Question about Panasonic DMR-E50 DVD Recorder
My rear wire-less speakers for the SA-HT65 unit have stopped working? all connections are fine and no other wire-less sources are on. Is there something our little fulla might have hit on the remote to cause this? as the red light on the wire-less unit is on but no noise, have exhausted all possibilities, pleaaase help!!!!
  • john_w_c Feb 08, 2010
    Thanx for your time but still no joy, all connections are fine and all other speakers are working good which leads to wonder if our little boy has pressed a button on the remote or something, he's into everthing! have read the manual to try and reset the unit to factory settings but this is a little hard as the display doesn't work cause of an extremely hot day we had afew months back, must of cooked the LCD display.
    Is there a way to find out the right sequence of buttons to press to activate the reset feature????
  • john_w_c Feb 10, 2010
    hEY SOUNDS LIKE YOUR GIVING ME ADVICE ON HOW TO CHANGE RADIO STATIONS AND SUCH... THIS IS OF NO USE TO ME AT ALL.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. You’ll need to check the speaker connections, turn the volume up and check that the muting is off. Please also make sure that the speaker cords are not sorted.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 07, 2010
  • Rylee Smith
    Rylee Smith Feb 08, 2010
    For automatic presetting,
    you’ll need to tune to the frequency from where presetting is to be started. Now
    press and hold memory. Release the button when the frequency begins to change. The
    stations are preset into the channels in ascending order. The last station to
    be preset is played when presetting is complete. For manual presetting you’ll
    need to preset the station one at a time and press memory. Tune to the required
    frequency and again press memory. Now press tuning down or up arrow to select a
    channel and press memory again. The station occupying a channel is erased if
    another station is preset in that channel. As the LCD display has gone bad it
    means that one of the capacitors on power supply board are gone bad and you’ll
    need to replace it.
    Please do
    assistance.
    Thanks
    Rylee
  • Rylee Smith
    Rylee Smith Feb 10, 2010
    I was telling you on how to reset it, if still it wont work and as the LCD display has gone bad it means that one of the capacitors on power supply board are gone bad and you’ll need to replace it. Getting it repaired will cost you same as buying a new one...as new ones are available for around $50. Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
I need a remote for as-ht70home theatre
Here is one on the Bay
PANASONIC Remote Control for SC HT70 SC HT65 SA HT70 SA HT65 Free Shipping
Couldn't find factory new available. Best bet may be a universal.
Jan 06, 2015 | Audio Players & Recorders
Ouku single din no sound from rca cables
Sorry I did not use the video out RCA cables. My audio RCA cables worked fine... I ran them to my JBL amplifier through a conversion adapter. I did not run it direct to the amp.. I used Metra TYTO-01 03-08 Toyota Vehicles Harness for JBL SYS (Ebay item 160560648718) and it worked great.
Here is the wiring color coding that I found online:
Code on stereo for steering wheel is 0000
2011 Toyota Camry Car Audio Installation Diagram
F6 Pins:
1.Light Green (LG) Front Right (FR) plus (+) speakers source
2.Pink (P) Front Left (FL) plus (+) speakers
3.Grey (GR) Accessory power [switched on with the ignition switch] +12v
4.Light Blue with Yellow Stripe (L-Y) always +12v [radio memory]
5.Light Blue (L) Front Right (FR) minus (-) speakers return
6.Violet (V) Front Left (FR) minus (-) speakers return
7.Brown (BR) Ground (GND) radio ground
8.Orange (O) Antenna Amplifier (ANT) power source
9. No Connection
10.Green (G) Night Lighting [+12 when the taillights are turned on]
F7 Pins:
1.Red (R) Rear Right (RR) plus (+) speakers source
2.Black (B) Rear Left (RL) plus (+) speakers source
3.White (W) Rear Right (RR) minus (-) speakers return
4.No Connection
5.White Black (W-B) Lighting Intensity [Pull down circuit, voltage level drops {Bright Dash Lights}or raises {dim Dash Lights} Caution with this one, DO NOT CONNECT DIRECTLY TO +12 VOLTS, you will mess up your instrument panel cluster.
6.Yellow (Y) Rear Left (RL) minus (-) speakers return
F8 Pins:
1.No Connection
2.No Connection
3.Violet (V) Speed Pulse Connection (SPD) [Pulses from the speed sensors applied here. This is for the automatic sound level system. The volume raises when the speed is above a specified level, if enabled.]
4.No Connection
5.No Connection
6.Pink (P) Steering Wheel (Switch) Ground (SWG)[common]
7.Orange (O) Steering Wheel (Switch Group) one (SW1) [source for Seek+, Seek-, Volume+, & Volume-]
8.Yellow (Y) Steering Wheel (Switch Group) two (SW2) [source for Mode, (if equipped On Hook, Off Hook & Voice)
9.No Connection
10.No Connection
11.No Connection
12.No Connection
13.No Connection
14.No Connection
15.Orange (O) Auxiliary Right Input (ARI)
16.Brown (BR ) Auxiliary Shield Ground (ASGN)
17.Red (R) Auxiliary Left Input (ALI)
18.No Connection
19.Green (G) Auxiliary Input [Sense](AUXI)
20.No Connection
Car Radio Battery Constant 12V+ Wire: Blue/Yellow
Car Radio Accessory Switched 12V+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: N/A
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Tweeter Size: 3 1/2? Tweeters
Car Audio Front Tweeter Depth: 2?
Car Audio Front Tweeter Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Apr 02, 2014 | Crown Ouku 7" Car Dvd Player
Overload
Probably dry joints around the power amplifier.
Mar 18, 2017 | Technics SA-AX720 Receiver
Fan Unit Replacement for SA-HT65?
replacement fans are on ebay, you need to measure the fan, how many wires. etc or do a search of the fan number that is on the fan itself. as long as the fan is the same size from fixing hole top left to fixing hole bottom right and the right voltage and wiring it will work as a cooler fan in the device.
Jun 30, 2017 | Audio Players & Recorders
I have recently purchased a panasonic sa-ht65 receiver and speaker pack. when i turn the unit on it displays 'overload' and turns itself off. i have let it sit for a couple of hours but still not...
If it has never worked maybe your speaker connections are shorting.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it '*****'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Aug 06, 2011 | Panasonic SC-HT65 System
Installing aftermarket Kenwood stereo on 1991 Subaru Legacy. The subaru stock wiring does not have a red ignition wire. Can i simply connect the kenwood ignition wire to the Accessory +12v (Yellow/red)?...
Hi, according to my source, there should be an accessory wire that is blue with a yellow stripe. If your is yellow/red, that's fine. You actually should prefer an accessory wire to an ignition wire as there may be less static on the accessory wire. Just make sure the wire does not have power when the key is off. Don't use the illumination wires--they are not needed for the aftermarket head unit and should be taped off.
1991 Subaru Legacy Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red/Green
Car Radio Switched 12v+ Wire: Blue/Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Front Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Yellow
Left Front Speaker Negative Wire (-): Blue/Red
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Blue/Black
Rear Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Yellow/White
Left Rear Speaker Negative Wire (-): Blue/Red
Right Rear Speaker Positive Wire (+): White/Blue
Right Rear Speaker Negative Wire (-): Blue/Black
May 31, 2011 | Car Audio & Video
I have a Panasonic SA-HT650 Home Theater system that has stopped working. The panel code is F61
A power source problem. Means there is voltage measured at the output/speaker cable connections. Indicates a failure of the amp., or faulty power supply to it.
Just re-check all of your connections, especially speakers. And that the power ac power source from the wall is wired correctly and has proper voltage and grounding.
Apr 07, 2010 | Panasonic Home Theater System System
The system worked fine but has an intermittent connection in the main power tower unit..you can shake the unit or bump it heavily and the sound from the main tower speakers goes and comes with a lot of...
They are prone to bad solder connections on the power regulators and output ics. should only be a labor charge. est $60 -100
Not very easy to take apart, need to remove several screws on rear of unit, remove front grill remove some screws on front. disconect connectors remove amp and power supply board, resolder bad connections and re-assemble. I've done several would take me 30-45 min.
Nov 12, 2009 | Sony SA-VA1 Rear Speaker
Problem with subwoofer and one off the speakers.
check out the amplifier ic in the receiver unit of subwoofer as the number of ic is IC346JC this has to be replaced.
Mar 13, 2009 | Technics SA-DX940
Panasonic DMR-E50 DVD Recorder Logo
55 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
