Question about HP Pavilion dv9000z Notebook
Blank dim screen only - no functionality . This must be a fairly common problem from reading some of the posts
  • HP Master
  • 2,517 Answers
Hi there, please restart your laptop when its booting press F8 key . You will find few option asking for selection. Select that by using up/down arrow key. Select " Last know good configuration" & press Enter. Next page asking for selecting operating system, for example: windows vista or Windows XP etc. Just select the operating system & press Enter again. ( Hope your laptop showing only one operating system ). Your laptop will start normally. After the if you seen the screen dark then press FN+Right arrow in key board(>). When you press FN + ( </ ) or ( >) key that's time its working for brightness controlling for screen. Now if all well then fine other wise please let me know .
Another suggestion is run your HP driver DVD for installing Display drivers. When finish restart your laptop and watch whats going. If no success then format the Operating system & reinstall again.
Thanks & waiting for your feedback
Posted on Feb 06, 2010
X241W Acer monitor: getting blank screen. When unplugged and plugged back in, it powers up, stays on for about 10 seconds, then goes blank again. Green power light stays on. Have connected to different...
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 15, 2010 | Acer X241Wsd Monitor
Phone display is very dim-can barely read
Well, first you will have to check your options, if you can read it enough to get in there.  You may have the backlight turned off.  If the backlight is not turned off, then you probably have a bad backlight and will have to take it to your provider to get it fixed.  Replacing a screen/backlight is not something I would attempt to do unless you are certain you know exactly what you are doing as you can render the phone completely useless.
May 28, 2009 | Motorola Mobility MOTO W755 Cellular Phone
Blank screen
If you see POST information, but no Windows... try looking for a symbol with two screens on it (usually a "F" function button across the top). Hold "Fn" and whatever "F"-key looks right, and you should be able to switch between laptop LCD, external monitor, or both simultaneously.
Feb 03, 2009 | Toshiba Satellite A105 Notebook
Toshiba equium A100-306
try function key for lcd it may be in presetaiton mode by mistake
or is lcd on / come on bright then go dim / dark just very dim if so your backlight is out replace lcd
Oct 24, 2008 | Toshiba Equium 7100S PC Desktop
Task bar locked
This is a fairly common problem with Windows Vista especially after a particular update. The steps/procedures are detailed here or here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 26, 2008 | Microsoft Windows XP Home Edition
Blank white screen
when switched on the phone,my phone screen only show nokia and i want to turn off cant. how to solve this problem?
Feb 08, 2008 | Nokia N76 Cellular Phone
LCD goes dim within 1-2 minutes
You could have a bad "inverter" or flourescent backlight tube, or a problem in your power supply.The only way to isolate the problem is to check each component in sequence.If your hard disk and DVD / CD drive are still working when your screen goes dark, then I'd say it's the "inverter". You'll have to take it to a repair shop.
flipbooks
Jan 20, 2008 | HP Pavilion dv6000z Notebook
Screen is dim
Try looking for a function key (usually used by holding down the Fn key and then pressing one of the "F" key at the top) the key will be marked with a brightness indicator.
Is your screen only dim when running off the battery is it dim when running when the charger is plugged in as well. If it is only dim when the laptop is running on battery then this may be caused by a setting in Power Options which is located in Control Panel (that is if your running Windows). In Power Options look for settings about running on AC Power and running on Battery power.
Jan 07, 2008 | Dell Inspiron 8500 Notebook
Lcd screen is on, but blank - nothing - no desktop comes up
Have you made sure it's not just switched over to external monitor? Check by holding the "Fn" button (usually at the bottom left of the keyboard) while pressing the key (often one of F1-F12) marked with different monitors. On mine this is F5. This may toggle it back if you have toggled it off by accident.
If it really is broken, I'd say $200 for a new one is a fair deal, at least if the computer itself is fairly up to date and powerfull.
Nov 07, 2007 | Toshiba Satellite A105-S4004 Notebook
HP Pavilion dv9000z Notebook Logo
115 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
