Question about Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ Bottom Freezer French Door Refrigerator
Freezer won't chill beyond fridge temp
I have an Amana ABD 2533 and since last night, the freezer will not chill beyond the refrigerator's temperature. We can hear it try to turn the compressor on (loud buzz every few minutes), but then nothing happens, just a continual low hum. Any ideas for a DIY fix, or do I need to call a repair service? Thank you so much!
    President:
  • Amana Master
  • 2,651 Answers
Compresoor sounds like its tryin to start but cant, should be covered under 5 yr manufacture warr.
Posted on Feb 24, 2008
Amana refrigerator Light and refrigerator/freezer top freezer model are both off. Is there a reset button? Both were fine last night.
if everything is out even the lights check the plug and make sure the fuse or breaker isn't popped,unplug the fridge and plug a lamp or something in there to check power,i've seen fridges on a gfi plug so check that too,but sounds like no power to fridge.next time send the full model number off of the machine,
Feb 04, 2018 | Amana Refrigerators
Amana refrigerator A4TXNWFWWO1 >top freezer, bottom fridge it's only 10 months old refrigerator won't get colder than 55 degrees freezer is working
There is something plugging the drain line in the freezer which carries water from the defrost cycle to your evap drain tray in the bottom of your fridge. The water has built up and froze plugging the flow of air from freezer to fridge.... find the line and unplug it and let fridge sit and thaw overnight and then some more.
Jul 19, 2011 | Amana A4TXNWFWW Top Freezer Refrigerator
Refrigerator compartment doesn't chill
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Feb 04, 2010 | Amana Refrigerators
Fridge and freezer not staying cold - Got home last night and my whirlpool (frost free) fridge/freezer was switched on (power running to it - light etc working) but was not chilling properly. Everything in...
This can happen if the fan motor in the freezer compartment is bad. Causes the freezer section to freeze up and you will not get air circulating, so no cooling. Check the fanmotor
Nov 06, 2009 | Cars & Trucks
Refrigerator compressor never kicks on.
If the compressor "never kicks in," I don't see how you have having any cooling at all.
It could be a relay, or it could be the compressor. If you're lucky, it's a relay. These are cheap. In any event, it will take a diagnosis that is probably beyond the capability of a do-it-yourselfer.
Oct 15, 2009 | Amana 25.9 cu. ft. Side-by-Side...
Amana bz22rw fridge temp fluctuates & is a little warm - freezer is ok should i replace the fridge temp control or the damper
Temp control = controls run time of the compressor and temp of freezer.
damper and cold control = control how cool the fridge is...
also check you fan speed and air flow to the fridge.
Sep 19, 2009 | Amana Refrigerators
Hi, my amana freezes my food in the refrigerator....
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..It may be stuck open letting in too much cold air.
Aug 15, 2009 | Amana Refrigerators
Amana refrigerator will not chill
That model number does not come up for me.
Click on and enter model number
http://www.searspartsdirect.com/partsdirect/index.action
Jan 10, 2009 | Amana BC21V1W Bottom Freezer Refrigerator
Amana Fridge with bottom Freezer
either the switch or the temp sensor it broken. on the sears site you can get the part number
Apr 24, 2008 | Amana ABB1921DE Bottom Freezer...
Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ Bottom Freezer French Door Refrigerator Logo
174 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
