Question about JVC Televison & Video
I have a JVC AV-48P776. TV refuses to turn on after power outage.
I have a JVC AV-48P776. The power flicked off in my house with the tv running. Now the tv will not turn on. No indicator lights or any sounds when I attempt to turn it on.
  • 1 more comment
  • sticks82 Feb 06, 2010
    I checked the fuse (printed under it was F801 125V 7A). It unfortunately looks fine clear glass and the wire appears to be intact. The power cord itself seems good as well. I simply used an electric tester on where the cord enters the tv and it shows power.
    No, the light doesn't light up on the front of the tv either. Don't think I feel comfortable messing around on the power board. Sounds like I'm gonna have to have someone look at it. Figured it was worth a try to see if there was something I could do. Thanks for all your help, much appreciated.
  • sticks82 Feb 07, 2010
    Thanks for the help. 4 thumbs up!
    Top Expert:
  • JVC Master
  • 14,553 Answers
This is a model first made in 2005. Follow the ac power cord into the set (unplug it first from the wall etc) and it will lead you to the glass fuse. JVC QMFZ049-5R0Z-E F905 FUSE, 5A 125VThis is the part number and F905 will be printed on the board next to the fuse which is 5 amp. If you are lucky the fuse just got surged out when the power came back. Some advice--do not buy a "generic" fuse like at Radio Shack--they will not work most of the time and blow for no reason--this fuse looks normal but you want one like it that is slow blow or thermal--most TV shops or parts dealers will have something not generic--brands like littlefuse etc. Check the fuse first--if it is blackened or the wire inside the glass broken you have found your likely problem. If the fuse is good further testing with a volt meter will be needed. Let me know what you find---I am here to help. SD TECH
Posted on Feb 06, 2010
  • 1 more comment
  • SD Tech
    SD Tech Feb 06, 2010
    This may be beyond a do it yourself repair--what is needed here is to go further into the power board and see if voltages are present--
    Does the power light on the front of the set not even light up?
    SD TECH
  • SD Tech
    If possible look for a shop that does JVC authorized repairs--they will have access to schematics and info on the JVC technical site---small shops will not have this and may only guess as to what the problem is.
    I will be here if you need help or advice.
    Regards, SD TECH
  • SD Tech
    SD Tech Feb 07, 2010
    If you are satisfied I did help you in some way you can rate this 4 thumbs up and I will get credit for having assisted you.
    You will still be able to return if you need more help or advice from me.
    SD TECH
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
How do i get my HDMI to work on my JVC model av-48p776
Please make sure your TV in on correct channel by pushing INPUT and select [Digital IN]
Jan 31, 2015 | JVC Televison & Video
How do i find HDMI on my tv
Look on your remote for an "input" button, keep pressing until you get to "digital in" this is HDMI input!
Jan 12, 2015 | JVC Televison & Video
I look for the Hdmi with remote going through input and can't find
Check out this page
http://pdf.textfiles.com/manuals/STARINMANUALS/JVC/Archive/AV-48P776,%20AV-56P776.pdf
Could be that the pixels on the Ipad are set to high for the TV at the bottom left it shows what the pixals are accepted.
May 01, 2014 | JVC AV48P776 48" CRT TV
Av-48p776 rear projection jvc. power surge from a lightning storm
You will need to replace the convergence chips located inside the set. Typically a repair shop will charge 150-250 to fix it. Good luck
May 16, 2009 | Samsung HC-P4752W 47" Rear Projection...
Albert
albert
thaks for you i.m
I found the solution I repleased coil ( L531 ) and the tv looks like new
Nov 23, 2008 | JVC AV-48P775 48" HDTV
JVC 48" AV-48P776
no se ve bien los colores jvc 48 776
Nov 02, 2008 | JVC AV-48P775 48" HDTV
Tv wont power up makes a noise but no picture
Your power transformer is likely shot. It'll cost at least $200 to have it replaced. Someone can come to your house to diagnose it. Usually costs around $65.
Nov 03, 2007 | JVC AV-56WP74 56" Rear Projection...
Televison & Video Logo
61 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
