Question about Yamaha HTR-5240 Receiver
Play iphone music with yamaha htr-5240
How can I hook up my iphone with this receiver to play my music through the surround sound?
SOURCE: Codes for Yamaha HTR-5240
just go here and download the manual...
http://www.usersmanualguide.com/yamaha_audio/av_receivers/htr-5240
it has all the codes listed
Posted on Mar 31, 2008
SOURCE: my yamaha htr 6050
Make sure your audio output on your PS3 is configured properly. You have the ability to chose which port the audio is coming out of.
The 6050 does NOT process audio signals coming in on the HDMI port. The amp is weak, I had one. With the 6050 you will have to use the AV multi coming out of the PS3 and use the special cable that came with the PS3 to convert that signal to the RCA and connect that to the 6050.
Posted on Jul 27, 2008
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
  • 55 Answers
SOURCE: Is it possible to play my ipod nano through my Receiver?
If it doesn't have a jack made for plugging Mp3 players into it like the new car stereo's do than you just have to go buy an FM transmitter that is made for Mp3 players. It will play through one of your low FM frequency's on your receiver. You can generally pick one up for around $20
Posted on Jan 02, 2009
marklights54
  • 12 Answers
SOURCE: I need the remote code for the Yamaha HTR-5740
0176,1176
http://www.comcast.com/remotes/universal.html
Posted on Mar 01, 2009
Find Blu-ray player compatible with Yamaha htr-5830
Hello James,I have the exact same issue, did you have any luck?
Dec 28, 2012 | Yamaha HTR-5830 Receiver
HTR-5240 short circuiting
First i would strongly suggest that you review your wiring, since the problem occurred after those change , It might also be just coincidence. When you are playing something(music) go around and listen carefully to each of the speakers, check for muffled or distorted sound, that could indicate a speaker or wiring problem. Of course the problem could also be in the receiver. The protection circuit in your amplifier could be acting up(too sensitive), in that case you might need the help from a local repair tech.
Hope this will help Good luck
Nov 27, 2009 | Yamaha HTR-5240 Receiver
I am looking for the owner's manuel the YAMAHA HTR5660
http://www2.yamaha.co.jp/manual/pdf/av/english/re/HTR-5240.pdf
Jan 05, 2009 | Yamaha HTR-5240 Receiver
Yamaha htr5230 hookup
Hi, Your receiver is really the same as my HTR 5240. Same back and front. basically. Go to Retrevo for manual. Shows all the hook ups. I have VCR , DVD, Tape Deck, hooked to mine but can't find the adapter so i can hook up my indoor fm antenna. All my components plug to back of receiver then there is one RCA wire running from receiver to Tv.
Sep 01, 2008 | Yamaha HTR-5230 Receiver
Yamaha HTR-5240 no sound from main speakers
check and see if there is a a/b,a+b setting for speakers make sure its set to a
Jan 06, 2008 | Yamaha HTR-5240 Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
Yamaha htr-5240 dolby digital problem
Is there switch from dolby pro logic/ surround / or analog/ digital?
Sep 27, 2007 | Yamaha HTR-5240 Receiver
Yamaha HTR-5240 Receiver Logo
69 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
