Question about Tefal UltraGlide plus 1656 Iron
My t-fal ultraglide iron will not work. I don't
My t-fal ultraglide iron will not work. I don't know if it was left on and the auto shut off came on, but now no light on or heat.
  • 3 Answers
SOURCE: tefal 400 iron auto shut-off light stays on
TEFAL B.800
AUTO LIGHT ON,BUT NOT TEMP LIGHT.NOT HEATING UP.HAD BEEN USING BUT UNPLUGED WHILE I GOT MOE IRIONING.
Posted on Feb 04, 2008
  • 2336 Answers
SOURCE: Premature shutting off
Have you try with lower heat setting?
It seems like it might be thermostat or thermal fuse that is not working properly.
Posted on Apr 21, 2008
SOURCE: Iron No Longer Heats Up
Recommended solution, gently shake, did not work.
Considering the iron was at a minimum two years old, I decided to purchase another Rowenta. I found the recommended solution documented on a FAQ sheet enclosed with the new iron.
I actually own another Rowenta iron (I now have three) that has the same issue. I will send one iron, the one manufactured in Germany, to a Rowenta Service Center to see if can be repaired - it was the first Rowenta iron I purchased and it provided several good years of service.
Posted on Sep 21, 2008
heatman101
  • 43501 Answers
SOURCE: Black & Decker Steam Xpress AS250 Iron with Auto Shut-off: my iron won't heat up. the green light comes on b...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
heatman101
  • 43501 Answers
SOURCE: Re: cleaning the iron
Here is a tip that will help you with cleaning the bottom of your iron...
Cleaning a Steam Iron Soleplate
http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate
heatman101
Can I use a descaler on my Tefal Ultraglide as the anti scale isn't working
Yes just use equal parts Vinegar & Water and fill as usual, and work through.
Apr 02, 2010 | Tefal UltraGlide Easycord FV4256 Iron
heatman101
Mar 07, 2010 | Tefal UltraGlide Easycord FV4256 Iron
I need descaling instructions for Tefal Ultraglide easycord55...Mislaid instruction booklet....Thank you
thank you solved de scale instructions for Tefal Ultraglide easycord 55, found manual on net....
Jan 09, 2010 | Tefal UltraGlide Easycord FV4256 Iron
The auto stp security light is on and the iron does not heat up i have a tefal ultra glide iron
i'm not quite sure what the STP security light is but on my iron a security light comes on when the iron is idle. It shuts the power to the iron when no movement has happened mine is about 5 mins.
Sep 16, 2009 | Tefal UltraGlide Easycord FV4256 Iron
T-fal ultra glide easy cord iron stopped working while ironing
heatman101
Jun 03, 2009 | Tefal UltraGlide 1569 Iron
Tefal iron stopped working
You better open your tefal iron,so you can fix the problem.When open look for the contact bronze in color must them place in the center,use a sandpaper to clean the contacts,when already clean test it if its okey going to hot again if not turn the udjuster to adjust it is a screw liked.
Hope it nay helps you;
Apr 22, 2009 | Tefal Aquaspeed 155 Iron with Auto...
Auto shut off
either the element is faulty or the switch you turned to give the diffrent tempreture has solder, if it is lose then your iron can repair if it is the element then you have to buy a new iron.good luck.
Sep 06, 2006 | Tefal UltraGlide plus 1656 Iron
Tefal UltraGlide plus 1656 Iron Logo
204 people viewed this question
Top Tefal Irons Experts
Billy Detlefsen
Are you a Tefal Iron Expert? Answer questions, earn points and help others
