Question about Dishwashers
My frigidaire dishwasher did not come with the drain hose. Is this something I can get from a hardware store or would I have to order it from the manufacture?
  • 572 Answers
Id order it. sometimes other hoses causes leaks. different material
Posted on Feb 06, 2010
    Sergeant:
    Champion:
  • 263 Answers
Hardware stores usually don't have that. You can easily order it online with model number.
Fridgidaire dishwasher repair in orange county, ca
appliance repair orange county, ca
Do I need a new drain pump?
Get a wet vacuum and hook it to the drain HOSE
May 29, 2015 | Frigidaire Professional Series 24"...
How to extend the drain hose Siemens SL34A006UC/22 Dishwasher
get another hose same diamiter and two hose clamps and a splice nipple from hardware store, cut hose to lenght with some extra insert nipple into both hoses and clamp with hose clamps make sure you get them tight.. use a metal nipple as a plastic one may crack when you clamp hoses
Dec 13, 2009 | Siemens Dishwashers
Water didnt drain from frigidaire dishwasher model FDB989GFC
Hello!
If your dishwasher does you need to check all this parts:
1. Check sink drain and drain hose for restrictions
The drain hose and recirculation hoses can be responsible for leaks. The drain hose can cause the dishwasher to fail to drain properly. The recirculation hose can be responsible for problems with poor rinsing of dishes.
2. Unjam the motor
3. Unjam the pump
4. Check the drain valve
5. Check the drive belt
6. Test the timer motor
If you have a brand new dishwasher or garbage disposer, check the knock out plug on the garbage disposer.
Dec 02, 2009 | Frigidaire Dishwashers
Dishwasher has a smell and all the water is not being pumped out
There is a product called " Dishwasher Magic " to clean, deodorize, and disinfect dishwashers. Hardware, appliance parts, and possibly grocery stores should carry it. It comes in a rectangular 12 once bottle.
Also, check to see that the drain hose loops up higher than the outlet into the drain so no water will run back into your dishwasher from the drain or disposer. Plugged up pump inlets and on some models a degraded drain pop up valve will also result in excessive water remaining in your dishwasher. You didn't state you model number in your post so I can't tell if your machine has one of those.
May 30, 2009 | GE Nautilus 24" Built-in Dishwasher
Installing a used dishwasher just need to now how big of drain line is needed the one on this lookes bigger than most dishwashers can i reduce it to smaller ruber hose
Most hardware stores should have plastic reducers that slide on your drain hose,then attach the correct size to the reducer to drain.
Apr 07, 2009 | Moyer Diebel 24 in. 301HT-40 Built-in...
Model #GLD215ORCBO Water does not drain out from the bottom of the machine and there is a strange noise almost like a sizzling sound. Is there something that is plugging it up? Or is there a trap that can...
You most likely have something blocking the pump. If you can get a wet vac, disconnect the drain hose from under the sink, and vac out the water straight through the hose. Occasionally, this will remove the blockage (probably not though).
If not, disconnect the power at the breaker or unplug the unit if possible, and remove the lower panel. You should be able to see the drain pump fairly easily, and on most models, it has a holding tab that must be pressed inward so that it can be twisted off. Disconnect the wires and hose clamps and you can pull out the pump, and remove it from the pump housing (should be screwed on.)
Remove the (probably) piece of broken glass or whatever, and do the above in reverse order until you have a working dishwasher!
Apr 07, 2009 | Frigidaire Dishwashers
E 1 error
90% of the time you get an E1 error code is because the drain hose is not properly installed between the LG dishwasher and the drain. The hose should connect to an Air Gap valve (almost free at any hardware store) but in a pinch, raise the drain hose near the drain and attach the hose to the bottom of the counter top under the sink. Is should rise almost 30 inches between the dishwasher and the drain or the water WILL siphon out of the dishwasher as soon as the wash or rinse cycle begins (and take 5 minutes before the water gets low enough the cause the E1 error.
Good Luck!
Nov 21, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Hose required for Amcor 12000!
hi,
looking at the standalone a/c the vet has in their office where I live, I noticed what they are using, its a dishwasher drain hose and you can get them at any hardware store, you will need a hose clamp for that also, the hardware store employee should be able to get the right clamp for you. Im in the united states but Im pretty sure dishwasher drain hoses are universal.
good luck
J
Aug 06, 2008 | Amcor 12000 Air Conditioner
A common problem with dishwashers is the non-draining machine. If you are having trouble, check to see if the drainpipe and sink trap are clogged. If you still have drainage problems after doing this, check your drain hose to make sure there are no kinks or bends. if the hose looks worn out you can replace the hose pretty inexpensivley. if your have thoughly checked from dishwasher to trap under the sink where your dishwasher should drain to and it seems clear you may have to call in the repair man.
Jun 18, 2008 | Frigidaire 24 in. FDB510LC Free-standing...
Dishwashers Logo
61 people viewed this question
Top Dishwashers Experts
