Tell me about overheating - Computers & Internet
    Sniper:
  • 105 Answers
Overheating is generally cause by a clogged or dirty cooling fan. To clean the fan out I generally use some compressed air and a vacuum. Simply locate the cooling fan output on the outside of your laptop (usually on the left or right side of your laptop and sometimes the intake part of the fan is on the underside of the laptop). Once you locate the input and output of your fan turn off the laptop and blow the compressed air into the input and output and for extra cleaning I always take the hose of my vacuum and vacuum both input and output ports of the laptop. If you want to go deeper into the laptop and clean it on the inside here are several sites that can help you get into your laptop safely and easier (I assume no responsibility for any damage that you may cause to your laptop)
How to Upgrade, Repair, Disassemble an ACER Laptop or Notebook
Cleaning your acer laptop
Dissemble Laptop
take apart an acer
Photo gallery of taking apart different acer laptops
Be warned: i take NO RESPONSABILITY for anything you will do with your notebook following my instructions. I mean, I own this notebook and that's what i did. Nothing else. No warranty of any type. You're on your own.
Posted on Feb 07, 2010
  • 12,061 Answers
Overheating is a bad problem. All electronic devices create heat, it is a byproduct of resistance to the electrical flow. Many methods are used to combat it, from Fans to heat-sinks to special gel filled packs. Most devices operate "Hot" and a certain amount of heat is to be expected and designed for, indeed we have an "Operating Temperature" however it is the "Excess" heat we try to remove. Also, when a device heats up and cools down it is subject to "Thermal Shock" or, whereby, as all things heat up they expand, and when they cool, they contract, this repeated cycle, can & will, cause devices internals to "Fracture" just like when you bend a piece of metal backwards and forwards until it snaps, same principle. . Also too high a temperature over a long period will cause the device to simply fail. Also most devices will/should have temperature shutdown circuitry, that will shut off power to the device, when & if the temperature rises beyond a certain point. generally you can never have it too cool. So really anything that is done to remove heat and cool things down is only of benefit.
Posted on Feb 06, 2010
  • 102 Answers
Overheating usually occurs when the vents are obstructed or full of dust.
Overheating causes that laptop to slow down in terms of processor speed, if the laptop overheats too much then it will shut down to protect itself from damage.
Overheating
Overheating can have different resons.
Learn everything about overheating :
What to Do If Your Car Overheats
5 Ways to Tell Your Car is Overheating
How to Stop an Engine from Overheating
Why Is My Car Overheating
You can get much more information about oveheating doing a google search for
OVERHEATING IN CARS
Sep 24, 2015 | Cars & Trucks
What can cause my gauge to rise to hot but it does not over heat.on a 2000dodge grand caravan sport.
How do you know it is not overheating. It may very well be overheating but it has not blown a tube or gasket yet to have that tell tale sign of steam coming form the engine compartment. Careful about driving with an overheated car as you can do some serious and expensive damage to your engine.
Mar 24, 2015 | Cars & Trucks
How can you tell if the clutch fan on a 2002 dodge ram 1500 slt truck , 4.7L is gone ore = not
Sorry to say, but these are classic symptoms of a failed head gasket. Those bubbles are probably exhaust. Check the oil as well, coolant could be leaking into it. There are test strips that can verify this by dipping the coolant.
Feb 20, 2018 | Cars & Trucks
How do i tell if my overheating problem is the waterpump on my 2.0 l '96 contour?
remove coolant thermostat and run vehicle if overheating occurs waterpump is problem
Apr 12, 2012 | 1996 Ford Contour
Vehicle is overheating, leaking anti freeze heat not working
Fix the leak then change the thermostat, and it will stop overheating. If there is more to the story than you are telling us, then here is an article that will tell you how to diagnose an overheating Toyota.
Dec 09, 2010 | 2001 Toyota Echo
How can i tell if my engine runs hot I have a
just make sure all the vains are clear of any grass clippings that may have gotten caught in them. i wouldn't worry about it overheating as i have never heard of them overheating just as long as the vains are kept clear
Apr 09, 2010 | Garden
I have a 2003 Hyundai Tiburon that is overheating. How can I tell if I have a bad water pump or if it could be the thermostat. Does not appear to be a radiator leak or hose leak, but I am constantly...
If it's overheating it will lose antifreeze.I would change the thermostat first and see it it solves the overheating problem if not then worry about the water pump. Thermostats are only $7-10.
Dec 24, 2009 | 2003 Hyundai Tiburon
My 97 Riviera is Overheating
Head gasket is gone...don't forget to have the head checked for cracks and warpage before putting it back on. Check it over for leaks to see if anything else needs repair before driving it again.
Jun 15, 2009 | 1997 Buick Riviera
Overheating
Its pretty easy to tell when your laptop is overheating. Youll have those tell-tale red marks on your legs from where the hot bottom of the laptop has been resting against your legs.
Fortunately, most laptops will automatically shut down if they are over heating to prevent any further damage to hardware like hard drives and motherboards.
If you would like to know the running temperature of your laptop, download this little utility.
Hope this helps,
TJ
Dec 15, 2008 | Toshiba Satellite A35-S1592 Notebook
Computers & Internet Logo
934 people viewed this question
David Payne
David Payne
