Question about LG Heating & Cooling
REMOTE control functions, my model is an LG LSZ122M-4 and I do not have a book and have no idea of remote control function, not cooling and no adjustment possible
    Guru:
  • 415 Answers
Hi Chris,
Your best bet is to read the owner's manual first. This will have user and troubleshooting information. I found the manual on LG's website. I had to install some ActiveX controls from their site to view the manual. It took less than 2 minutes. I'm attaching the link at the bottom. Check it out and let us know if this helped you with your problem. Good Luck!!! :-)
http://www.lge.com/au/support/product/support-product-profile.jsp?customerModelCode=LSZ122M-4&matchedModelCode=NOT_MATCHED&searchEngineModelCode=LSZ122M-4&initialTab=documents&targetPage=support-product-profile#
Posted on Feb 07, 2010
Testimonial: "Spot on info and thanks for your assistance, at the LG home page it did no except the model number as a good model."
26LC7D-UB Can my LG remote be reprogramed to the TV?
If new batteries correctly installed do not revive your LG remote control, it probably is shot.
May 17, 2018 | LG Televison & Video
URC 7110 key functions
you can download another remote control and get some idea
go www.fitness.manualsonline.com
God bless you
Jan 29, 2013 | One For All Televison & Video
Hi i need to find a sky plus code 47lh300-za for this LG TV can you help?
Hello
Setup codes for LG TV with Sky are:
065 244 405 318 037 398 191 459 245 389 060 275
065
742
743
726
508
584
Follow the steps below
1* Select any channel on the TV.
2* Point your Sky+ remote control away from the TV and press the tv button.
3* Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4*Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5* Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Jul 21, 2011 | LG 47LH3000 LCD TV
Sky remote control code needed for lg tv - model 37lk450
Hello
Setup codes for LG TV with Sky remote are:
065
742
743
726
508
584
1*Select any channel on the TV.
2*Point your Sky+ remote control away from the TV and press the tv button.
3*Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button. If this works try the other TV functions.
Please note:- in der to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
Jul 16, 2011 | Televison & Video
Do you know the sky+ remote code? So I can operate the volume control on the sky+ remote. I've tried loads already hope you can help.
It would help to know the model number of your LG TV. However, you can try the generic codes for LG which I've listed here:
Rev 8 remote: 1293, 1206, 0206, 0065, 0904
Rev 6 remote: 0065, 0742, 0502, 0672, 0634, 0136,
Rev 4 remote: Same as Rev 6
RC1600/00 remote: codes not available and unlikely to work with your TV
** Your Sky remote version can be found on a sticker inside the battery compartment. **
Try these codes but if they don't work, please post back with your TV model number. It's possible that your remote does not have a code which will work with your TV, in which case, you will need to use the remote supplied with your TV to control volume and power functions. Unfortunately, when a TV is newer than the remote and uses a new flash pattern not programmed into that remote, the remote wont work. However manufacturers often keep the same flash patterns for common functions, so the generic codes might work for you.
I'm informed that a new Sky remote version is due but I've not been able to confirm this yet.
Hope this helps - please post back if you need further assistance.
Regards,
BElectric
Nov 25, 2010 | LG Televison & Video
Trying to set up sky remote with TV (19LG3000)
The Sky Remote Code 1280 worked for my Sky+ box
Dannyboi1940
Nov 24, 2008 | LG M1910A 19 in. LCD Television
I am trying to find a universal remote code to control the new Zenith digital tv tuner converter box. The model # is DTT900. It is for a person with low vision who cannot see the buttons on the remote...
Pls post back with the brand and model of the universal (replacement) Remote Control or what remote control you would want to use with the Zenith DTT900 Digital-to-Analog Converter Box.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 23, 2008 | Televison & Video
Lg artcool 12000btu mirror model
1.check remore battery.if week change it
2.check indoor unit sensar of remote.
3.check sirkit board.
Mar 09, 2008 | LG Art Cool LA1000PR Air Conditioner
Lg remote control
one or more of these codes will give you basic functions. no set of codes will allow you to duplicate full functionality with another controller. you will need the original remote to be able to program advanced settings.
0807, 0022, 0020, 0422, 0122, 0222, 0322, 0002, 0520, 0919, 0521, 0621, 0430, 0247, 0901, 0402, 0408, 0109, 0210, 0310, 0715
good luck
mark
Dec 23, 2007 | LG 42LC2D 42 in. LCD HDTV
Heating & Cooling Logo
255 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
