Question about MTX Thunder 4202 Car Audio Amplifier
Is it bridgeable - MTX Thunder 4202 Car Audio Amplifier
    Top Expert:
  • MTX Master
  • 79,189 Answers
Yes you can bridge this amp to one channel
here are the specs for the amp
  • stereo or bridged mono output
  • Tri-way capable (Tri-Way crossover required)
  • 100 watts x 2 at 2 ohms
  • 200 watts x 1 in bridged mode
  • requires 10-gauge power and ground leads — wiring and hardware not included with amplifier
  • PWM MOSFET switching power supply
  • Intelligent Surface Mount Technology for cleaner sound and greater reliability
  • selectable 85 Hz high-pass/low-pass crossovers, 18 dB/octave
  • preamp outputs
  • speaker-level inputs with SmartEngage (turns the amp on when it detects signal from the receiver, eliminating the need for a separate turn-on lead from your receiver)
  • 9-3/4"W x 2-1/8"H x 9-3/4"D
  • Posted on Feb 06, 2010
    I have a kicker comp s with 4 ohm rating, two posotive and negative conections. and a kicker cx300.1 also with two positive and negative connections, the manual only shows how to wire a 2 ohm sub use one...
    Its depends, if your bridging the amplifier, you will be using one channel(the bridgeable cchannel , your two 4ohms subs will turn into a 2ohm bridge one negative out of one sub and a positive out the other one then you conect the neg to pos between subs (ohms Law). To your bridgeable amp channel, your amp must be 2 OHM stable on the bridge channel.
    Feb 08, 2018 | Car Audio & Video
    How do i bridge all 4 channels on the jensen 400 watt 4 channel lxa amp ?
    • This amp is not "bridgeable" at all. You will either blow the front end or blow the low end voice coil in your sub.
    Regards, Tony
    May 24, 2011 | Jensen LXA400 Car Audio Amplifier
    Alpine 3530 Bridgeable 4 channel power amplifier how do i connect the wires/speakers
    Use the left and right to connect the positive and negative to the respective speakers in the right and left. Please make sure of the polarity and so be cautious. next you can connect the sub woofer from the left and right channel as the amp is bridgeable. Use the lead to connect from the R- positve to L negative. test and check the phasing of the speakers, must get good low bass or else you can reverse the sub woofer and check again. If you ae having frint speakers connect accordingly the the other channel. Helpful Good day
    Jul 12, 2010 | Alpine Car Audio & Video
    Titanium 800.1
    It's a mono block so define bridgeable? It is only a "ONE" channel amp.
    Jun 19, 2008 | Phoenix Gold Titanium 800.1 Car Audio...
    Bridgeable vs not bridgeable
    All amplifiers are bridgeable. The bridge setting is for driving a large speaker by using the power output of 2 or more channels. The power will be summed if a bridge is made.
    For example, if you have a 800W, 4 channel power stage, you can connect 2 component speakers in the channels 1 and 2 and bridge the channel 3 with the 4 to drive a subwoofer.
    Feb 14, 2008 | Car Audio & Video
    Is it not bridgable
    This amp isn't bridgeable. It's a mono amp (only one channel). You need two independent channels to bridge. Some mono amps are bridgeable if you have two identical amps but I don't think Kenwood recommends that with this amp.
    Jan 27, 2008 | Kenwood KAC-9152D Car Audio Amplifier
    Bridge a not bridgeable amp
    It will probably blow a fuse or blow up completely.
    When the output stages ar not lifted from ground
    as is the case in a bridgeable amp bridging cannot
    be done.
    Jan 12, 2008 | Performance Teknique ICBM-782 Car Audio...
    Gemini P601
    the gemini p-601 is not bridgeable. you can select either speaker pair a, speaker pair b, or both pairs, but you can not bridge it without potentially damaging the unit.
    Oct 27, 2007 | Philips GEMINI P-601 Fan CooledStereo...
    MTX Thunder 4202 Car Audio Amplifier Logo
    156 people viewed this question
    Top MTX Car Audio & Video Experts
    hoyzee1
    Mark Skinner
    Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
