Question about SanDisk Sansa Clip MP3 Player
When I turn on my Sansa Mp3 player I get an error saying "Not enough space for Music DB. Please free 30 MB." Then it shuts off. I'm not sure how to keep it on to delete music & make available space.
    President:
  • 949 Answers
Your player could be corrupt, please go to this webpage I posted and read it, it explains your error and how to fix it,hope you resolve the problem.
http://kb.sandisk.com/app/answers/detail/a_id/848/kw/Not%20enough%20space%20for%20Music%20DB/r_id/101834
Posted on Feb 06, 2010
3 Suggested Answers
  • 10 Answers
SOURCE: Sansa e280r "not enough space for music db. please free 6mb."
RECOVERY MODE
Switch your Sansa E260 to its Recovery Mode:
1. Make sure the player is powered off
2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface
3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button.
4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode"
5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above)
6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6.
Next, Apply the firmware for the E260 (your player should be connected to your PC at this time):
Step 1:
Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop":
http://www.sandisk.com/Assets/File/Downl...
Step 2:
Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred which caused the player to keep resetting.
Step 3:
When the process is complete, unplug your E260 from your computer, and please make sure you disable the "Hold" switch
Step 4:
Power up your E260 and 90-99% of the time, it would boot up successfully. If not, try to repeat steps 1-4 again.
I hope this helps.
Posted on Dec 01, 2007
ThaMp3Doctor
  • 8596 Answers
SOURCE: problem
Reformat
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 28, 2008
When i turn the player on it says Not enough space for music DB Please free 6 MB. But it says in the info Memory 0MB and Free 0MB
Connect to your computer copy music to a folder and save as whatever name you give it Then format Check the folder with the music in it to see if there is a file thats not MP3 delete it if there is one then replace the musicto the sansa keep about 6MB of free space
Dec 23, 2010 | SanDisk Sansa e260 MP3 Player
It keeps saying not enough space for music DB please free 90 MB when i turn it on
Remove the microSD card, then connect the Sansa to your computer. Delete one or more files (music, photos, videos) until you free up the required amount of memory.
Feb 10, 2010 | SanDisk Sansa Clip MP3 Player
Wont turn on
Slide the hold switch to off and when detected as a flash drive,format the device.... After this if it still doesnt work,use sansa updater to update the firmware
Sep 19, 2009 | SanDisk Sansa m230 MP3 Player
Not enough space for music db. Please free 6 MB.
If you have formatted there is no music on the player. You will have to re-sync any the music. Set the USB mode to MTP, then Use Windows Media Player 10 or higher to sync player.
http://www.sansaworld.com/
http://www.sansaworldmp3.com/
Apr 03, 2009 | SanDisk Sansa e260 MP3 Player
"Not enough space for music DB. Please free up 30 MB"
The mp3 manufacturers are often being disingenuous - they plug an mp3 player into a Macintosh, and it shows up, so they say, "Hey! It's Mac-compatilbe!" But, the software is certainly not Mac-compatible, so if you ever experience a problem, there is no way to fix it. Also, the Sansa e200 series does not recognize iTunes format.
In general, I would agree that you need to reformat your player, but I have no idea how to do that on a Mac (I'm good at a lot of things, but I'm Mac-illiterate).
-Tha Mp3 Doctor
Mar 15, 2009 | SanDisk Sansa e250 MP3 Player
Music DB??? clear 6 MB???
Have you tried re-formatting the device?  This will "wipe" memory, getting rid of corrupted files, etc. and should restore use.
Oct 24, 2007 | SanDisk Sansa e250 MP3 Player
Sansa M240 format error
you need to format like new one
Jun 12, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
170 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
