Question about Fujitsu Siemens LifeBook N3511 Notebook
POWERED UP AND NOTHING LIGHTS ARE RUNNING - Fujitsu Siemens LifeBook N3511 Notebook
Did you press and hold for 30seconds. This helped with my laptop. Hope this helps.
Posted on Feb 06, 2010
Cab lights are not working
turn the switch on ha ha, not sure what kind of light fog or interior check switch & make sure of your ground with a test light it sounds like you should have good power after trying all those spots
Aug 11, 2013 | Cars & Trucks
Bike running fine suddenly no power , fuses good but no lights nothing
check permanent live and switched live at the ignition switch...
Nov 15, 2012 | Motorcycles
The power light is on but my satellite A75-229 won't turn on. It was on last night running fine. The battery ran out because I forgot to turn it off so I plugged it in and pushed the power on button and...
Try letting the computer sit without the battery for a few minutes, and also without external power. Then try plugging in your external power WITHOUT the battery and try to start it up. If it does, add the battery while it is running. Then try it with the battery only.
Nov 30, 2010 | Toshiba Satellite A75-S229 Notebook
Emachine t2882: not powering up just an amber light. replaced power supply, still just an amber light. power supply fan runs, but cpu fan does not. reseated all connections. plugged in drives one by one,...
Hello there:
ok unplug everything from the board first and power up and see what happnes. if nothing still unplug the powersupply to the motherboard and press in the power button and hold it in for 1 min and than plug in the powersupply to the motherboard and see what happnes. Also doublecheck the jumper for the cmos. ok please keep me informed there is a lot more that we can do but lets try this first ok best regards mike
Aug 16, 2009 | Computers & Internet
Have running lights, brake lights,dome and dash lights. but, the headlights do not work. replaced headlights nothing. not getting power to the plug.
Power runs from the headlight switch down to the dimmer switch, then to the lights. Start by checking for power to the dimmer switch when headlamp switch is on. There should be power in one wire and power out 1 for low and the other for high beam.
Jun 23, 2009 | 1983 Chevrolet Silverado
HP Pavilion a1150y fans run when powered on but windows doesn't load, monitor, mouse and keyboard do not work. (Running Windows XP)
Believe it or not, it's due to a weak power supply. More specifically, weak voltage rail/s caused by failing Electrolytic Capacitors.
A bad computer power supply is about 70% of computer failure.
ALL the light use less than 1 Watt. EACH fan uses 2 to 3 Watts.
A processor uses 55 to 125 Watts. Depends on the make and model.
Since the power supply is weak, it doesn't have enough power to turn the processor on.
No processor, nothing to find the Boot record on the harddrive. Nothing to get the Operating System going. (Example: Windows XP)
No computer running, there is no signal to the monitor.
Just enough power to light lights, and spin fans.
Apr 13, 2009 | HP Computers & Internet
I PLUG THE E-MACHINE IN AND NOTHING
Is the power supply fan running? If not then the power suppy needs to be replaced, that is what sends power to the rest of the computer.
Mar 15, 2009 | E-Machines eMachines Desktop PC
LIGHT comes on, but nothing else running.
check the starting unit on the compressor for power. If it has power, it is bad.
Dec 31, 2008 | GE Refrigerators
Kenmore Model 587 -- Will not run - Power lights come on/wontrun
Hello I am V- Mari and i own a Kenmore dishwasher model Number 587.1574590 and it doesn't work at all. The power light comes on and it seems to make noise, but it does nothing. Is there a recall for these models or free fix help please respond to miss_vmari@netzero.net. I would like to solve my dishwasher problems as soon as possible. Thank you!
Dec 12, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Fujitsu Siemens LifeBook N3511 Notebook Logo
273 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Marcin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
