Where can I get display replacement for the CCR+? Thanks
  • carlbarzo Feb 06, 2010
    There is no catigory on your list for CCR+ radio, but I am new to site. And I still like repair methods or display distributors. Or just tell me the bottom line
    Thanks
  • 6,993 Answers
its not certain you can get another display for your CCR+, except you luckily see one that is no more working, and you can remove the display and fix it to yours.
Also you can go to an electronics repair shop in your area, you might find the display there.
Once you are able to get the display, simply loose the Radio with a screw driver, carefully remove the replace the replacement.
Take care
Posted on Feb 06, 2010
    Top Expert:
  • Audio Player... Master
  • 80,531 Answers
We are a technical assistance web site, we have no access to parts manuals for any product, I suggest you contact the manufacturers web site to see if they can supply the needed parts ,
  • yadayada
    yadayada Feb 07, 2010
    need the make and the model number of device and will try to help u.
CCR keeps enabling on Nortel Norstar
CONTACT NORTEL we have no idea what you are doing .
Dec 11, 2017 | Lands Phones
I now have the code for my radio but no manual to show how to put it in. Its a Philips CCR 600 in a Vauxhall Vectra (B) 1998 The Radio Screen is showeing 7 SAFE ! what dose this mean !
7 SAFE means wrong codes have been entered previously
To restore leave SWITCHED ON ...UNDISTURBED until it has automatically reset itself
This may take an hour or more
Vauxhall CCR 600 Code Entry
Press and hold the [ AS ] key and switch on.
'SAFE' will display followed by '10 - - - - '
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the third digit
To save the code press the [ AS ] key to accept
Feb 14, 2011 | Philips Car Audio & Video
What is the gas/oil mix for a Toro CCR 2450?
Hi my names Dane, and I'm going to help you.
The mix on the toro CCR 2450 is 50:1 I don't know if you;re having any more problems, but I wanted to include this link for you to check out. I'll let you judge.. Thanks! Dane
http://mattfleming.com/node/45
Dec 11, 2010 | Toro Lawn Mower With Toro Power Tools
How do I redo our company voice mail to set up - press 1 for dale, 2 for ian, 3 for bev....how do you assiciate the number 1 with dale's extension number 223, Ian's number 2 with his extension 224, bev's...
The programming of the individual paths is done in CCR programming. First you have to disable the CCR tree to change the programming This is accomplished by entering feature983>password>AA>table>Gtng table:1 (might be a different table but 1 is the most common)>press either ok or next til you see CCR tree: 1 then press CHNG and disable. Next press the * key til you return to the main menu ( mbox AA OTHR) and press the OTHR soft key. Press the CCR soft key >admin>and the tree number(probably 1). At this point it asks for a "path" number. A path is the action when a certain digit is pressed (1 for Dale..) Enter path 1> transfer>int>and 223 (which is dales extension number) and ok.Continue with the remainder of the paths until done.Next press the END soft key and the SAVE>SAVE as tree 1 YES soft keys. Lastly don't forget to re-enable the CCR programming AA>table>GTNG table:1>>>>> CCR tree: disable. CHNG>and the number 1. Press the Rls key when finished.
Oct 16, 2010 | NorStar Meridian M7310 Phone
No one in my work place knows how to work our phones. We use Nortel Networks T7316, it doesn't help that they don't make this model anymore :/. I was put in charge on setting everything up which i've done...
The feature your looking for is custom call routing(CCR). If your using 4 digit DN's then you probably have larger office environment which I'm not sure that a CCR tree will handle efficently. To build your CCR tree, enter into voicemail admin programming, press the OTHR soft key, then the CCR soft key ehn the ADMIN key
enter in a CCR tree number, then press build At this point you would enter in the number of the path you want to build and what it will do. ex. path 1 means when I press 1 on the dialpad I want it to call Mary's extension(transfer, internal, ext 2221) When your finished building your paths you'll need to save your tree.then you'll need to enable the CCR tree under AA,TABLE, Grtg Table:1, then press next til you see CCR tree: none. Press the CHNG soft key then 1 on the dialpad and ok. That will enable CCR tree 1 to work in greeting table 1. Theres a large section dedicated to building and changing CCR trees in the Nortel voicemail manuals so don't be discouraged if you don't get it on your first try. good luck
Sep 10, 2010 | NorStar T7316E Corded Phone
Re recording the CCR tree
You will have to determine which CCR tree is in use. Typically Greeting table 1 is associated with Company greeting 1 and CCR tree 1. After you log into the voice mail admin box choose "OTHR" then choose CCR, then ADMIN. enter 1 for tree 1. I believe at this point you get an admin option. Choose that and you should see "path:' Enter 0 for the path and you will see your record option. Do your recording and then choose end and save as tree 1. If you still have problems send me your email and I will forward you a cheat sheet I put together for the AA/CCR changes. I've been working on the Norstar/BCM - NAM/Callpilot line for quite soem time so there are very few things I don't know about these systems.
Mark
Mar 09, 2009 | NorStar T7316E Corded Phone
Disabling CCR Tree on M7310
Did you try F832, then select off?
Sep 12, 2008 | NorStar M7310 Corded Phone
21 people viewed this question
 Grubhead
Grubhead
