Question about LG WM-2277HW Front Load Washer
Code de turn unit on and error code de apears after a clicking sound.
  • Anonymous Mar 19, 2014
    won't work DE code
    Problem Solver:
  • 8 Answers
De is 'door error'. I just fixed this with a new door catch/switch (called a door overlock). Theres a bi-metal strip in there that makes the contacts as well as keeping the door locked closed when its working and it looks like this was the culprit as I was able to open the door even when the machine was filling. The de was intermittant, if you continued to open and close the door it would start eventually - if it does this try changing the switch, cost about £30.
Posted on Feb 26, 2008
  • king noel Feb 26, 2008
    sorry, 'interlock', not overlock.
  • 156 Answers
Ck water pump
Posted on Feb 25, 2008
Bosch WTB86200/02 E90 faulted When trying to start The sound of the dryer bips and relay which doesn’t switch
LOTS of fault codes here, but NO "E90"
BOSCH Side by Side Refrigerator Error Fault Codes Error Codes
Then there is this:
"Most of the times when the F:09 Error code apears on a Bosh Dryer is due to the thermal cut off being triggered, you can correct this issue by simply disconnecting the power to the unit and removing the back panel of the machine where you will find the button to be red. simply press it in and test the unit... if this doesn't resolve the issue, most likely your belt snapped off and would need to be replaced."
My Bosch dryer has error code 09 What does that mean
And if THAT is not enough, WATCH THIS!
Bosch Condensing Dryer F09 Error
Anthony
Dec 20, 2017 | Bosch Dryers
Error sc542 service
SC 542 Fusing temperature warm up error.Fusing lamp defective,poor fusing unit connector,thermistor warped or broken,thermostat has tripped,power supply defective.After verify the componenets try reset the error.Enter in service mode:Press the yellow key and press 107 and keep pressed the stop key 3 second.Touch the SP window on screen open the front door and turn OFF the copier.Wait 1 minutes ,close the front door and turn ON the copier.If the error code persist change the upper fuser roller and the thermistors.
Jan 01, 2014 | Ricoh Aficio 2022 All-In-One Laser Printer
Please Help! My LG WD-3274RHD has the error code "dE" after replacing assembly door switch?
dE for LG does the spring of latch hook actuate? no> fix door latch Yes> is there clicking sound once or twice when the start/pause button is pressed to start the cycle? No> check door switch and main PWB Assemblyhope that helps..
OE is Drain Error.
Sep 02, 2012 | LG WD-3274RHD Front Load Washer / Dryer
An error aperar wen i launch de my h03 apear un error says Error fan 01 and then turn off de projector,
maybe the fan for cooling the projector has a problem, you can bring it to the service center coz its not easy to replace those fan, thanks
Aug 07, 2011 | Computers & Internet
Hello: I have an LG front load Washer Model #WM2010C. Its' receiving a error code (de). I've looked it up and it seems to be "door error." I cannot open the door. When I go to...
You will need a new door llock switch.
to change it you will need to loosen the front bellow by removing clamp, unscrew the twwo scrwes holding the switch then unplug wires to switch and re-install.
Jul 02, 2011 | Washing Machines
My washer is not locking the door it sounds two clicks and is showing the leter in scream DE what is that means
HI. This is a Door Open error code.
Here are 4 reasons for this issue:
* The Door may not be all the way closed
* Loose electrical connections at door switch and pwb assembly.
* Door switch assembly is out of order
* Gasket on door may be creased in
Ok. You have stated that the unit is attempting to lock the door, but it is not locking. There are two click, then the error code illuminates the DE code. This is common when the control cannot initiate a door lock sequence. The cause will be a failed door lock mechanism, and it will require you to replace this mechanism asap, if possible. The actuator has failed. Replacing the door switch mechanism, will correct this issue.
Oct 19, 2009 | LG WM-2277HW Front Load Washer
The DVD an CD doesn't work
Check speaker connections and wires and make sure all wires are plugged properly. If problem still exist then unplug speaker one=by-one and test home theater to determine what speaker is causing Protect error.
May 17, 2009 | Sony DAV-C700 System
I found code error 88780078
check sound drivers in device manager
run-->devmgmt.msc
Jan 10, 2009 | HP Pavilion dv6000z Notebook
LG WM-2277HW Front Load Washer Logo
634 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
