaired if you problem doesn't get solved since that is the only solution to fix it.
Goodluck..
Posted on Feb 21, 2008
  • Priya darshan Feb 21, 2008
    The repair will cost you anything between $250-$300..
    But it is worth a repair so that you don't face any more problems in the future..
  • 689 Answers
There is excessive current in circuit, Circuit protection cuts down the power to avoid over-heating and hazardous result. Best thing to have hands on technician
  • ExpressFiX
    ExpressFiX Feb 21, 2008
    Power components like Transistors and MOSFETs stops their performance after a period of time. Time to replace the malfunctioning component. I believe component itself will not be costly however hands on service charge might be added on.
Tv will not stay on
Tv won't stay on - Fixya
www.fixya.com/support/t101679-tv_stay
Tv won't stay on My tv comes on, the power light comes on, but it won't stay on, it goes off by itself a few seconds - RCA F27450 27" TV question. ... My TV will notcome on, when I hit the power button the green light flashes but the ..... Please do Note: The front panel buttons must be used, NOT those on the Remote Control.
Why won't my TV stay on? ' Yahoo Answers
Nov 14, 2015 | Symphonic ST420FF 20" TV
TV won't turn on
Before going OFF, the standby LED might blink. These blinks are fault indication. The number of blink should be counted. Count the number of blinks at one time, before the TV goes OFF. [eg: 4 blinks Power SOS P Board; 6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)] and so on. you can get more details from this site named 'Electro-help'. You can reach it by searching the keyword "electronicshelponline" by internet.
Jul 03, 2012 | Panasonic TC-P50X1 50 in. Plasma HDTV
Mitsubishi hdtv
NOT A GOOD IDEA AT ALL!
You likely now have one of two things happening:
1. Green power light constantly blinks and will not stop(should blink for 70 seconds and go out).
2. Green power light comes on and a few seconds later goes off.
Which do you have?
May 17, 2012 | Mitsubishi Televison & Video
My hitachi plasma tv model: p55t551 every time i
turn tv on the red power light comes on then goes off again
Jun 27, 2010 | Televison & Video
Protron TV, YHI power adapter goes off after a few seconds.
Sounds lika a bad power adapter. I've been repairing them for $60. Let me know if your interested. dave@thola.com
May 09, 2009 | Protron PLTV3250 32 in. LCD Television
Tv won't stay on
Hello mrscarpenter,
This is a common problem with the ITC222 chassis, I would check CP120, CP140, CP150 to see if they are bad I suspect CP150 is the one that is bad. Its value is 2200uf 16VDC. It is located on the same board as the IHVT and is in between the Heat sink in the middle of the board.
I hope this helps,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 04, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv won't stay on
hello,
After further inspection, I believe that you have a blown convergence IC. Most posts point for two IC's. I only have one. STK393-110. There are 12 - 3.9ohm 2w resistors around it . I think they may be bad as well. The 2 Pico fuses feeding that circuit (+24/-24) may be open also.
So, with that said...... Think we have the problem cornered?
MENACE1275
Oct 13, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Tv won't stay on
MY SAMSUNG 27# MODEL TXT27820 ONLY NINE MONTHS OLD SHUTS OFF BY ITSELF AND WILL NOT START AGAIN
May 10, 2008 | Samsung TXJ2754 27" TV
Tv won't stay on
i have seen this before and it may be the front power button being stuck and when your remote turns it on the stuck button turns it back off again. I have an older mitsubishi that will not boot up right sometimes and i have to unplug it and plug it back in fot it to come on. I used to pick up broken tv and fix the power buton and resell them
Mar 27, 2008 | Televison & Video
Tv won't stay on
it is a brandnew tv, so expected that it is under warranty,, it best for you to return where you bought so the warraty will not void. Big possible of factory deffect.
Dec 26, 2007 | RCA 20F420T 20" TV
Panasonic CT-32HX42 32" TV Logo
210 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
