Question about Hoover HTC243 Top Load Washer
Water problem with Hoover 550M top loading machine
Water when filling does not always shut off when it should resulting in a mini lake in laundry.This problem is not constant but as you can imagine once is more than enough.
4 Suggested Answers
  • 1462 Answers
SOURCE: hoover washing machine top load, model 550m.5.5kg
water leak from cold hose nothing to do with other problem. tighten hose connection and fit a new hose washer overfilling probably because air chamber blocked. remove lid. you will see a pressurestat somewhere at the top - usually round with anything from 3 to 7 wires and a small tube underneath. follow hose down and it connects to the air chamber. make sure this is free of gung and check hose for splits and has no blockage. to check the pressure stat itself, attach your own hose to the stat and while machine in fill mode, blow down this hose and you should hear a click and water intake will stop
Posted on May 04, 2007
part No: 47841-405 hoover washing machine
Posted on Aug 31, 2008
dcramer531
  • 1654 Answers
SOURCE: Hoover 550M washing machine - taking ages to fill,
Check the inlet screen on the hose connection on the back of the machine. This may be clogged with debris, also make sure you hose is not crimped. You can unhook the inlet hose and put it in a bucket and turn it on to see how much water is actuall coming thru that hose. I suspect some type of blockage in the inlet.
Posted on Nov 11, 2010
Hoover Elite 920 top loading washing machine will not fill. I can manually fill the machine and it will run through a cycle until fill is required for rinse cycle and then I have to manually fill again I...
first check the water is switched on to the machine. If it is then you most likely have a faulty water valve. Switch all power off and remove the top panel should be 4 screws or so. If it has 1 valve then replace it.
Mar 09, 2011 | Hoover Washing Machines
How do I fix a hoover 550m washing machine not is not pumping water to drain out and empty the wash bowl. Everything else works fine
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Feb 20, 2011 | Hoover HTC243 Top Load Washer
Hoover 550M washing machine - taking ages to fill, water is just dribbling out. Was fine when started, lifted lid to put in clothes and now only dribbling out. Water pressure in rest of house seems to be...
Nov 11, 2010 | Hoover HTC243 Top Load Washer
I have a hoover 550m top loaderduring the spin cycle the drum has droped on one side I managed to to get rod reconnected but after 3 wash loads it has drop off again? how do i fix it proberly
you will have to purchase a new suspension rod support sounds like yours has broken spare parts supplier should help you good luck
Jun 22, 2010 | Washing Machines
The water does not always shut off and the machine fills even when turned off.
HI, this is the result of a faulty inlet water valve assembly. it should be replaced asap.
Jul 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hoover Premier 710 - always fills to capacity (can't adjust water level).
my one the same, I just adjust the water level switch to 60% then it work on full level, but no flood,I hope this help :)
Apr 30, 2008 | Hoover HTC243 Top Load Washer
Hoover washing machine top load, model 550m.5.5kg
May 04, 2007 | Hoover HTC243 Top Load Washer
Hoover HTC243 Top Load Washer Logo
44 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
