Question about Motorola Mobility RAZR V3
When i open phone flip to answer,they can hear me but i cant hear them immediately. i usually i have a 5 to 10 second delay
How can I get the telephone on my Brother Fax T96 to work?
Step by step information at the link below.
Brother Fax T96
The F/T Mode is used to allow the fax machine and the telephones to share the same telephone line. When a call comes in, the fax machine and all extension telephones on that line will ring according to the number of rings you have set for the Ring Delay.
When the Ring Delay is completed, the fax machine will answer the call and determine if it is a fax call or a telephone (voice) call.
The fax machine can determine this by the signal it is receiving on the telephone line. If someone is sending a fax automatically , the sending fax machine will transmit a fax tone (a series of beeps every 3 seconds).
If your fax machine hears these tones, it will receive the fax.
If the fax machine does not hear any fax tones, it assumes it is a telephone (voice) call and will begin ringing the F/T ring tones (double ring) for the length of time you selected for the F/T Ring Time. These tones will only ring on the fax machine's handset (extension or external phones will not ring). At the end of the F/T ring time the fax machine will go into the receive mode in order to receive a manual fax.
(If the call was a voice call and was not answered, the caller will hear the fax receive tones also).
  • If you answer the call before the fax machine(during the ring delay period) and determine it is a fax, you can transfer the fax to the fax machine for receiving.
  • If you answer the call on an "extension" phone and hear a beep every 3 seconds (automatic fax) or silence (manual fax), press *51 or *91 for New Zealand (remote activation code) on the telephone keypad, wait to hear the fax machine turn on (chirping sounds) and then hang up.
  • If you answer on the handset of the fax machine and hear a beep every 3 seconds or silence, press the Fax Start or Start/Copy key on the control panel of the fax machine and then hang up the handset.
  • If you answer a call on an "extension" phone during the F/T Ring Time, you will hear the F/T ring tones.
    To release the call from the fax machine, press #51 or #91 for New Zealand (remote deactivation code) on the telephone keypad and you can speak to the calling party.
  • If you pick up the handset of the fax machine during the F/T ring time, you may talk to the calling party immediately.
Mar 28, 2011 | Office Equipment & Supplies
My motorola v8 screen wont turn on, it was working fine then i went to open it again and the screen is black. it vibrates for texts and calls, i can answer them but i can't hear the other person but they...
it's a flex problem.This is a common problem with flip phones.
The flex usually worn out due to constant opening and closing of the phone.
You need to replace the flex in other to solve this problem.
As for the hearing problem, there are two things involved:
1. Is either the ear piece is bad and needs to be replaced.
or
2. It's still the same flex problem.
Take care.
Mar 09, 2010 | Motorola Mobility RAZR2 V8 Cellular Phone
Sound problems with the W380i sony ericsson
my sony Ericsson T303 is asking me for puk code,how do i go about getting it,thanks.
Dec 25, 2009 | Sony Ericsson W380i Cellular Phone
When ringing someone the phone doesn't ring out. the other person can hear me but i cant hear them for a few seconds can you help me please.
Try to see if you have a connection to a bluetooth, also make sure you arent connected to any other device, especially if you used a cord to retrive photos or d/l ringtones Allows you to set the Bluetooth® power On/Off.
1. Open the flip, then press [MENU] bluetooth menu options, turn on or off
2 try menu settings and tools, call settings,pc connections, usb, no connection
Nov 24, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
None of the keys work on my motorola v9 except the on and off button.when i flip it open it open it ask's me to enter SIM PIN but i cant type anything in
Try the menu to dead the keys, in the same menu/photo where you turn off the answer by flipping it open or using the on key.
Aug 11, 2009 | Motorola Mobility RAZR2 v9 Cell Phone
Disable v-cast key
With the phone closed, hold down the multi-function button on the lower-right side of the phone for a few seconds; that will lock all of the buttons on your phone until you either a) open the phone, or b) hold down the same button for another few seconds to unlock the keys.
To the best of my knowledge, there's no way to set the button to ALWAYS be disabled when closed; you have to lock it every time you close the phone.
NOTE: Locking your keys can create another problem, at least on my phone, where I've disabled the option to anser a call by flipping it open (I prefer the option to view the caller and ignore it if it's not a priority). When I receive a call with the phone locked, I have to wait a few seconds after flipping the phone open before pressing the "answer" key; if I answer too soon after flipping it open, the phone tends to lock up for about 30 seconds, which obviously kills the call.
Apr 07, 2009 | 2007 Toyota Avalon
When someone phones me, the phone doesnt ring it just vibrates. but when i answer they other person can hear me but i cant hear them. My phone is a Samsung S401i
I know it's a flip phone and I am not familiar with this model, but sometimes the <--> button on the side is pressed by accident, this can adjust the volume [*during a call*] up or down.
Sep 08, 2008 | Samsung Cell Phones
Answering Delay.
get a TORX 6 screwdriver
WIggle the tiny flex cable connector
near the hinge.. still no luck ????
Buy another V220 on ebay
gently take the phone apart and sub in the whole
screen shell and front of keypad.
DO NOT TRY TO remove the screen from the body section..
you will destroy to the teeny tiny flex cable.
Google for V220 take apart/ disassembly
Jan 18, 2008 | Motorola Mobility V220
Ring Tone Won't Stop
I had this problem with my old phone, it was a Samsung Sch-950 I recently upgraded my phone and new phone doesn't do it so I don't have an answer other than to get a new phone.
Oct 26, 2007 | Motorola Mobility H350 Wireless Headset
Motorola Bluetooth HS850 Pairing Mode
was soooo helpful just make sure u do flip it open immediately after, thats were i messed up... Thk
Sep 16, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility RAZR V3 Logo
24 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
