Question about Sony Handycam CCD-TRV37 Camcorder
SONY CCD-TRV37 8mm. video records with static in
SONY CCD-TRV37 8mm. video records with fuzzy static in the picture. When playing back on LCD or TV the video is very fuzzy. When I take tapes recorded a year ago and play then back, they are also showing some fuzzyness that was not there previously. What would cause the fuzzy recordings and what would cause the fuzzy playback of non fuzzy recorded tapes?
thanks
Mickey
  • chaffik Feb 09, 2010
    I tried cleaning the heads but it did not change anything. Please advise if there is another solution I could try.
  • chaffik Feb 10, 2010
    Sorry, What is the best way to do this? Thanks for all the help.
ctf1800
  • 4402 Answers
SOURCE: CCD-TRV308 Recording issuses
When was the last time you "cleaned" the heads? Use a good commercial head cleaning tape. They have both "Wet" and "Dry" types. I prefer the "wet" over the dry. I think it does a better job but they are hard to find sometimes.
you can also do it manually with "foam" swabs and "methanol1.gif". Alcohol works but the methanol leaves less residue behind.
If that doesn't solve the problem the next step would be to take it to a repair shop for cleaning and re-alignment.
Posted on Jan 29, 2008
welcomejee
  • 10594 Answers
SOURCE: No picture during playback on LCD or TV from my Sony DCR-TRV255E
Just use good quality Video Head Cleaning Cassette. Video head is dirty/ clogged.
Posted on Jun 18, 2008
welcomejee
  • 10594 Answers
SOURCE: SONY CAMCORDER CCD TRV 328 rec,problem
Your camera ccd-TRV328 has defect with ccd imager that's why not giving picture in camera / recording mode. This part (ccd imager) needs to be replaced and good news Sony will replace it free of cost.
Please click Sony Official Website for details.
Regards,
Posted on Sep 02, 2008
SOURCE: Cannot view recording
No that is not the proble. In the recrding mode it does record the images as well, but the images are absolutely unclear and does not show any color.
Posted on Nov 01, 2008
SOURCE: sony video camera will not record but will play previous taped t
TO REPLACE THE CCD ASSEMBLY. SOME MODELS ARE COVERED BY SONY WARRANTY EVEN AFTER WARRANTY PERIOD, BECOUSE OF FACTORY FAULTY CCD-S -ASK A SONY REPAIR CENTRE OR LOGIN TO THEIR WESITE GOOD LUCK: KOPASZ
Posted on Apr 21, 2009
How do I get the sony handycam dcr-hc30ntsc to show me a pictuer wale recording or any thing
If camcorder does not show live view in view finder and lcd screen but shows good picture in play back of old recorded tapes then ccd imager chip is defective in camcorder and need to be replaced.
It is not user level repair as soldering work is needed to replace ccd imager chip.
Let me know if you have additional question.
Thanks.
Oct 18, 2010 | Sony Handycam DCR-HC30 Mini DV Digital...
When playback of tape, fuzzy, not clear picture, or blue screen with sounds
try rewinding the tape and play it from the beginning.if still the same,video heads may be dirty and needs to be clean.i recommend you use a dry head cleaning tape.after which reinsert tape and play it again.if issue persists use a diff tape with previous recordings.if still no go,use new tape and try recording on it,play it back and check.if still the same your unit will require service.thanks:) hope this help.
Mar 12, 2010 | Sony Handycam CCD-TRV308 Camcorder
Everthing seems to work, except the camera will not record.
Assume you have Sony DCR-HC20 camcorder and it does not show you live view to record, I hope camcorder is playing back old recorded tapes perfectly with good quality picture on its LCD.
If it is true then your camcorder has ccd imager chip failure and ccd imager needs to be replace to get live view in LCD monitor.
Qualified camera tech will replace ccd imager chip.
Thanks.
Oct 01, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
Sony ccd trv218e, recording & playing back does'nt work
I had that problem also and I found that using smaller tapes helped. I was using the 120 minute tapes, I think they may be too heavy.
Feb 13, 2009 | Sony Handycam CCD-TRV21 Camcorder
Sony Handycam Vision videoHi8 will record sound, but no picture.
It is known problem of bad ccd imager in camcorder and requires replacement of that part.
Sony will repair CCD-TRV318 Free of Cost in ccd imager problem.
Please click Sony CCD Imager Support for details.
Good luck.
Jan 27, 2009 | Sony Handycam CCD-TRV318 Camcorder
Regards,
Sep 02, 2008 | Sony Handycam CCD-TRV328 Camcorder
Blurred image
This sounds like CCD sensor problem ( especially if the picture is "noisy" ). Canon and Sony fixes this particular problem free of charge since the CCD device installed in your camera should last + - 15 years if it is properly manufactured. Contact your agent and find out what their policy is.
Aug 19, 2008 | Canon MV650i Mini DV Digital Camcorder
LCD won't project
You may have a problem with the image sensor device (CCD). From October 3, 2005 through October 2, 2007, Sony will repair, free of charge, affected products exhibiting the above-mentioned problem where it is caused by the image sensor device. Sony will also cover the cost of shipping and handling from and to addresses within the United States and US Territories for service to correct this issue. To see if you have this problem: Power On your camcorder (make sure the battery is fully charged). Check the LCD screen and verify that the display icons are turned on. If you cannot see the icons, press the Display button until the icons are visible. Put a tape in the camcorder. With the lens cap off, record some video. NOTE: Be sure to speak during the recording so the video will contain your voice. Rewind this section of the tape (using tape counter to verify start of your recording). Play back the recorded video and use the LCD screen on the camcorder to view it. You should hear the audio you recorded and the Display icons/text will still appear. If your camcorder is affected by this CCD issue, the picture will either be extremely distorted, or there will be no visible picture (just a blank LCD screen with the display icons still visible).
Mar 22, 2006 | Sony Handycam CCD-TRV318 Camcorder
Sony Handycam CCD-TRV37 Camcorder Logo
440 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
