Question about Honeywell Programmable Thermostat Heater
Set back thermostat has mind of its own.
Help! honeywell visionPRo th 8000. (heat pump, oil back up) this happens randomly only at night; i wake up in the middle of the night hot (and its not my hormones): house stays warm all night, even after set back goes to 63 (from 70). the thermostat is programmed... and says 63, but thermostat still says 70. i reprogram it, but it has a mind of its own. it drives me nuts. have you heard of this problem?
  • 407 Answers
The Honeywell Vision Pro 8000 can be complicated to figure out if it isn't set up right from the system menu. There are so many things that you can make it do, sometimes the most common things are wrong. My question is ''what kind of system do you have, heat pump or not?, and is the system gas or oil?" If I knew these things, I could definitely help you figure out if the thermostat is set up right. I have the manual so that I can give you exact numbers. Just in case, you can email me at : kingbrizzle@aim.com
Posted on Feb 07, 2010
Howto hook up th8320R1003 to heat pump
Byron, unless you have thoroughly familiarized yourself with the terminal designations on all three components, t-stat, air handler and heat pump you shouldn't attempt connection of the control. There are many variations of what will work and many more variations of what will NOT work.
No mention of outdoor sensors, so fine tuning of the electric heating stages to match the heat loss of your house (for most efficient operation) doesn't sound possible.
I know, this answer didn't help but there is no simple answer without having all the components in hand.
Mar 05, 2015 | Honeywell TH8320R1003 VisionPRO 8000 w/...
Why is my honeywell 8320r1003 short cycling for hot water heat.I have heat set at 65 degress.cycling 2min,3min,the most is 8min.
Hi Bill, after closing your thermostat, is this correct the situation?
And how far is your thermostat from your baseboard heater, if the baseboard is underneath the stat, you should move the stat elsewhere. Hope this help you find the problem.
Jan 03, 2015 | Honeywell TH8320R1003 VisionPRO 8000 w/...
Our visionpro 8000 thermostat has adjusted its day. It is currently one day ahead. We have misplaced our manual and we cannot seem to get the day to change. Suggestions?
This site has owners manuals for different types of thermostats. http://yourhome.honeywell.com/home/Products/Thermostats/7-Day-Programmable/VisionPRO+8000.htm
This site is the manual for the "VisionPro 8000". You can look up what you need, copy or download. http://customer.honeywell.com/techlit/pdf/PackedLit/69-1894EFS.pdf Roger
Apr 07, 2011 | Honeywell Heating & Cooling
Honeywell 8000 Thermostat relay switch clicking noise.
It's an expensive solution but doable. Look for Honeywell's VisionPro IAQ thermostat. It works much differently than a conventional thermostat and shouldn't click at all make sure it's the 3-wire version.
Aug 21, 2009 | Honeywell Programmable Thermostat Heater
Honeywell VisionPro 8000 cycles between Hot and Cold all day.
yes it sound like either they wired it wrong or when theywent and configured the settings this obe did not take to the configuration correctly. Have the contractor come back and do the job correctly or replace the thermostat. Thinks for using Fixya
Dec 24, 2008 | Heating & Cooling
Non-deletable schedule in VisionPRO TH8000
The thermostat has a function called "Adaptive Intelligent Recovery".
This feature allows the thermostat to learn how long the furnace and air conditioner take to reach programmed temperature settings, so the temperature is reached at the time you set. For example: Set the Wake time to 6 am, and the temperature to 70°. The heat will come on before 6 am, so the temperature is 70° by the time you wake at 6.
You can turn off this function. Download the installation guide at the next link:
http://customer.honeywell.com/honeywell/ProductInfo.aspx/TH8321U1006
and look for funcion number 0530 Adaptive Intelligent Recovery. In this manual you also find the way to do a reset with the function number 0710.
I hope this solves your problem.
Nov 19, 2008 | Honeywell Programmable Thermostat Heater
Wiring a Honeywell VisionPRO TH8320U1008 Thermostat
the thermostat will to any temperature but will not shut off
Nov 25, 2007 | Honeywell CT3600 7 Day Electronic...
Heating & Cooling Logo
301 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
