Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
What amp fuses are needed for this tv? - Philips 55PW9363 55" Rear Projection HDTV-Ready Television
TV will not turn on. The fuse is blown. Need to
hello,
replace the fuse with the rating of 2.5A,
you can also check the iron head of the fuse.
Good luck...
May 25, 2010 | Televison & Video
No power
Yes, there will be an internal fuse & other protection devices. Even if a fuse has blown this may not be the cure, a fuse will blow because a fault has developed elsewhere in the circuit & replacing the fuse will just blow again. Again all fuses may be intact in which case you would need to trace what voltages are present & which are missing from different parts of the power supply using a multi-meter. If there is no supply from the secondary part of the power supply then a regulator transistor will be at fault. If there are voltages present then you will need to find which parts of the TV is not starting up, possibly a fault in the control board etc.
Nov 06, 2009 | Proview Mh422su 42 in. EDTV-Ready Plasma...
TV won't turn on
take the back off the tv and inspect the glass fuse off the ac power cord, it will probably be black and open, this is a common problem, it blows because the degaussing circuit works too slow, the original fuse is an 6.3 amp fuse, you need to replace it with a 6.3 amp slow blow or a 7 or 8 amp fuse to keep it from blowing, if you put an original 6.3 amp fast blow fuse in it, it will work for a while, but will blow again someday.
Sep 07, 2009 | Panasonic CT-32SX12 32" TV
Tv won't turn on
I assume you do not have any red light showing on the front of the TV to indicate it is receiving power? Again assuming the your mains electric supply is functioning & the fuse in the TV plug is ok, if there are no signs of life & then most likely a fuse in the power supply may have blown. If you have a multimeter you could remove the rear of the TV & check the fuses in the power supply, if these are ok then you will need to check any supply voltages coming from the power board. If one of the fuses are open circuit, check some of the doides or transistors for any short circuits. If you are not comfortable doing this, then it would be advisible to contact a repair service centre.
Jul 28, 2009 | Televison & Video
Don't know what size and amps fuse to use for T4E250V (#on the fuse)
4 amp slow blow -- any fuse with those characteristics will suffice.
May 30, 2009 | Philips 27PT6441 27" TV
Rca tv model # F32672SB
The fuse is a 5 amp,can get at any electronics store
Jan 09, 2008 | RCA F32672SB 32" TV
Tv Fuse Blown
Depends on how hard the fuse blew. If softly, perhaps 1 amp diff is too much.
If hard - blackened inside - then you need to call in a tech.
Mr Bob
www.imageperfection.com
Dec 22, 2007 | Pioneer SD-P55A3-K 55" Rear Projection...
Blown 4 amp fuse twice
ok appaloosa! is the fuse blowned again? if blow you have fault unregulated power section, you have defective parts like.. leak degausing or defective diodes or capacitor and or regulator IC. 2nd. defective horizontal output. if not blow the fuse u have fault oscillation!
Sep 14, 2007 | Pioneer SD-P55A3-K 55" Rear Projection...
Fuse blown
the fuse will always blow if there is a shorted component. the horizontal output transistor may be the most likely culprit, if you are not a technician, have it service by a qualified one.
May 15, 2007 | Samsung TXR3079 TV
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
22 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
